1967 Barracuda Formula S 383
[Re: moparts]
#3241629
06/30/24 10:53 PM
06/30/24 10:53 PM
Posts: 1,014 Central US
grancuda
Central US
1967 Plymouth Barracuda Formula S 383/Auto Fastback 383 Commando V8/727 car Factory Red exterior/Black interior
SOLD
1967 Barracuda Formula S FB 383/727 1967 Chevy C10 Short Stepper LS1/TKO 600/7675 Precision 1979 Ford F150 LWB 300 / 4 speed 1996 Toyota Land Cruiser 2024 Ford Bronco Badlands Sasquatch 2022 Kawasaki Z900RS
1971 Demon 340
[Re: moparts]
#3241887
07/02/24 09:22 AM
07/02/24 09:22 AM
Posts: 13,514 Marion, South Carolina [><]
an8sec70cuda
SOLD
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
1968 Valiant 2dr Sedan Drag Car Project $9,500
[Re: an8sec70cuda]
#3244489
07/14/24 06:03 PM
07/14/24 06:03 PM
Posts: 1,537 AZ
Mike P
AZ
1968 Plymouth Valiant 2 door sedan street/strip Big Block project. (Pictures are recent) $9,500. This is a package deal ONLY, I will not sell parts individually. I bought this car to use as a parts car/mock-up car for converting another 68 Valiant drag car back to a street car. I am done with the mock-up phase and no longer have use for the red Valiant or the parts I am listing. The car and parts are a good start for putting together an 11 second drag car. First 7 digits of the VIN are VL21A8E. I have a clean Arizona title in my name, VIN tag is present and attached with original rivets, it matches the title. Sale does NOT include the green car or the red hood. This car is a roller. Body: The body is solid and straight with the exception of the rusty front floors and 3 small rust holes in passenger side rocker.. Some minor body work was started on the car. Replacement front floor pans have been temporarily installed in the car and are included. There is no gauge cluster in the car but I am including a sheet of flat stock to fabricate a gauge panel from. This was originally a slant 6 car. All the glass is good. Hood is steel with a fiberglass 6 pack style hood scoop. This is a small bolt pattern car with a set of 4 SBP rally wheels. The car comes with a pair of aftermarket tubular upper control arms, spindles, 5 on 4 ½” rotors, calipers, and braided brake lines (not installed). Also included is an 8 ¾ rear axle housing (54” flange to flange (65-67 B body ?)), axles (5 on 4 ½” BC) and backing plates for 10” X 2 ½” brakes. The big block K member is set up for spool mounts (mounts and brackets included). This is the same K member the engine was attached to in the drag car. K member is now installed in the car that is for sale. Included on the K Member is an aluminum manual steering box. The transmission tunnel accepts the 727 and has also been enlarged to accept a 46RH/RE transmission. The piece of the crossmember that was cut out is included and can be welded back in or the crossmember can be reinforced and used with a 500/518 overdrive transmission. Sale includes the engine (complete air filter to oil pan). 727 Torqueflite transmission with 3000 stall convertor. Stainless headers (with welded O2 sensor bung) and 3” exhaust with Flowmaster mufflers. 20 gallon aluminum fuel cell with Holley in tank pump and wiring harness. Autometer 5” tach and mechanical oil and temperature gauges. Original bench seats, 1 aluminum JAZ racing seat, cover and racing harness. Wiring to relocate battery to the trunk. Motor mounts and brackets, factory heater. Bolt on aluminum driveshaft safety loop. Transmission cooler and kick-down linkage. Alternator and high torque starter. Spare pair of 6 cyl torsion bars (the ones that came out of the race car). When I bought the drag car, a Holley Terminator X fuel injection unit was included with the sale. The wiring was installed in the car. I do no know if the unit was actually used (the 850 Holley double pumper was on the car when I bought it) it appears to be complete. It is included with the sale of the car. Engine: I bought the race car to re-motor, so only took a short test drive. As I have not torn the engine down I cannot personally verify the previous owners’ claims. The engine ran strong with no unusual noises. Quoted is the description provided by the previous owner is his ad to sell the race car. “….508 big block…. Pump gas stroker motor with 10 to 1 compression ….. approx 550hp…… Ran a 1.55 60ft and went 7.3 in the eighth, high 11's in the quarter mile….. On the street cruising it runs 180 to 190 water temps…...Only 4 passes made at Barona 1/8 mile in San Diego and a dozen passes at Tucson Dragway….” (I have seen the 11.9 time slip from Tucson dragway). I believe the engine was built with a 440 Source stroker kit but I cannot verify this or the displacement. Things I have verified: 440 block “440 Source” stealth aluminum heads Aftermarket push rods Adjustable rocker arms (possibly indicating a solid lifter cam ?) ARP head bolts Mopar Wedge dual plane intake (P5153525)* Aluminum water pump housing Aluminum water pump Holley 82851 850 CFM double-pumper carb Mopar electronic distributor Deep sump oil pan *A check of availability for this manifold shows it as back order from all the sources I checked. A short You Tube video of the engine running prior to removal is located at: https://www.youtube.com/watch?v=gavwtIuX9pATransmission: 727 with 3000 RPM stall convertor. It does have a standard shift pattern valve body and TCI aluminum pan. The transmission shifted well and all gears engaged. Located in southern Arizona (85616). Car and parts are being sold as is where is. More pictures can be seen in my Tucson Craigslist ad: https://tucson.craigslist.org/cto/d/huachuca-city-1968-plymouth-valiant/7766193987.htmlFront ¾ Z R34 by M Patterson, on Flickr Passenger side Z R1 by M Patterson, on Flickr Drivers side Zl by M Patterson, on Flickr Passenger side rocker Z R by M Patterson, on Flickr
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 1968 Valiant 2dr Sedan Drag Car Project
[Re: Mike P]
#3245222
07/17/24 10:57 AM
07/17/24 10:57 AM
Posts: 340 Northport, al.
tvt59
Northport, al.
