Re: Milodon dual oiling question
[Re: Z_Z]
#3273565
12/02/24 10:48 AM
12/02/24 10:48 AM
Posts: 10,163 Frostbitefalls MN (Rocky&Bullw...
gregsdart
When you say you only get 10 psi, is that idle? What idle rpm, lifter, rocker gear, block, oil feed to rockers, pushrods?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Stanton]
#3273587
12/02/24 11:44 AM
12/02/24 11:44 AM
gregsdart
HV pump ?? I had a very similar problem. Swapped in a HV pump body and alls good now.
If you have a dual line the oil could be draining back through the front line even though you have a loop in the rear one.
Besides pump volume, knowing the rpm your drill runs at when you see 65 psi will help you figure out what you need. If your drill speed is 1800, rhen that represents 3600 rpm engine speed. If you see only 10 psi at an idle of 1200 rpm, that would be a srill speed of only 600 rpm.
[Re: gregsdart]
#3273594
12/02/24 11:54 AM
12/02/24 11:54 AM
gregsdart
I just looked up the drill speeds of 3/8 corded drills. They go from 2500 to 2800 rpm. If they are bogged down to 2/3 speed, then you are looking at equivelent engine speed of over 3000 to 3600 rpm roughly. Pump speed driven by the drill is half that, or about two to three times what it would be at idle, 1250 to 1400 rpm, normal pump speed at 1200 rpm idle is 600 rpm when driven by the engine.
[Re: gregsdart]
#3273641
12/02/24 01:28 PM
12/02/24 01:28 PM
Posts: 100 western iowa
Z_Z
western iowa
When you say you only get 10 psi, is that idle? What idle rpm, lifter, rocker gear, block, oil feed to rockers, pushrods? Hey Greg, yes pretty much at idle, wouldn't go up much at all with raising the rpm. Indy Sr heads Roller cam, Harland Sharpe rockers.
[Re: Z_Z]
#3273646
12/02/24 01:44 PM
12/02/24 01:44 PM
Posts: 733 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
When you say you only get 10 psi, is that idle? What idle rpm, lifter, rocker gear, block, oil feed to rockers, pushrods? Hey Greg, yes pretty much at idle, wouldn't go up much at all with raising the rpm. Indy Sr heads Roller cam, Harland Sharpe rockers. I had roller lifters that at max lift would expose the bottom of the lifter bore and pour oil out. The engine had good pressure on the drill, but low when running and would climb slowly with rpm. PS if I recall, I think I had the lifters in wrong, the tie bar was against the block instead of being toward the cam. (it was 20+ years ago)
Without Data, you’re just another guy with an opinion.
[Re: Z_Z]
#3273657
12/02/24 02:36 PM
12/02/24 02:36 PM
Posts: 13,581 Marion, South Carolina [><]
an8sec70cuda
When you say you only get 10 psi, is that idle? What idle rpm, lifter, rocker gear, block, oil feed to rockers, pushrods? Hey Greg, yes pretty much at idle, wouldn't go up much at all with raising the rpm. Indy Sr heads Roller cam, Harland Sharpe rockers. Do you have restrictors in the oil lines to the heads? If not, it'll bleed off a lot of pressure w/ those rockers.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3273669
12/02/24 03:06 PM
12/02/24 03:06 PM
Z_Z
western iowa
When you say you only get 10 psi, is that idle? What idle rpm, lifter, rocker gear, block, oil feed to rockers, pushrods? Hey Greg, yes pretty much at idle, wouldn't go up much at all with raising the rpm. Indy Sr heads Roller cam, Harland Sharpe rockers. Do you have restrictors in the oil lines to the heads? If not, it'll bleed off a lot of pressure w/ those rockers. Yes I do
[Re: Z_Z]
#3273764
12/02/24 10:38 PM
12/02/24 10:38 PM
Posts: 4,678 Motor City
6PKRTSE
Motor City
Pressure will be lower due to the size of the -12 external lines, but is moving more volume of oil at lower pressures.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3273776
12/02/24 11:31 PM
12/02/24 11:31 PM
gregsdart
Pressure will be lower due to the size of the -12 external lines, but is moving more volume of oil at lower pressures. I kindly disagree. Unless there is leakage by the pump rotors, or an air leak in the pickup lines and fittings, the rotors will draw a full volume of oil, no matter how big the external lines. Atmospheric pressure will see to it.
