For Sale - Truck / Van / Jeep Vehicles - 3rd Quarter #3241578
06/30/24 07:41 PM
06/30/24 07:41 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Truck / Van / Jeep Vehicles - 3rd Quarter [Re: moparts] #3242594
07/05/24 06:07 PM
07/05/24 06:07 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
1978 Dodge D150 Pick-up truck. 318 engine with an automatic transmission. 2 wheel drive. 8 foot bed with a topper. Red with white on the sides. It has that popular "patina" look.. 90% original. Some minor rust, but it is very solid for an unrestored 46 year old truck. I can text or e-mail pictures of the truck and provide the contact info for the owner. (It is NOT my truck) $3,500 The truck is located in central West Virginia.
Re: For Sale - Truck / Van / Jeep Vehicles - 3rd Quarter [Re: moparts] #3243180
07/09/24 10:28 AM
07/09/24 10:28 AM
Boostdbelv Offline
Boostdbelv  Offline
2019 Ram 1500 Rebel 5.7L Hemi
64k miles and counting since i still drive it everyday.
TRX wheels and tires were put on last fall and have 8000 miles on them (tire light is on due to pressure requirement difference from the stock wheels and tires which can be removed).
Truck is maintained very well with zero issues.
Cosmetically and mechanically this truck is perfect.
Asking $38500 obo
Thanks moparts for the ad!
67 Belvedere II In process
1975 D-700 Dump Truck [Re: 938-DAN] #3247030
07/24/24 02:34 PM
07/24/24 02:34 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
1975 D-700 Dump Truck, Max G.V.W. 25,500, 84.082 Miles, Very Solid w/No Rust, Some Light Dents, 5-Speed w/2 Speed Axle, 361Big Block, Heads Have Had A Valve Job Recently, New Water Pump, New Starter, Dual Exhaust, Runs and Drives Great $7500 P.M. or Text (563) 605-0907
1978 Dodge Little Red Express Truck [Re: old340dog] #3249967
08/07/24 06:30 AM
08/07/24 06:30 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Unfortunately I have reached the age where I have to start downsizing the number of Mopar Project vehicles I have and pass on some of them to other people. I am starting to have to make the hard decisions,one of which is my 1978 Little Red Express truck. It is a the most desirable of the these models with only 2188 ever produced, It is one of only 185 built with air conditioning. The truck has 62,000 original miles and has never been apart. It has the original E58 Police spec 360 engine with the 68 340 spec camshaft,double roller timing chain,and 800 cfm Thermoquad Fireball carb. These were the fastest American production vehicles built in 1978. The truck is complete and very solid. It does run,but has been sitting a few years and would need to be gone through to make a driver out of. It has patina if that is your thing,or restore to as new condition if you so desire. It had the complete exhaust system replaced about 5 years ago and was never driven since. The only real rust on the truck is the bottom front corner of each door,and I have two NOS doors for the truck. I also have brand new oak wood for the sides of the bed and tailgate. I have two sets of Little Red Express wheels and 4 of the original tires these came with,three are in great condition,one has wear on the tread. I have four new centercaps and a replacement windshield too. This is the rarest combination made being red with red interior. Rhode Island does not issue titles for vehicles over ten years old,so the truck will be sold with a current registration in my name and a bill of sale. This documentation should be sufficient to apply for a title in your state if needed. It's a good solid truck.. The truck is sold.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
2004.5 Cummins Dually for sale [Re: chargervert] #3250746
08/11/24 12:08 PM
08/11/24 12:08 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I've owned this truck since new, only 1 driver[ me]. Back seat has hardly been used. Since its an 04.5, there are no truck stopping emissions equipment problems like the 07.5 and newer ones. The truck has only been used as a work horse for maybe 5% of its odometer reading, the rest is just being a daily driver. It's never been wrecked, although I did back into a tree limb and damaged the tailgate. I've done many longevity, tow and performance upgrades to it. It has 7 forged aluminum wheels, B&W turnover ball gooseneck hitch with 5th wheel companion unit[ both never used], Airdog lift pump and filter unit, has been run on Amsoil lubricants its entire life, Zoom ZVT clutch, Bosch Motorsports 50hp injectors, Garrett stage 2 water cooled turbo, Mag Hyteck diff cover, Smarty programmer, factory accessory Jake Brake since new, Rhino Liner, home done cold air intake, custom back up lights in rear bumper, Cooper tires with lots of life, bed mat, Alpine CD player, LED Headlight bulb conversion in new housings, have the factory service manuals[4],
some spare items. Truck needs to have the gate repaired plus total repaint of truck, has a weeping front crank seal, rear pinion seal leaking[ have a new factory one], HVAC doors need to be replaced[ known issue with these trucks, otherwise system works fine], fuel tank has a leak when full[ must drop tank out or take bed off to fix], interior is great other than showing age with faded carpet and some stains, dash is awesome since its been covered since new. $18,000.00 OBO. PM me here if interested. Truck is in Los Osos, Ca. 93402. I accept cash or USPS money order.
Carl Kessel
1999 Dodge Dakota R/T 5.9 Magnum [Re: moparts] #3255450
09/02/24 09:30 PM
09/02/24 09:30 PM
Bristol, CT
RalphsRapidTrnst Offline
Bristol, CT
For Sale 1999 Dodge Dakota R/T 5.9 360 Magnum, Factory 3.91 Gears. Automatic. 111000 Miles Restoration completed last Summer. Original Solar Yellow in Color. Interior is very nice, Console has no issues. 5 Original Powder Coated Wheels with brand new General Tires. Engine bay is clean, New Bumpers, Grill, Windshield, Taillights, Headlights parking lights and fog. Class 5 Hitch with electric brake controller and Backup Camera. Runs great, Looks amazing. have over 15K in receipts, Asking 12,000.00 Or Trade for a Fox Body 1986 or newer Mustang 5.0 or Cool Mopar. No Motorcycle's Please Ralph 8604One1One22Eight.
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: For Sale - Truck / Van / Jeep Vehicles - 3rd Quarter [Re: moparts] #3255622
09/03/24 05:22 PM
09/03/24 05:22 PM
NORTH ATTLEBORO
Billy Offline
Billy  Offline
NORTH ATTLEBORO
1985 Dodge single cab 8ft bed 2-wheel drive, 6 cyl, straight slant 6, automatic. Garaged most of its life, frame is in excellent condition. Drivers side bed has large dent, does not affect driveability. Many new parts....Tires,wheels, exhaust, brakes and brake lines, battery. Everything else works and passes MA inspection no problem. 88,500 original miles. Used daily. Fuel gage and radio not working. $5,800 or BO. Serious inquiries only please. I can email more pictures. 508-344-9600, pbbowness@yahoo.com
85Dodgedrivers side.jpg (88 downloads)
