For Sale/ Wanted - Big Block Engine - 1st Quarter #3279402
12/31/24 06:56 PM
12/31/24 06:56 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter [Re: moparts] #3279568
01/01/25 10:36 AM
01/01/25 10:36 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New Mopar Performance chrome big block distributor hold down. $20
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping.
gt340 @ yahoo.com
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter [Re: moparts] #3279590
01/01/25 11:27 AM
01/01/25 11:27 AM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Carter AVS carburetor # 4682SA D9 date code. This is for a 1969 383 engine. Carb is complete and clean but has a hair line crack in base. Not sure if it will work as is or use for parts. Asking $40.
Contact Bud: Kramden426 at aol.com
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter [Re: moparts] #3279599
01/01/25 11:39 AM
01/01/25 11:39 AM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Pair of big block spool type motor mounts for 1973 and 1974 B-body cars. Also fit the early Direct Connection big block A-Body K-frames. Not sure if these are new or just very clean and painted used. Also included are the special non twist long bolts but no nuts. Asking $40. Also have a used pair that are rusty $25. Contact Bud: Kramden426 at aol.com
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter [Re: moparts] #3279606
01/01/25 11:49 AM
01/01/25 11:49 AM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Holley spread bore carburetor # 7002-1. This can be used as a replacement for the Carter Thermoquad. Carb is complete and clean-may work as is but I didn't test it. Comes with plastic spacer. Asking $75. Contact Bud: Kramden426 at aol.com
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter [Re: budman1965] #3280064
01/02/25 07:46 PM
01/02/25 07:46 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I'm wanting a 4500 M1 intake for a low block. If you can help me out with one of these let me know, thanks. Rick Seeman 501-519-742five
2011 Drag Pak Challenger
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter [Re: moparts] #3280086
01/02/25 08:42 PM
01/02/25 08:42 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand but it never was run and is essentially new. $375 + shipping. I also have a new set of Comp Cams 973-16 inner valve springs I was going to use with this cam and Edelbrock RPM heads that I am asking $40 for.
https://www.summitracing.com/parts/HRS-CL722322-08
https://www.summitracing.com/parts/cca-973-16
gt340 at yahoo.com
Howard's Cam.JPG (500 downloads)
Howard's Cam4.JPG (500 downloads)
Howard's Cam2.JPG (500 downloads)
440 Six Pack Center Carb 4144-1 - reconditioned [Re: rickseeman] #3280685
01/05/25 01:07 PM
01/05/25 01:07 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a 440 six pack center carb part # 4144-1 that was factory reconditioned by Holley. Has not been run since reconditioned.
$750 shipped in the lower 48 states. I will ship internationally for the added cost.
Email me at procketrichard@hotmail.com for more pictures or any questions.
Lunati Big Block Solid Roller Cam & Lifters - New [Re: Rocket] #3280755
01/05/25 04:46 PM
01/05/25 04:46 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new Big Block Lunati solid roller cam part # 40230912 & solid roller lifters part # 72451-16. The specs of the cam are as follows:
Part # 40230912
Basic Operating RPM Range: 4,500-7,500
Duration at 050 inch Lift: 276 int./284 exh.
Advertised Duration: 312 int./320 exh.
Valve Lift with Factory Rocker Ratio: 0.690 int./0.690 exh.
Lobe Separation Angle 106
Camshaft Gear Attachment: 3-bolt
Valve Lash: 0.026 in. Intake 0.028 in. Exhaust
Lifter Specs and Description are as follows:
Part # 72451-16
Fits Engines 361-440
Lifter Diameter 0.903"
Weight – Lifter Pair 256 grams
Seat Height 1.98"
Pressurized Oiling to Roller Bearings - Yes
Pushrod oiling - Yes
Lifter Wheel Diameter 0.81”
Developed for serious racing applications, the pressurized oiling system of these lifters provides constant lubrication through the axle and to the needles. This reduces wear in the axle and increases the durability of the lifter. Also, for increased durability, all surfaces are hardened and polished, which makes the body stronger and smoother while reducing friction. The solid vertical bar roller lifters with pressurized oiling are held to higher standards than the competition for the ultimate in race lifters
Was planning to build a big block bracket engine but plans have changed so these are no longer needed. I have not opened the lifter package as it is one of those plastic packages is like Howards lifters and usually breaks and never stays shut on its own afterwards. Picture of lifter pair is what was on a retailers website.