[Re: 6PKRTSE]
#3273812
12/03/24 10:00 AM
12/03/24 10:00 AM
Posts: 9,122 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Pressure will be lower due to the size of the -12 external lines, but is moving more volume of oil at lower pressures. Huh ??? Those lines are on the inlet side, what the hell do they have to do with outlet pressure ?!?!? The statement about the drill speed is important. Its tough to find a drill that turns art 500 rpm. What I do is get the prime with a drill then switch to a speed wrench and turn it by hand. If I can maintain some pressure spinning it by hand then I figure its good to go.
[Re: Stanton]
#3273825
12/03/24 11:05 AM
12/03/24 11:05 AM
Posts: 3,219 Michigan
A727Tflite
Over 50 years around building engines and never had s problem getting oil pressure with a speed handle and maintaining 50 plus pounds or pressure and back in the day with straight 30 weight oil. No matter external or internal oiling. That’s with wet pump rotors and a full filter. Not sure what all is going on with today’s parts.
[Re: Z_Z]
#3273870
12/03/24 01:40 PM
12/03/24 01:40 PM
Posts: 10,073 MI, usa
dvw
MI, usa
When you say you only get 10 psi, is that idle? What idle rpm, lifter, rocker gear, block, oil feed to rockers, pushrods? Hey Greg, yes pretty much at idle, wouldn't go up much at all with raising the rpm. Indy Sr heads Roller cam, Harland Sharpe rockers. Need a little more information. What is the oil pressure at higher engine speeds with the engine running? At 3000, 5000? You've stated it has oil pressure with a drill motor at these speeds. If it does rise with speed? Then the question is what is different when the pump speeds are similar? What parts are moving and opening a leak path internally? If it were me I'd pull the intake and valve covers. Spin the drill while rotating the motor and watch. Doug
[Re: dvw]
#3273872
12/03/24 01:57 PM
12/03/24 01:57 PM
gregsdart
When you say you only get 10 psi, is that idle? What idle rpm, lifter, rocker gear, block, oil feed to rockers, pushrods? Hey Greg, yes pretty much at idle, wouldn't go up much at all with raising the rpm. Indy Sr heads Roller cam, Harland Sharpe rockers. Need a little more information. What is the oil pressure at higher engine speeds with the engine running? At 3000, 5000? You've stated it has oil pressure with a drill motor at these speeds. If it does rise with speed? Then the question is what is different when the pump speeds are similar? What parts are moving and opening a leak path internally? If it were me I'd pull the intake and valve covers. Spin the drill while rotating the motor and watch. Doug Good idea. Then be sure and have ar least one lifter at max lift, to see if it is uncovering rhe oil galley hole.
[Re: Stanton]
#3273887
12/03/24 03:47 PM
12/03/24 03:47 PM
6PKRTSE
Motor City
Pressure will be lower due to the size of the -12 external lines, but is moving more volume of oil at lower pressures. Huh ??? Those lines are on the inlet side, what the hell do they have to do with outlet pressure ?!?!? The statement about the drill speed is important. Its tough to find a drill that turns art 500 rpm. What I do is get the prime with a drill then switch to a speed wrench and turn it by hand. If I can maintain some pressure spinning it by hand then I figure its good to go. True, sorry for the confusion. I was thinking of my entire oil system. It is all -12 to and from the remote filter mount, to and from the Accusump, to and from the Milodon oil pump and to the external return lines.
