Page 2 of 3 1 2 3
360 Ductile Iron 4 Bolt Main Cap Sets – New [Re: Rocket] #3262289
10/06/24 12:38 PM
10/06/24 12:38 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a few sets of new ductile iron main caps available for 360/5.9 magnum engines. These are Mopar Performance caps. I have sets for both 360. The sets includes the first 4 caps. The center 3 caps are 4 bolt main. These are the same caps that came standard on R3 4 bolt blocks. I have installed these caps on a 340 before by milling off the ends of the center caps to leave them 2 bolt. See pictures for the 3 modified center caps installed on a 340 stroker engine. These caps are more stout than the stock caps and are an excellent upgrade for any high performance build. A line bore will be needed when installing new caps as well as some machining for the thrust bearing on the #3 cap.
Price is $340 shipped per set in the lower 48 states. I will ship internationally for the additional cost.
Email procketrichard@hotmail.com for more information.
Small Block Forged 4.060” Pistons for 3.454” Stroke - New [Re: Rocket] #3262302
10/06/24 01:05 PM
10/06/24 01:05 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of 8 Mopar Performance pistons and wrist pins Mopar part# P4876973 for a 3.454” stroke crankshaft. Specs are 4.060” bore, 1/16, 1/16, 3/16 ring set, 0.984” wrist pin, flat top with ~ 5 cc eyebrows, listed by Mopar as 10.5 compression ratio. Compression height is ~ 1.72” per my measurement.
Price for the set is $480 shipped in the lower 48 states. I will ship internationally for the extra cost.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
4.030" Forged Pistons & pins for 3.79" Stoke Crank [Re: Rocket] #3262303
10/06/24 01:07 PM
10/06/24 01:07 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a set of New BRC 4.030" forged flat top pistons and pins for a 3.79" stroke small block crankshaft. Compression height is ~ 1.57" and the ring lands are 1/16, 1/16 and 3/16. Pins are 0.984”. Approximately 6cc valve reliefs.
These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks with 4.030” finished bores.
Price is $475 shipped in the lower 48 states. I will ship elsewhere for the added cost.
BRC 3.79 P1.JPG (1169 downloads)
BRC 3.79 P2.JPG (1170 downloads)
BRC 3.79 P3.JPG (1169 downloads)
BRC 3.79 P4.JPG (1168 downloads)
Water pump adapter [Re: moparts] #3262375
10/06/24 10:01 PM
10/06/24 10:01 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Chevy water pump to big block Mopar adapter. Don’t remember brand. $125 plus shipping from 70072 PayPal or postal money order
Afco Eliminator front shocks [Re: moparts] #3262377
10/06/24 10:05 PM
10/06/24 10:05 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Afco Eliminator Front Shocks Single Adjustable . Used 1 season before upgrading to double adjustable. $300 plus shipping from 70072. Postal money order or PayPal friends and family
Quicktime RM-6073 [Re: Rocket] #3262451
10/07/24 11:07 AM
10/07/24 11:07 AM
Out of the State of Confusion
blue_stocker Offline
New, in-the-box RM-6073 QuickTime bellhousing for Chrysler big block, using 130T flywheel. All parts included as from the factory, $950 shipped within the continental 48 states. PM me here if interested, thanks.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Quicktime RM-6073 [Re: blue_stocker] #3262491
10/07/24 01:35 PM
10/07/24 01:35 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
For Sale Willy’s adjustable plate throttle stop for 4150 carb , great for index racing $433 now from
Summit asking $300 new price ! $250 price negotiable shipping extra lbvracing@aol.com or pm
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #3262620
10/07/24 09:48 PM
10/07/24 09:48 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Rear trailer tie down brackets for most A, B, or E body vehicles (doesn’t fit the 7 ¼ rear axle). These piggyback onto the bottom of the stock shock plate mounting nuts and then 4 more nuts hold these tie down brackets on. You must have enough extra thread hanging down on the bottom of your U-bolts to fit the ¼” thick tie down bracket and another nut. No disassembly necessary, just slide the brackets over the extra thread on your U-bolts, install the included nuts, tighten them down and you’re done. Takes about 10 minutes to install. These eliminate all the hassles that come with using axle straps. Fits A, B, and E body cars with the standard shock plates like shown in the pictures. $60.00 per pair plus shipping. I also have these available for cars with CalTracs, same price. Made in the USA.