Price for the cam and lifters is $1,250 plus $30 shipping.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter [Re: moparts] #3281845
01/10/25 11:32 AM
01/10/25 11:32 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
Mopar one pair of 1967 440 HP exhaust manifolds, one year only and very hard to find $975.00 for the pair (708) 288-2879
parts 1-10-2025 022.JPG (207 downloads)
parts 1-10-2025 023.JPG (207 downloads)
parts 1-10-2025 024.JPG (207 downloads)
parts 1-10-2025 025.JPG (207 downloads)
Re: Wanted - Big Block Engine - 1st Quarter [Re: dsd70bee] #3281881
01/10/25 02:05 PM
01/10/25 02:05 PM
I need and want to buy a stock AVS intake and carb for a 1970 375 HP 440 manifold, casting date from 04-1968 to 10-1968. I need a stock single or dual point distributor also if you have one.
PM me on here or E mail me at cabburge@wans.net, let me know your price with the shipping to me in zip code 97702 which is Bend, OR
Thanks: Cab
Throttle cable brkt [Re: moparts] #3281901
01/10/25 03:06 PM
01/10/25 03:06 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Throttle cable bracket for auto trans
Came off a 1969 440
$40 plus shipping
PM me for info please
Remember when cars were FUN?
Alt brkt [Re: Cab_Burge] #3281902
01/10/25 03:09 PM
01/10/25 03:09 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Alternator bracket from a 1969 440
$20 plus ship
HOLLEY 37-921 [Re: moparts] #3281944
01/10/25 05:29 PM
01/10/25 05:29 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
HOLLEY Trick Kit 37-921
It has been opened, not sure if anything is missing as this kit seems to be no longer available
$45 plus shipping
HOLLEY 3-396 [Re: moparts] #3281946
01/10/25 05:50 PM
01/10/25 05:50 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
HOLLEY 3-396 gasket pkg for HOLLEY 2300 2bbl
It has been opened.
Not sure what is missing as the kit seems to be discontinued
$20 plus shipping
P4007671 6bbl tune kit [Re: roadntrack] #3281960
01/10/25 06:38 PM
01/10/25 06:38 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
DIRECT CONNECTION MOPAR PERFORMANCE P4007671
Tuning pkg for 1969 440-6bbl
$185 plus shipping
water pump housing [Re: moparts] #3281969
01/10/25 07:14 PM
01/10/25 07:14 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
High flow Water pump housing from a 440 motorhome.
casting 3751216
$50 plus shipping
pump housing.jpg (225 downloads)
Meter plates [Re: roadntrack] #3281975
01/10/25 07:41 PM
01/10/25 07:41 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Holley metering plates from 1970 440-6bbl
Stamped 34 and 35
$90
PM me please
Re: Meter plates [Re: roadntrack] #3282014
01/11/25 01:30 AM
01/11/25 01:30 AM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
1970 440-6 metering plates...more photos
Iskenderian 1623 PushRods [Re: moparts] #3282233
01/12/25 12:55 PM
01/12/25 12:55 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Isky 1623 chrome moly tubular pushrods
413 / 426 / 440
set of 16, new in box, some light surface rust spots from storage
https://iskycams.com/shop/index.php...p;zenid=8e92b69ec0b78f22185564f7cea1c96e
list for $286.99 at JEGS & Summit
$125.00 + shipping from 08724
PM or email address is in my profile
