Re: Front wheel wiggle
[Re: 6PAX]
#3242865
07/07/24 05:10 PM
07/07/24 05:10 PM
Posts: 26,384 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Take the dust cap off of the drum and rock the tire...you'll see if the wiggle is is at the spindle.
[Re: topside]
#3242878
07/07/24 06:56 PM
07/07/24 06:56 PM
Posts: 21,162 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Spindle nuts set up per the book on older vehicles may have some wiggle left over, but it's just barely perceptible, and should not make any noise. If you have a totally obvious clunk clunk thing going on then something is not right. Last part of the 3rd paragraph. https://brakeperformance.com/wheel-bearing-service1.php#
[Re: topside]
#3242899
07/07/24 09:10 PM
07/07/24 09:10 PM
Posts: 5,723 Detroit area
6PAX
Detroit area
Same wheels as before ? Any interference/clearance issues @ hub or caliper or upper arm ?
Finger tight on bearings isn't enough, if I'm interpreting the post correctly - I usually use a big crescent wrench - but wheel/tire should spin pretty freely when nut is tightened. None of it is as before. I converted from the original sbp drum brakes to the later lbp disks. The wheels are new, never been on the car before. No interference/clearance issues whatsoever. I just did the finger tight thing because that was what the service manual said to do.
[Re: 6PAX]
#3242918
07/07/24 11:08 PM
07/07/24 11:08 PM
Posts: 10,279 Someplace you aren't
SomeCarGuy
Maybe the a body is different, but for a b and e you are supposed to torque to an inch pounds spec and then loosen one key way. Or tighten by feel as many do. I find the spec way to leave a barely perceptible wiggle and I like it a bit tighter than that.
I want my fair share
[Re: earlymopar]
#3242982
07/08/24 09:31 AM
07/08/24 09:31 AM
Posts: 1,573 Michigan
Kiddart
one thing that i aways did wrong was not spinning the rotor while you tighten, I was told this seats the needle bearings properly. everything else i did correct. i think i went to 70 inch pounds then back off one key on the nut cover for the cotterpin.
Thank you Kiddart
