Front wheel wiggle #3242858
07/07/24 04:35 PM
07/07/24 04:35 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I mounted the front wheels/tires on my Dart and after tightening the lug nuts I noticed there is a very slight wiggle if I grab the tire and try to rock it. New wheels torqued to spec. and all new wheel bearings. I tightened the spindle nut to spec. and then backed it off and hand tightened it as per the manual. Is a slight wiggle typical or is something wrong?
Re: Front wheel wiggle [Re: 6PAX] #3242860
07/07/24 04:46 PM
07/07/24 04:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would try snugging the spindle nut a little.
Re: Front wheel wiggle [Re: 6PAX] #3242865
07/07/24 05:10 PM
07/07/24 05:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Take the dust cap off of the drum and rock the tire...you'll see if the wiggle is is at the spindle.
Re: Front wheel wiggle [Re: stumpy] #3242866
07/07/24 05:13 PM
07/07/24 05:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
What type of wheels and lug nuts?
It's possible when using shank style lug nuts that are too long they bottom out before they contact the wheel like they are supposed to.
Re: Front wheel wiggle [Re: Neil] #3242873
07/07/24 05:38 PM
07/07/24 05:38 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
The wheels are Torq Thrusts with conical nuts. Forgot to mention, both sides wiggle the same way. You can just barely feel it. As suggested, I'll pull the dust cap off and try wiggling it again and I will also tighten the nut a little tighter although it will be with a socket as I have it as tight as I can get it by hand.
Re: Front wheel wiggle [Re: 6PAX] #3242875
07/07/24 06:04 PM
07/07/24 06:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Same wheels as before ? Any interference/clearance issues @ hub or caliper or upper arm ?
Finger tight on bearings isn't enough, if I'm interpreting the post correctly - I usually use a big crescent wrench - but wheel/tire should spin pretty freely when nut is tightened.
Re: Front wheel wiggle [Re: topside] #3242878
07/07/24 06:56 PM
07/07/24 06:56 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Spindle nuts set up per the book on older vehicles may have some wiggle left over, but it's just barely perceptible, and should not make any noise. If you have a totally obvious clunk clunk thing going on then something is not right.
Last part of the 3rd paragraph.
https://brakeperformance.com/wheel-bearing-service1.php#
Re: Front wheel wiggle [Re: topside] #3242899
07/07/24 09:10 PM
07/07/24 09:10 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
None of it is as before. I converted from the original sbp drum brakes to the later lbp disks. The wheels are new, never been on the car before. No interference/clearance issues whatsoever. I just did the finger tight thing because that was what the service manual said to do.
Re: Front wheel wiggle [Re: 6PAX] #3242918
07/07/24 11:08 PM
07/07/24 11:08 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Maybe the a body is different, but for a b and e you are supposed to torque to an inch pounds spec and then loosen one key way. Or tighten by feel as many do. I find the spec way to leave a barely perceptible wiggle and I like it a bit tighter than that.
I want my fair share
Re: Front wheel wiggle [Re: 6PAX] #3242968
07/08/24 07:40 AM
07/08/24 07:40 AM
E
earlymopar Offline
earlymopar  Offline
E
If both wheels have back and forth "slop", check the tie rod ends and steering box adjustment.
Re: Front wheel wiggle [Re: earlymopar] #3242982
07/08/24 09:31 AM
07/08/24 09:31 AM
K
Kiddart Offline
Kiddart  Offline
K
one thing that i aways did wrong was not spinning the rotor while you tighten, I was told this seats the needle bearings properly. everything else i did correct. i think i went to 70 inch pounds then back off one key on the nut cover for the cotterpin.
Thank you
Kiddart
