enclosed trailer inside finishing #3280502
01/04/25 05:54 PM
01/04/25 05:54 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Hey everyone,
looking for thoughts on types and colors of paint for the inside of your enclosed race trailers. just picked mine up today way too cold to do any painting or electrical to it for a few weeks or months up here in Michigan.
so, wondering what you guys have used for paint on the walls and floor that will stand the test of time. mostly the floor with running drag radial and or a slick at track. what sticks and stays down with minimal maintenance on floors.
let me know what you have done
please and thank you.
Thank you
Kiddart
Re: enclosed trailer inside finishing [Re: Kiddart] #3280510
01/04/25 06:16 PM
01/04/25 06:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
When is purchased my 28' enclosed someone had painted the whole inside dark machine grey. It was like a dungeon inside, even in the middle of the day with the doors open, unless I turned on the lights. I just used the cheapest semi gloss on sale exterior white house paint I could find and painted it all white, but the floor. I left the floor the grey. Made a huge difference. Don't even need lights during the day. That was like 6-7 years ago and still looks great.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: enclosed trailer inside finishing [Re: 6PKRTSE] #3280534
01/04/25 07:46 PM
01/04/25 07:46 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I always paint the all the wood inside with Kilz then go back over it with white latex, never had a problem doing it that way... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: enclosed trailer inside finishing [Re: Kiddart] #3280538
01/04/25 07:50 PM
01/04/25 07:50 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I used Behr semi gloss white that was a primer and finish paint all in one. It wipes down easy and still looks like it did when put on(5yrs ago).
Ok
Re: enclosed trailer inside finishing [Re: 6PKRTSE] #3280540
01/04/25 07:56 PM
01/04/25 07:56 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
I would choose the walls as the lightest grey I could get, Ceiling white, and floor a light grey, all satin (tiny sheen to make any cleaning easier)
Sidewalls white will start to show a lot of fingerprints IMO at some point.
Floor would be oil-based 2 part epoxy on my trailer, the walls/sides not as critical.
I forbid my content here from being learned and used by artificial intelligence systems.
Re: enclosed trailer inside finishing [Re: jcc] #3280550
01/04/25 08:15 PM
01/04/25 08:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Put down a couple of pieces of diamond plate where the tires set. At least the rears. They will pull up anything they set on.
Doug
Re: enclosed trailer inside finishing [Re: dvw] #3280583
01/04/25 11:34 PM
01/04/25 11:34 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Could also bolt down some 4'? pieces of E track that would lift tires mostly off the floor and add some easy additional tie downs, if you could get to them ,with slicks you would need a double row?
Re: enclosed trailer inside finishing [Re: Kiddart] #3280619
01/05/25 10:02 AM
01/05/25 10:02 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
So far these are all some really good ideas.
When you guys did your floors did everyone use oil base on floors and did you mix in sand to add a texture, or a little grip.
Thank you
Kiddart
Re: enclosed trailer inside finishing [Re: Kiddart] #3280636
01/05/25 11:18 AM
01/05/25 11:18 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
WHITE Semi-gloss or even White matt finish I would suggest. Any color gloss will be annoying day or night with too much reflective glare. Doing the walls and ceiling in White semi-gloss or White matt and the floor in a light or medium grey or even matt black makes a good work area inside a trailer.
Re: enclosed trailer inside finishing [Re: A12] #3280643
01/05/25 11:43 AM
01/05/25 11:43 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've worked out of trailers that were white or natural aluminum.
It was surprising how much darker the aluminum interior was.
Generally we didn't have leakers, but the ramp door was usually a bit more slippery than the trailer floor.
Textured surfaces tend to hold more dirt & etc, but a bit of sand in the floor paint helps with footing.
Tread plate works well for tires and - obviously enough - shoes...
Re: enclosed trailer inside finishing [Re: A12] #3280645
01/05/25 11:51 AM
01/05/25 11:51 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
porch/patio floor paint semigloss, indoor/outdoor carpet walls and tire runners, self adhesive black/white floor tiles
click on photo to rotate
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: enclosed trailer inside finishing [Re: 440lebaron] #3280651
01/05/25 12:12 PM
01/05/25 12:12 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
I dont work in mine , Its 100% strictly to haul the car
Mine is a off white walls and ceiling. Unpainted plywood floors
Enjoy life today, It has an expiration date
Re: enclosed trailer inside finishing [Re: gtx6970] #3280665
01/05/25 12:34 PM
01/05/25 12:34 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Gloss white barn enamel, at least for the walls and ceiling.
Yes, it takes hours to dry.
It is very easy to wipe down, very durable and keeps things bright.
Valspar makes (made?) a durable marine paint that is non-slip. Not sure how it might hold up to automotive fluids (leaks). But as other's have mentioned, add some sand to your paint to make a homemade non-slip pint.
Re: enclosed trailer inside finishing [Re: Sniper] #3280678
01/05/25 12:52 PM
01/05/25 12:52 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
My experience with sand/grit additives added to floor paints, paint does not do a great job of containing the sand long term, and therefore it is forever wearing off and you always have a bit of loose sand residue on everything, blowing around in a gust of wind, getting in your eye, always on the floor, getting transferred too anything that touches the floor, etc.
Nice idea , but has its downsides IMO.
Re: enclosed trailer inside finishing [Re: jcc] #3280694
01/05/25 01:24 PM
01/05/25 01:24 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Then you did it wrong. Never seen that issue but I only used it in enamel.
Re: enclosed trailer inside finishing [Re: Sniper] #3280699
01/05/25 01:29 PM
01/05/25 01:29 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
What coating containing sand/grit when used, never wears and exposes the additive?
Re: enclosed trailer inside finishing [Re: Kiddart] #3280700
01/05/25 01:30 PM
01/05/25 01:30 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Primed with Kilz, them battleship gray gloss on the floor and gloss white on the walls (oil base) and trusscore for the ceiling. I went with gloss for easy cleanup.
Re: enclosed trailer inside finishing [Re: Mr340] #3280709
01/05/25 01:42 PM
01/05/25 01:42 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Nice, what is the reasoning for the mini ramps?
Re: enclosed trailer inside finishing [Re: jcc] #3280726
01/05/25 02:11 PM
01/05/25 02:11 PM
Midwest
MoparsnMissiles Offline
Midwest
Most likely to get the driver's door up high enough to clear the trailer fenderwell for side door access? Just a WAG.
Re: enclosed trailer inside finishing [Re: jcc] #3280727
01/05/25 02:16 PM
01/05/25 02:16 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
To raise the car up so opening the door clears the escape door.
