360 Ductile Iron 4 Bolt Main Cap Sets – New [Re: Rocket] #3262289
10/06/24 12:38 PM
10/06/24 12:38 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a few sets of new ductile iron main caps available for 360/5.9 magnum engines. These are Mopar Performance caps. I have sets for both 360. The sets includes the first 4 caps. The center 3 caps are 4 bolt main. These are the same caps that came standard on R3 4 bolt blocks. I have installed these caps on a 340 before by milling off the ends of the center caps to leave them 2 bolt. See pictures for the 3 modified center caps installed on a 340 stroker engine. These caps are more stout than the stock caps and are an excellent upgrade for any high performance build. A line bore will be needed when installing new caps as well as some machining for the thrust bearing on the #3 cap.
Price is $340 shipped per set in the lower 48 states. I will ship internationally for the additional cost.
Email procketrichard@hotmail.com for more information.
Small Block Forged 4.060” Pistons for 3.454” Stroke - New [Re: Rocket] #3262302
10/06/24 01:05 PM
10/06/24 01:05 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of 8 Mopar Performance pistons and wrist pins Mopar part# P4876973 for a 3.454” stroke crankshaft. Specs are 4.060” bore, 1/16, 1/16, 3/16 ring set, 0.984” wrist pin, flat top with ~ 5 cc eyebrows, listed by Mopar as 10.5 compression ratio. Compression height is ~ 1.72” per my measurement.
Price for the set is $480 shipped in the lower 48 states. I will ship internationally for the extra cost.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
4.030" Forged Pistons & pins for 3.79" Stoke Crank [Re: Rocket] #3262303
10/06/24 01:07 PM
10/06/24 01:07 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a set of New BRC 4.030" forged flat top pistons and pins for a 3.79" stroke small block crankshaft. Compression height is ~ 1.57" and the ring lands are 1/16, 1/16 and 3/16. Pins are 0.984”. Approximately 6cc valve reliefs.
These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks with 4.030” finished bores.
Price is $475 shipped in the lower 48 states. I will ship elsewhere for the added cost.
BRC 3.79 P1.JPG (68 downloads)
BRC 3.79 P2.JPG (68 downloads)
BRC 3.79 P3.JPG (68 downloads)
BRC 3.79 P4.JPG (68 downloads)
Water pump adapter [Re: moparts] #3262375
10/06/24 10:01 PM
10/06/24 10:01 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Chevy water pump to big block Mopar adapter. Don’t remember brand. $125 plus shipping from 70072 PayPal or postal money order
Afco Eliminator front shocks [Re: moparts] #3262377
10/06/24 10:05 PM
10/06/24 10:05 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Afco Eliminator Front Shocks Single Adjustable . Used 1 season before upgrading to double adjustable. $300 plus shipping from 70072. Postal money order or PayPal friends and family
