2004 Durango 5.7 Hemi #3261368
10/02/24 12:43 AM
10/02/24 12:43 AM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
I figured that I'd post some pics of what I'm currently dealing with.
The wife was driving our 2004 Durango last February when the engine decided to go out with a bang. laugh2
I had just put a fresh set of heads on it with new valve seats installed to be proactive with the common valve seat issue.
I can't find an obvious reason why it broke a connecting rod.
No obvious valve contact or hydraulic lock up.
The heads look fine.
I picked up a low mileage (80k) 2008 5.7 to replace it.
It's definitely no fun doing it since the recommended way is to lift the body off the frame to replace the engine.
Since I have a four post lift and not a two post, that ain't happening. laugh2
Re: 2004 Durango 5.7 Hemi [Re: SNK-EYZ] #3261653
10/03/24 10:36 AM
10/03/24 10:36 AM
K
Kiddart Offline
Kiddart  Offline
K
I have a 2004 5.7 block that will need some machine work tht i will sell you on the cheap if it helps you out??
Thank you
Kiddart
Re: 2004 Durango 5.7 Hemi [Re: Kiddart] #3261713
10/03/24 12:38 PM
10/03/24 12:38 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
Thanks, but I already have a 2008 complete low mileage engine that I bought from a buddy. up
Re: 2004 Durango 5.7 Hemi [Re: SNK-EYZ] #3261947
10/04/24 11:31 AM
10/04/24 11:31 AM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
Your intake o rings are bad. Those early durangos had a cowl design that allowed rain water to drip on the engine and it would go in the cylinders thru worn out intake O rings, start the engine after sitting in the rain and BAM! Busted connecting rod exactly like you have pictured right there. This issue got them a reputation as having bad rods but no engine can take a hydo lock. There was a recall or TSB to update the cowling so it would not drip there. Also I would do intake O rings on them as an extra precaution if I had one every 100,000 miles.
The engine is much easier to replace just by pulling the fender liners and intake. Removing the body from the frame is a waste of time and effort.
Re: 2004 Durango 5.7 Hemi [Re: HotRodDave] #3261954
10/04/24 12:21 PM
10/04/24 12:21 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
The o-rings were new, I had just replaced the cylinder heads after have an extra pair redone with new valve seats.
After the new heads were installed I was chasing a random misfire.
Once I replaced the coils it ran fine, for two weeks.
When the rod spit out it hadn't been raining.
It had been running for hours, about 10 minutes into the 25 minutes trip home from her moms it went bang, so it wasn't on a start up after rain.
Re: 2004 Durango 5.7 Hemi [Re: SNK-EYZ] #3271207
11/19/24 06:17 AM
11/19/24 06:17 AM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
My '04 Durango did virtually the same thing in 2015, but it holed the block on BOTH sides. Slowed down to turn a corner, engine seemed to cough and stalled. Popped it in neutral, fired it back up, and drove on, but it had a miss (big surprise). Had it towed home and found the hole similar to yours, and started it to drive into the shop. After I pulled it I found the hole on the other side. Swapped it the traditional way, from the front with no problem.
Re: 2004 Durango 5.7 Hemi [Re: SNK-EYZ] #3271228
11/19/24 08:47 AM
11/19/24 08:47 AM
Quakertown PA
Tay Offline
Tay  Offline
Quakertown PA
seen that a few times, one of the parts engines I bought last year, it was in a 2500 4x4 ram, owner went in to the shop on nice may morning, fired up the old girl , he said after a 5 min warm up it started to shake , he pulled it out of the shop and it shut off. put it up on his lift and found a hole.
Those OEM powder metal rods are a 1 in 1 million is junk thing, my uncle had an OEM crate engine , loaded it up on the dyno, got 7 pulls out of it before a rod windowed the block, My step father has a 690k mile 05 3500 RC dually 4x2 still going strong, .......there's no rhyme or reason as to why it happens , luck of the draw I guess.
