71 Charger Front Sway Bar Bushings? #3272858
11/28/24 01:05 AM
11/28/24 01:05 AM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
I ordered a pair of these from Rock Auto after measuring the diameter of my front sway bar - '71 Charger R/T 440 car. The OE sway bar measures 22 mm, so I ordered the bushings for that. They are too small of diameter first of all, plus these will not stay centered - all of them do not have the "humped" contour like the OE bushings - as you can see - they are flat.
Where can I get the correct contour (rubber) that will fit into the OE brackets? See photo of the style I received - this style is all Rock Auto offers - 4 different brands too.
Re: 71 Charger Front Sway Bar Bushings? [Re: Sunroofcuda] #3273228
11/30/24 02:58 PM
11/30/24 02:58 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
I'll suggest contacting Firm Feel and see what they say.
https://www.firmfeel.com/b_body_mopar_parts.html
Re: 71 Charger Front Sway Bar Bushings? [Re: moparmike1] #3273230
11/30/24 03:21 PM
11/30/24 03:21 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I see places that have them with the lips on the sides so they stay put, but so far they are all Poly material instead of rubber.
https://www.kanter.com/products/suspension-stabilizer-bar-bushing-poly55115
Re: 71 Charger Front Sway Bar Bushings? [Re: Neil] #3273231
11/30/24 03:27 PM
11/30/24 03:27 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I wonder if O'Reilly's or Autozone have rubber ones that fit ?
No idea if the rubber meets OEM standards, though.
I guess you could also look for NO$ on Feebay or Amazon.
Re: 71 Charger Front Sway Bar Bushings? [Re: Sunroofcuda] #3273474
12/01/24 10:23 PM
12/01/24 10:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
LINKY
This look like what you're looking for ? IF so do some price shopping wink beer
Re: 71 Charger Front Sway Bar Bushings? [Re: TJP] #3273482
12/01/24 11:06 PM
12/01/24 11:06 PM
Highland, MI.
Highland, MI.
I've seen those - not even close to the right shape however.
Re: 71 Charger Front Sway Bar Bushings? [Re: Sunroofcuda] #3273561
12/02/24 10:35 AM
12/02/24 10:35 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Time just gets away from us
I`m here until I`m not
Re: 71 Charger Front Sway Bar Bushings? [Re: TJP] #3273591
12/02/24 11:47 AM
12/02/24 11:47 AM
moparx Offline
moparx  Offline
Originally Posted by TJP
LINKY
aren't those bushings for the brackets that need cut apart, old bushing removed, new bushing installed, then the bracket is welded back together ? shruggy
beer
Re: 71 Charger Front Sway Bar Bushings? [Re: mopars4ever] #3273719
12/02/24 06:43 PM
12/02/24 06:43 PM
Highland, MI.
Highland, MI.
Originally Posted by mopars4ever
Yeah - that looks more like it.
Re: 71 Charger Front Sway Bar Bushings? [Re: mopars4ever] #3273742
12/02/24 08:58 PM
12/02/24 08:58 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
The Mopar part# according to Bill Meerholz Enterprise is #2535987 who I believe was repoping them at one time, I could never find this part# either in the factory parts manual or any for sale Ebay etc etc,the moog part# K5241 is a poor substitute & supposed to fit many makes & models,an NOS GM bushing part# 3742254 {Ebay} looks like it may be a better substitute check it out.
Re: 71 Charger Front Sway Bar Bushings? [Re: 71GTX471] #3273772
12/02/24 11:17 PM
12/02/24 11:17 PM
Highland, MI.
Highland, MI.
I think I'm looking for 4322580. This is a superceded # from the original part. Martin Kolner (Arizona Parts) is not showing any.
Re: 71 Charger Front Sway Bar Bushings? [Re: Sunroofcuda] #3273782
12/02/24 11:51 PM
12/02/24 11:51 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Re: 71 Charger Front Sway Bar Bushings? [Re: Neil] #3273807
12/03/24 09:37 AM
12/03/24 09:37 AM
md
mopars4ever Offline
mopars4ever  Offline
md
IIRC the sway bar and bushing were serviced together so no bushing number was provided from the factory. Will this work??? https://www.ebay.com/p/12010167728
Re: 71 Charger Front Sway Bar Bushings? [Re: mopars4ever] #3273901
12/03/24 05:39 PM
12/03/24 05:39 PM
Highland, MI.
Highland, MI.
Nope - the bushing does not have the hump in it. Don't be alarmed folks, whenever I start looking for something I need, it always turns into a quest. grin
Re: 71 Charger Front Sway Bar Bushings? [Re: Sunroofcuda] #3273961
12/03/24 11:11 PM
12/03/24 11:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
got a pic of what your looking for?
Re: 71 Charger Front Sway Bar Bushings? [Re: TJP] #3273984
12/04/24 05:28 AM
12/04/24 05:28 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Once you verify correct bushings buy many of them. They will be made of an inferior rubber and most likely dry rot after a few years even though they're not exposed to sunlight.
Keep old mopars alive.
Re: 71 Charger Front Sway Bar Bushings? [Re: Sunroofcuda] #3274023
12/04/24 10:35 AM
12/04/24 10:35 AM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
A little while back I was searching out original e-body rear sway bar bushings and came across these, took a screenshot for reference but it looks like they're sold now, anyway maybe 2071572 would also work?
Sent you a PM.
