71 Charger Front Sway Bar Bushings?
#3272858
11/28/24 01:05 AM
11/28/24 01:05 AM
Posts: 8,550 Highland, MI.
Sunroofcuda
Highland, MI.
I ordered a pair of these from Rock Auto after measuring the diameter of my front sway bar - '71 Charger R/T 440 car. The OE sway bar measures 22 mm, so I ordered the bushings for that. They are too small of diameter first of all, plus these will not stay centered - all of them do not have the "humped" contour like the OE bushings - as you can see - they are flat.
Where can I get the correct contour (rubber) that will fit into the OE brackets? See photo of the style I received - this style is all Rock Auto offers - 4 different brands too.
Re: 71 Charger Front Sway Bar Bushings?
[Re: TJP]
#3273482
12/01/24 11:06 PM
12/01/24 11:06 PM
Sunroofcuda
Highland, MI.
I've seen those - not even close to the right shape however.
[Re: TJP]
#3273591
12/02/24 11:47 AM
12/02/24 11:47 AM
Posts: 20,742 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
[Re: mopars4ever]
#3273742
12/02/24 08:58 PM
12/02/24 08:58 PM
Posts: 1,909 Harriman NY
71GTX471
Harriman NY
The Mopar part# according to Bill Meerholz Enterprise is #2535987 who I believe was repoping them at one time, I could never find this part# either in the factory parts manual or any for sale Ebay etc etc,the moog part# K5241 is a poor substitute & supposed to fit many makes & models,an NOS GM bushing part# 3742254 {Ebay} looks like it may be a better substitute check it out.
[Re: 71GTX471]
#3273772
12/02/24 11:17 PM
12/02/24 11:17 PM
Sunroofcuda
Highland, MI.
I think I'm looking for 4322580. This is a superceded # from the original part. Martin Kolner (Arizona Parts) is not showing any.
[Re: Neil]
#3273807
12/03/24 09:37 AM
12/03/24 09:37 AM
Posts: 13,769 md
mopars4ever
md
IIRC the sway bar and bushing were serviced together so no bushing number was provided from the factory. Will this work??? https://www.ebay.com/p/12010167728
Time just gets away from us I`m here until I`m not
[Re: Sunroofcuda]
#3273961
12/03/24 11:11 PM
12/03/24 11:11 PM
Posts: 16,141 Omaha Ne
TJP
Omaha Ne
I've seen those - not even close to the right shape however. got a pic of what your looking for?
[Re: TJP]
#3273984
12/04/24 05:28 AM
12/04/24 05:28 AM
Posts: 4,875 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Once you verify correct bushings buy many of them. They will be made of an inferior rubber and most likely dry rot after a few years even though they're not exposed to sunlight.
Keep old mopars alive.
[Re: Sunroofcuda]
#3274023
12/04/24 10:35 AM
12/04/24 10:35 AM
Posts: 1,050 NJ
EV2RTSE
NJ
I think I'm looking for 4322580. This is a superceded # from the original part. Martin Kolner (Arizona Parts) is not showing any. A little while back I was searching out original e-body rear sway bar bushings and came across these, took a screenshot for reference but it looks like they're sold now, anyway maybe 2071572 would also work? Sent you a PM.
[Re: EV2RTSE]
#3274616
12/07/24 12:44 PM
12/07/24 12:44 PM
Sunroofcuda
Highland, MI.
I think I'm looking for 4322580. This is a superceded # from the original part. Martin Kolner (Arizona Parts) is not showing any. A little while back I was searching out original e-body rear sway bar bushings and came across these, took a screenshot for reference but it looks like they're sold now, anyway maybe 2071572 would also work? Sent you a PM. I believe the OEM ones would look just like these - with the little hump at the top. I climbed under the front of the car Wed. night - the night before my eye surgery, & I think they had been changed sometime because they look like the ones posted below. My bar is 7/8" diameter. The ones on there right now are rubber, not poly, and they seem very soft. The brackets look like OE because they have the hump in them - just like the NOS ones shown above (well - the pic did not show in the quoted response from EV2RTSE - see above post). I checked with Marty at Arizona Parts & the hole in them is 1.75". WAAAY too big. I'll probably have to get the ones pictured here in Poly from Energy Suspension. Thanks for all the responses.
