Milodon dual oiling question #3273563
12/02/24 10:40 AM
12/02/24 10:40 AM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Hey all,
I've been trying to search the archives looking for my issue, but not having any luck. What i have is, I can prime the motor and get 65 lbs off the drill then go to fire less then 10lbs.
What I've done is replace the o-rings on the fittings of the pump, since they were junk. I did take the oil pump cover off, to clean and look it over. I've replaced to different degree fitting on the back of the pump since I have motor mounts and try to get a loop so it doesn't drain back.
Looking for ideas anyway
Thanks!
Re: Milodon dual oiling question [Re: Z_Z] #3273565
12/02/24 10:48 AM
12/02/24 10:48 AM
gregsdart Offline
gregsdart  Offline
When you say you only get 10 psi, is that idle? What idle rpm, lifter, rocker gear, block, oil feed to rockers, pushrods?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Milodon dual oiling question [Re: gregsdart] #3273576
12/02/24 11:25 AM
12/02/24 11:25 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
HV pump ?? I had a very similar problem. Swapped in a HV pump body and alls good now.
If you have a dual line the oil could be draining back through the front line even though you have a loop in the rear one.
Re: Milodon dual oiling question [Re: Stanton] #3273587
12/02/24 11:44 AM
12/02/24 11:44 AM
gregsdart Offline
gregsdart  Offline
Besides pump volume, knowing the rpm your drill runs at when you see 65 psi will help you figure out what you need. If your drill speed is 1800, rhen that represents 3600 rpm engine speed. If you see only 10 psi at an idle of 1200 rpm, that would be a srill speed of only 600 rpm.
Re: Milodon dual oiling question [Re: gregsdart] #3273594
12/02/24 11:54 AM
12/02/24 11:54 AM
gregsdart Offline
gregsdart  Offline
I just looked up the drill speeds of 3/8 corded drills. They go from 2500 to 2800 rpm. If they are bogged down to 2/3 speed, then you are looking at equivelent engine speed of over 3000 to 3600 rpm roughly. Pump speed driven by the drill is half that, or about two to three times what it would be at idle, 1250 to 1400 rpm, normal pump speed at 1200 rpm idle is 600 rpm when driven by the engine.
Re: Milodon dual oiling question [Re: gregsdart] #3273641
12/02/24 01:28 PM
12/02/24 01:28 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Hey Greg, yes pretty much at idle, wouldn't go up much at all with raising the rpm.
Indy Sr heads
Roller cam, Harland Sharpe rockers.
Re: Milodon dual oiling question [Re: Z_Z] #3273646
12/02/24 01:44 PM
12/02/24 01:44 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Indy Sr heads
I had roller lifters that at max lift would expose the bottom of the lifter bore and pour oil out. The engine had good pressure on the drill, but low when running and would climb slowly with rpm.
PS if I recall, I think I had the lifters in wrong, the tie bar was against the block instead of being toward the cam. (it was 20+ years ago)
Without Data, you’re just another guy with an opinion.
Re: Milodon dual oiling question [Re: Z_Z] #3273657
12/02/24 02:36 PM
12/02/24 02:36 PM
an8sec70cuda Offline
Indy Sr heads
Do you have restrictors in the oil lines to the heads? If not, it'll bleed off a lot of pressure w/ those rockers.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Milodon dual oiling question [Re: an8sec70cuda] #3273669
12/02/24 03:06 PM
12/02/24 03:06 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Indy Sr heads
Yes I do
Re: Milodon dual oiling question [Re: Z_Z] #3273764
12/02/24 10:38 PM
12/02/24 10:38 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Pressure will be lower due to the size of the -12 external lines, but is moving more volume of oil at lower pressures.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Milodon dual oiling question [Re: 6PKRTSE] #3273776
12/02/24 11:31 PM
12/02/24 11:31 PM
gregsdart Offline
gregsdart  Offline
I kindly disagree. Unless there is leakage by the pump rotors, or an air leak in the pickup lines and fittings, the rotors will draw a full volume of oil, no matter how big the external lines. Atmospheric pressure will see to it.