Email mrrandyj@aol.com
Reactor Flywheel [Re: moparts] #3262810
10/08/24 02:22 PM
10/08/24 02:22 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Reactor Products New Old Stock from 2/94. 8 bolt crank to powerglide aluminum flywheel . $100 plus shipping from 70072. Postal money order , PayPal friends and family or add fees
Re: NOS MP 1.6 SB rocker arms [Re: rick4106] #3262887
10/08/24 08:38 PM
10/08/24 08:38 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
NOS Mopar performance 1.6 ratio SB roller rocker arms
1.6 ratio often very effective when used on intake valves.
Made in USA
$315 plus shipping for EIGHT(8) individual rocker arms.
thanks
rapid340@yahoo.com
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: NOS Mopar Performance intake [Re: Rapid340] #3262891
10/08/24 09:00 PM
10/08/24 09:00 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
NOS Mopar Performance intake manifold
I believe this is a large port intake for use with W5 or similar heads. A little dirty but never used,
$585 prefer pickup (NE Ohio)
thanks
rapid340@yahoo.com
R3 timing cover distributor [Re: Rapid340] #3263150
10/10/24 12:11 AM
10/10/24 12:11 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
short deck cover 300 short deck distributor 400
Buyer pays actual shipping. Will show receipt for shipping cost.
Open to reasonable offers
REDUCED!!! $90.00 - Pro 1 Elite Safety Harness [Re: 6PAX] #3263301
10/10/24 08:38 PM
10/10/24 08:38 PM
Indiana
dragracer1 Offline
dragracer1  Offline
Indiana
PRICE REDUCED!!!
Hey ya’ll. I have a new Pro 1 Elite Series 5-point Harness.
I bought them, installed them, then never got the car out of the garage before they expired. This would be PERFECT for cars that do not have to be sfi rated belts.
See the pic on the build options when I ordered them.
SHOW YOUR SUPPORT FOR THE FIGHT AGAINS CANCER!!!
New: $230.00
Mine New: $90.00 (INCLUDES SHIPPING TO LOWER 48)
PM me if interested!!
Re: New (outdated) Pro 1 Elite Safety Harness [Re: dragracer1] #3264167
10/14/24 10:48 PM
10/14/24 10:48 PM
Fort Collins, Colorado
CoDart Offline
CoDart  Offline
Up for sale is a new in box msd gen 3 hemi controller and engine harness so you can run a carb. $700
-440 Edelbrock efi proflo 4 kit. Used 250 miles. Ran excellent. Took off for boosted application. $1600
Zip is 80550.
Please send PM if interested, thank you
aeromotive pro fuel pump [Re: moparts] #3264515
10/16/24 01:08 PM
10/16/24 01:08 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
sold thanks
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
596 Aluminium B1 [Re: 440lebaron] #3266046
10/23/24 02:37 PM
10/23/24 02:37 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
596
Indy block
B1 heads done by BES
Indy R3 cam
Bam lifters
Manley vavle springs
New T&D paired rockers 1.7 ratio
Callies 4.625 crank
Callies ultra rods
Ross pistons
Trend 7/16 .165 pushrods
Koffels RB B1 intake (1 of 7 Made)
C&S 1400 billet aerosol carb
Indy offset dist
Firecore wires
Olson oil pan
Moroso 3 vane vacuum pump
Went 4.64 @146 in dragster all motor
Has been 6.72 @ 199 on Spray
Motor has 45 runs on it since freshening
Any questions please call
Scott Foster
937-538-8027
20,000 firm
Motor in the picture of car attached
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #3266562
10/26/24 05:04 PM
10/26/24 05:04 PM
oak park, il.
dsd70bee Online content
dsd70bee  Online Content
oak park, il.
Mopar Performance 426 HEMI aluminum crossram intake manifold, it was bolted on a engine at one time but never ran $1650.00 (708) 288-2879
parts 10-20-2024 001.JPG (268 downloads)
parts 10-20-2024 002.JPG (268 downloads)
parts 10-20-2024 003.JPG (268 downloads)
parts 10-20-2024 004.JPG (269 downloads)
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #3266727
10/27/24 07:01 PM
10/27/24 07:01 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Used Mopar M1 intake for RB $200.plus shipping. PayPal friends and family or pay fee. Postal money order
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #3266729
10/27/24 07:05 PM
10/27/24 07:05 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
JW BBM to powerglide bellhousing no Sfi sticker. Part#92456 $300 plus shipping PayPal plus fee or postal money order
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #3266732
10/27/24 07:08 PM
10/27/24 07:08 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Mopar RB tach drive race distributor. $200 plus shipping. PayPall plus fee or postal money order
Page 2 of 3 1 2 3
