ForSale / Wanted -Tools/ Equipment/Trailers - 4th Quarter
#3260997
09/30/24 05:41 PM
09/30/24 05:41 PM
Posts: 15,685 Norwich CT USA
moparts
Norwich CT USA
Re: ForSale / Wanted -Tools/ Equipment/Trailers - 4th Quarter
[Re: moparts]
#3263930
10/13/24 09:37 PM
10/13/24 09:37 PM
Posts: 2,950 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
Selling our 1995 Pace Shadow 24' enclosed car trailer. I have owned this trailer since 2002 (22 years - 2nd owner). It has never let me down pulling our 2500#-3500# race cars. Always kept wheel bearings serviced, brakes etc. 5,200# axle's.
It comes with weight distribution hitch and sway control (only used the sway control once as it is not needed). All exterior/interior lights work. Trailer is also set up with 110 volt breaker box and outlets with overhead lighting. Generac 4000 generator included and runs fine but the fuel tank valve is currently plugged, it starts fine with a portable fuel tank. Tires are Maxxis M8008 E-rated with a 2017 date code and comes with one 2018 date coded spare. I typically get 8-10 years from these tires when sun protected. Interior could use a fresh coat of paint and one or two of the ceiling panels has dry rot from a leak years ago. Measurement between wheel wells is 81".
I have 25-30 Pictures I can send via Dropbox if any interest.
Looking for $6,800 cash.
2020 Featherlite 4410 24 foot enclosed racecar hauler
[Re: moparts]
#3268325
11/05/24 02:51 PM
11/05/24 02:51 PM
Posts: 139 ca
Swingin70
ca
Darn near new, very little use. New today this trailer retails for $54K from Featherlite. Asking $35K willing to assist with delivery.
2020 Featherlite 4410 8.5 x 24 Car / Racing Trailer with rear ramp door Upgraded with: lined walls & ceiling upper and lower cabinets 30 Amp motorbase Aluminum wheels in addition to the many standard features listed below:
OVERVIEW Featherlite enclosed bumper pull car trailer Model 4410 offers functionality, durability and value for custom car owners and racers. Featherlite's newest car hauler design features a spread axle, rear spoiler and flat nose. This car trailer, available in lengths of 20', 24' or 28', has a rear ramp and camper door standard to make accessing your cargo easy in this great looking, durable car trailer. While options are more limited on the Model 4410.
HIGHLIGHTS Lengths of 24' Width of 8'6" Flat nose & spread axle design Aluminum Floor Standard Rear ramp with cable assist Inside height of 7'0" Sleek Rivetless Design
SPECS & FEATURES Model: 4410 Hitch Type: Bumper pull Wall to Wall Width: 99" (rear opening width = 94 1/4") Fender to Fender Width: 82" Inside Height: 7'0" Loading Height: 20" Axles: Two rubber torsion 6000# axles with electric brakes Tire/Rim: 16" 6-hole silver aluminum wheels with Goodyear ST235/80R16 Load Range E tires (Qty: 4) Tie Downs: Stainless steel swivel "D" ring tie downs (Qty: 4) Floor: Smooth extruded aluminum floor Side Door: 42" heavy-duty 2" double sealed door on curbside Ramp: Full height & width rear ramp with cable assist, pressure latches, treadplate & vinyl hinge cover Coupler: 2 5/16" coupler; Crank type jack with wheel Exterior: White exterior sheets; Flat nose with stainless steel vertical & center panel; Spread axle design with drop skirt and fenderettes; Polished aluminum cast corners Exterior Lighting: Rear spoiler with load light; Clear LED clearance lights; Slimline LED stop/turn lights (Qty: 4) Interior Lighting: 6 Surface-mount LED dome lights with switch inside 36" beavertail Spare tire carrier 2- 14" x 14" crank up roof vents Skid plate Custom Winch​
WTB Crane 1.6:1 BB Rockers
[Re: birdtracker]
#3277118
12/19/24 01:03 PM
12/19/24 01:03 PM
Posts: 219 Illinois
gearhead01
Illinois
Good day
Looking for Crane 1.6:1 BB Rockers. Just need two for mock-up. One RH and One LH.
Please let me know what you gave available and price.
Thank you, John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