Re: Milodon dual oiling question [Re: 6PKRTSE] #3273812
12/03/24 10:00 AM
12/03/24 10:00 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Huh ??? Those lines are on the inlet side, what the hell do they have to do with outlet pressure ?!?!?
The statement about the drill speed is important. Its tough to find a drill that turns art 500 rpm. What I do is get the prime with a drill then switch to a speed wrench and turn it by hand. If I can maintain some pressure spinning it by hand then I figure its good to go.
Re: Milodon dual oiling question [Re: Stanton] #3273825
12/03/24 11:05 AM
12/03/24 11:05 AM
A727Tflite Online content
A727Tflite  Online Content
Over 50 years around building engines and never had s problem getting oil pressure with a speed handle and maintaining 50 plus pounds or pressure and back in the day with straight 30 weight oil. No matter external or internal oiling.
That’s with wet pump rotors and a full filter.
Not sure what all is going on with today’s parts. shruggy
Re: Milodon dual oiling question [Re: Z_Z] #3273834
12/03/24 11:33 AM
12/03/24 11:33 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
what roller lifter are you using - are the lifter bores bushed? - I am guessing the lifters are becoming uncovered if you have stock lifter bores
Re: Milodon dual oiling question [Re: Z_Z] #3273870
12/03/24 01:40 PM
12/03/24 01:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Indy Sr heads
Need a little more information. What is the oil pressure at higher engine speeds with the engine running? At 3000, 5000? You've stated it has oil pressure with a drill motor at these speeds. If it does rise with speed? Then the question is what is different when the pump speeds are similar? What parts are moving and opening a leak path internally? If it were me I'd pull the intake and valve covers. Spin the drill while rotating the motor and watch.
Doug
Re: Milodon dual oiling question [Re: dvw] #3273872
12/03/24 01:57 PM
12/03/24 01:57 PM
gregsdart Offline
gregsdart  Offline
Indy Sr heads
Doug
Good idea. Then be sure and have ar least one lifter at max lift, to see if it is uncovering rhe oil galley hole.
Re: Milodon dual oiling question [Re: Stanton] #3273887
12/03/24 03:47 PM
12/03/24 03:47 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Quote
True, sorry for the confusion. I was thinking of my entire oil system. It is all -12 to and from the remote filter mount, to and from the Accusump, to and from the Milodon oil pump and to the external return lines.
Re: Milodon dual oiling question [Re: 6PKRTSE] #3274002
12/04/24 09:00 AM
12/04/24 09:00 AM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Sorry guys for late replies, sorry no clue on drill speed, it's a habor freight that's well over 10 years old.
Is it possible, maybe I put the side cover with the impeller's back in wrong?
The lines feel like the have pressure on them. I will try to prime and spin the motor at the same time.
It's a 21200 milodon pump, I have attached a picture of what the o rings looked like.
Re: Milodon dual oiling question [Re: Z_Z] #3274004
12/04/24 09:11 AM
12/04/24 09:11 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
That’s not a o-ring fitting. Thats a bulkhead fitting, that could b ur problem.
Re: Milodon dual oiling question [Re: Z_Z] #3274006
12/04/24 09:18 AM
12/04/24 09:18 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That o-ring is pretty chewed up. I doubt its your problem but it certainly needs to be addressed. That is the wrong fitting to be using an o-ring on. the fitting should not have threads where the o-ring sits. The threads are whats chewing it up. The pump face looks good - they're usually all chewed up by the rotors.
Quote
I don't see how anyone could do that !!
Quote
Suction lines do not have pressure !!
Quote
Why, it won't make a difference.
Have you had the pan off - any chance the pickup is clogged up?
Please tell me you did not use RTV anywhere in the oil system.
