E Body - Cars/ Parts Wanted - 4th Quarter
#3260950
09/30/24 03:37 PM
09/30/24 03:37 PM
Posts: 15,679 Norwich CT USA
moparts
Norwich CT USA
Re: E Body - Cars/ Parts Wanted - 4th Quarter
[Re: FY1 AAR]
#3262429
10/07/24 08:19 AM
10/07/24 08:19 AM
Posts: 1,155 Home of the Bluegrass
MoparJunkie
WTB: 70 Challenger drive shaft.... specifically a 7290 u-joint shaft that is 45.85" PM with what you have. TIA
"It takes a Mopar to catch a Mopar” 1970 Challenger T/A 4 speed EV2
E Body - Parts Wanted
[Re: moparts]
#3265787
10/22/24 09:44 AM
10/22/24 09:44 AM
Posts: 141 Central Pa.
Cloned_Cuda
Central Pa.
Looking for the following parts that are clean and basically ready to go:
Door Latches 70-72
70 Cuda Standard Gage Bezel and Switch Bezel.
70 Cuda Door Glass both sides - Non Tinted within 5-6 hours driving distance from Central PA.
PM me here.
Thanks Moparts
[Re: moparts]
#3267676
11/01/24 08:35 PM
11/01/24 08:35 PM
Posts: 3,626 Millinocket, Maine
JonC
Millinocket, Maine
I need a used black upper seat cover for the drivers seat on 72 cuda, I want a used one to match my original covers. I don't want a new one because it may look funny.
11B40
[Re: moparts]
#3272345
11/25/24 03:21 PM
11/25/24 03:21 PM
Posts: 1,248 San Ramon, CA.
Topcat
San Ramon, CA.
I need some help! My 71’ Motorola AM/FM is being restored by Brent Ball, Classic Radio Restoration in Ontario and I need some help for this particular gear inside of it. Here is what Brent e-mailed me today: Your main tuning mechanism gear has some missing teeth (unfortunately not super uncommon as this old plastic sometimes has weak areas and defects)
Anyway, I have tried to find parts from the few hundred radios I have here and I have got nothing.. I had a c body radio that I thought would do it, but as you can see in the picture the C body is close but different and I can't even remove parts from it to use as the bevel cut on the gear is different anyway.
Yours has the SHORT aluminum shaft and the C body I was hoping to use has a long alumimum shaft and the gear tooth cut is wrong. I have not parts and I can't find anything from any of my other radios. I have looked for three hours, taking covers off of various radios, hoping. To make the problem worse Chrysler used Motorola AND Philco radio mechanisms. Technically 70 used Philco and 71 used motorola. I have a 70 philco C body radio here for potentially using parts but its completely different and thus was disappointing.
So basically I need a gear from a 71 AM FM MOTOROLA E body radio. I can't find one, and I don't see any used radios on ebay.
Re: E Body - Cars/ Parts Wanted - Radiator side bracket
[Re: musclecarman15]
#3272497
11/26/24 01:00 PM
11/26/24 01:00 PM
Posts: 16 Illinois, USA
dodgerebellion66
Illinois, USA
Hello everyone,
Looking for a RH radiator side bracket (or complete radiator if need be) for a 1970 challenger with a 26" radiator and a late '69 date code or early '70.
Car build date is 3/23.
PM here or call or text 815-790-1974
Thanks Rich
1966 Coronet 500 1967 Coronet R/T 1974 Cuda 1970 Challenger R/T 1970 Challenger T/A
[Re: Erik]
#3273820
12/03/24 10:21 AM
12/03/24 10:21 AM
Posts: 129 Middletown, De
mjb765
Middletown, De
UPDATE---I FOUND THEM
Need a set of A/C vents for a 1970 Cuda. Center and right side.
