ForSale / Wanted -Tools/ Equipment/Trailers - 4th Quarter #3260997
09/30/24 05:41 PM
09/30/24 05:41 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: ForSale / Wanted -Tools/ Equipment/Trailers - 4th Quarter [Re: moparts] #3261139
10/01/24 06:37 AM
10/01/24 06:37 AM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
I'm looking for a 16'-18' aluminum open car trailer with an aluminum deck like a Featherlite, R&R or something similar. Not looking for new as my budget is limited and I won't be using it very often. Southeastern Michigan area preferred.
gt340 at yahoo.com
Re: ForSale / Wanted -Tools/ Equipment/Trailers - 4th Quarter [Re: moparts] #3263930
10/13/24 09:37 PM
10/13/24 09:37 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Selling our 1995 Pace Shadow 24' enclosed car trailer. I have owned this trailer since 2002 (22 years - 2nd owner). It has never let me down pulling our 2500#-3500# race cars. Always kept wheel bearings serviced, brakes etc. 5,200# axle's.
It comes with weight distribution hitch and sway control (only used the sway control once as it is not needed).
All exterior/interior lights work.
Trailer is also set up with 110 volt breaker box and outlets with overhead lighting.
Generac 4000 generator included and runs fine but the fuel tank valve is currently plugged, it starts fine with a portable fuel tank.
Tires are Maxxis M8008 E-rated with a 2017 date code and comes with one 2018 date coded spare. I typically get 8-10 years from these tires when sun protected.
Interior could use a fresh coat of paint and one or two of the ceiling panels has dry rot from a leak years ago. Measurement between wheel wells is 81".
I have 25-30 Pictures I can send via Dropbox if any interest.
Looking for $6,800 cash.
Re: ForSale / Wanted -Tools/ Equipment/Trailers - 4th Quarter [Re: moparts] #3266938
10/28/24 05:53 PM
10/28/24 05:53 PM
Nevada
theman440 Offline
theman440  Offline
Nevada
Wanted -
Restrictor plate system for 4500 carburetor (Dominator) - what have you got?
ET Genie - EZ Plate System - Altronics Plate System - Willys ?
2020 Featherlite 4410 24 foot enclosed racecar hauler [Re: moparts] #3268325
11/05/24 02:51 PM
11/05/24 02:51 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
Darn near new, very little use. New today this trailer retails for $54K from Featherlite. Asking $35K willing to assist with delivery.
2020 Featherlite 4410 8.5 x 24 Car / Racing Trailer with rear ramp door
Upgraded with: lined walls & ceiling
upper and lower cabinets
30 Amp motorbase
Aluminum wheels
in addition to the many standard features listed below:
OVERVIEW
Featherlite enclosed bumper pull car trailer Model 4410 offers functionality, durability and value for custom car owners and racers. Featherlite's newest car hauler design features a spread axle, rear spoiler and flat nose. This car trailer, available in lengths of 20', 24' or 28', has a rear ramp and camper door standard to make accessing your cargo easy in this great looking, durable car trailer. While options are more limited on the Model 4410.
HIGHLIGHTS
Lengths of 24'
Width of 8'6"
Flat nose & spread axle design
Aluminum Floor Standard
Rear ramp with cable assist
Inside height of 7'0"
Sleek Rivetless Design
SPECS & FEATURES
Model: 4410
Hitch Type: Bumper pull
Wall to Wall Width: 99" (rear opening width = 94 1/4")
Fender to Fender Width: 82"
Inside Height: 7'0"
Loading Height: 20"
Axles: Two rubber torsion 6000# axles with electric brakes
Tire/Rim: 16" 6-hole silver aluminum wheels with Goodyear ST235/80R16 Load Range E tires (Qty: 4)
Tie Downs: Stainless steel swivel "D" ring tie downs (Qty: 4)
Floor: Smooth extruded aluminum floor
Side Door: 42" heavy-duty 2" double sealed door on curbside
Ramp: Full height & width rear ramp with cable assist, pressure latches, treadplate & vinyl hinge cover
Coupler: 2 5/16" coupler; Crank type jack with wheel
Exterior: White exterior sheets; Flat nose with stainless steel vertical & center panel; Spread axle design with drop skirt and fenderettes; Polished aluminum cast corners
Exterior Lighting: Rear spoiler with load light; Clear LED clearance lights; Slimline LED stop/turn lights (Qty: 4)
Interior Lighting: 6 Surface-mount LED dome lights with switch inside
36" beavertail
Spare tire carrier
2- 14" x 14" crank up roof vents
Skid plate
Custom Winch​
Re: enclosed trailer with living quarters [Re: Swingin70] #3275364
12/10/24 09:44 PM
12/10/24 09:44 PM
birdtracker Offline
birdtracker  Offline
looking for a used 48 ft enclosed trailer with living quarters. Good to excellent condition. Won't be interested in one that looks like a herd of raccoons lived in. PM here. Birdtracker
WTB Crane 1.6:1 BB Rockers [Re: birdtracker] #3277118
12/19/24 01:03 PM
12/19/24 01:03 PM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
Good day
Looking for Crane 1.6:1 BB Rockers. Just need two for mock-up. One RH and One LH.
Please let me know what you gave available and price.
Thank you, John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
