Trans crossmember swap?? #325301
05/22/09 12:04 AM
05/22/09 12:04 AM
Sunny So. Cal.
mopar68 Offline OP
mopar68  Offline OP
Sunny So. Cal.
I'm looking to swap out my crossmember (68 charger) from the tall block style mount to the through bolt spool type mount (better design right?). What years/models should I be looking for to swap out? Thanks
Re: Trans crossmember swap?? [Re: mopar68] #325302
05/22/09 10:21 AM
05/22/09 10:21 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
There are no stock crossmembers that will work. It will have to be a custom piece.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Trans crossmember swap?? [Re: mopar68] #325303
05/22/09 11:01 AM
05/22/09 11:01 AM
Indiana
P
Pentastar440 Offline
P
Indiana
I used the newer type transmission mount on my '65 Belvedere. I went to the junk yard and got the cross member from a car that used that style mount. I think I got one from a Cordoba , a Diplomat or 5th Avenue would work too. Then I cut out the center part of the cross member. Then I took the mount with the bolt through it and bolted it to the transmission with the new center part bolted to it. Then I took the '65 cross member (which was in two pieces now after removing the center section)and bolted it to the frame. Then while the transmission was supported by a jack , I located the transmission where I wanted it. Then I tack welded the new center section to the original cross member. I then removed the cross member and finished welding it. Then I painted it black and put in back in and bolted it up. When finished it looks like an original '65 cross member but it has the spool type mount. Has worked great for 10 years now.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Trans crossmember swap?? [Re: Pentastar440] #325304
05/22/09 07:54 PM
05/22/09 07:54 PM
Sunny So. Cal.
mopar68 Offline OP
mopar68  Offline OP
Sunny So. Cal.
Ahh nuts!!! I thought for sure at least a 69 charger would fit. I thought I'd seen some 69's with the spool type and others with the block style.
Re: Trans crossmember swap?? [Re: mopar68] #325305
05/22/09 09:47 PM
05/22/09 09:47 PM
Indiana
P
P
Indiana
It's an easy modification , go for it.
Re: Trans crossmember swap?? [Re: 64dodge572] #325306
05/22/09 10:27 PM
05/22/09 10:27 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Did 70 B's have a spool mount?
So a 71 B/E body trans crossmember won't fit a 66-69 B-body.
Off topic but FWIW, A 73-76 A-body spool mounts will fit a 67-72 A-body.
Re: Trans crossmember swap?? [Re: autoxcuda] #325307
05/23/09 11:19 AM
05/23/09 11:19 AM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Putting mine in today.
Re: Trans crossmember swap?? [Re: RokketRide] #325308
05/23/09 01:14 PM
05/23/09 01:14 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I have a poly mount in my 69 RR. I've been happy with it so far. No cutting and more secure than the rubber mount.
I want my fair share