1968 Plymouth Valiant · Sedan · Driven 60,000 miles. I'm in Tuscaloosa, Al The car is at Laverne Ferrouillat's shop in Moblie, Al
I have a 68' Valiant 2 door project that I've been working on for a few years. Lots of high dollar parts. I'm a motivated seller. I just need a sell it and move on. All reasonable offers considered. PM me your questions and offers.
All metal replaced as needed. Most body work done. Hemi Denny Tubular front suspension, Freak Ride 4 link rear suspension. Quick Time SBM to T56 Magnum transmission bellhousing. Two disk clutch, hydraulic master cylinder and throw out bearing, New T 56 Magnum transmission, wilwood 6 piston front brakes and 4 piston rear brakes, areomotive 15 gallon stainless steel fuel cell with internal A1000 pump, new dr diff Dana 60, new aftermarket bucket seats, all new speed hut gauges, new dry nitrous system, the following can go with the car but the price will go up substantially, fresh 440" SBM W5 engine with 48 deg R3 block. Dyno'd 644 hp. Complete with all sensors and wiring harness Holley Dominator EFI system.
I also have a pretty much complete parts car. it's a 1969 2 door Valiant, 6 cylinder , manual trans, a/c car. That goes in the deal
I'm reposting. I need to sell this car, so I can get started on my 2000 Dakota race truck. I initially listed it for $10,000 which is less than 20% of the cost of the parts in the car. Shoot me an offer. I'll accept anything realistic .
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
Very clean 1967 Dart street strip car
[Re: moparts]
#3246267
07/21/24 03:57 PM
07/21/24 03:57 PM
Posts: 4,297 Florida
blewbyu
I have decided to part with my very nice 67 Dart. Everything works and fully street legal. I street drive it all the time. It’s a 512 tall deck all motor no spray with reverse 727 manual valve body and 8 3/4 ladder bar with 4.10. Super solid original body panel car. Stock looking interior minus back seat. Do have light weight Hemi fiberglass hood also along with cowl hood. Car has run a best of 10:80 Not a fire sale but looking to build something else. No trades $37,500
blewbyu2bad@aol.com
1969 barracuda
[Re: moparts]
#3247048
07/24/24 03:49 PM
07/24/24 03:49 PM
Posts: 3,107 old westchester
mcat4321
old westchester
beautiful 1969 Plymouth barracuda. fresh 318 w/ 4 brl, Edelbrock carb.and intake, headers and cold A/C, champion 4 core aluminum radiator runs cool always. doesn't leak a drop of anything. fresh 904 transmission shifts good recent rebuild, and 8-3/4 rearend, 3.23 gear new factory shifter in console. front disc manual brakes with. new lines and hardware. new 16.1 manual steering gear front and rear sway bars, rebuilt front suspension newer torsion bars. complete new fuel system, tank, sender, lines and pump. New mufflers and dual exhaust. all gauges are new and work flawless. all lights work even the key buzzer. ZERO rust... perfect floors and frame. great paint and interior new headliner and recovered seats, all glass is good this is a really nice car! great for cruising it needs nothing. best handling mopar i have owned IT IS NOT A 100 POINT SHOW CAR its a damn nice car you can enjoy and not worry about. i would take it cross country in a minute... i found another car i want , so this one goes. it is located in Cincinnati Ohio. my asking price includes shipping in the lower 48 $36,500 shipped to your door. partial trades possible but doubtful e-mail mcat4321@yahoo.com
1970 Duster
[Re: mcat4321]
#3247980
07/28/24 09:28 PM
07/28/24 09:28 PM
Posts: 779 Washougal,Wa
Dodge
Washougal,Wa
Selling the odd duck 🤪.1970 EV2 duster project. 318, 3 on the tree. Has an auto in it now. Buckets, PS, 8 3/4. Has fender tag/ build sheet/ title 😁. $4250
Stand behind your word
Re: 1970 Duster
[Re: Dodge]
#3252044
08/17/24 12:44 PM
08/17/24 12:44 PM
Posts: 12,481 Taxes & Virus's R-US, NY
Dragula
Asking $38,000 (716) 830-1258 or PM here or email me at Dragula426@gmail.com
I have owned this car since 2013 and its gone thru many upgrades and with my now known health issue, I am not dealing with any BS. I am pretty attached to the car, but I damn near died this week.....So don't be a jerk if you call or email me. Not dealing with it. Spent the week in the hospital. I do not need to sell the car, but to have the cash if needed if my health changes for the worse.
It won the Gasser Racing series in 2013 with three class wins to take the over all title. Car is a proven winner and it works well.
The car: Rear suspension is a 4-link with sway bar Coil over single adjustable 16.5x33 slicks (brand new) Dana 60 with 4.56 gears & spool & pre-load cover 10 Gal plastic fuel cell Magna 500 fuel pump & Filter Full cage with outdated cert Window net Full frame connectors cut into the floor and fully welded Aluminum dash Kirkey seat Front suspension is MagnumForce Viking Double coil overs on front no inner fenders Full steel fire wall Fiberglass hood, trunk, bumpers Lexan windows front and rear Glass roll up windows in the doors Car weighs 2753 lbs fully loaded Inner door panels aluminum Most aluminum, including dash covered in carbon fiber wrap Holley stand alone dash with many sensors Willwood brakes all corners
The engine: (brand new, not even broke in yet) 400, 512 stroker from 440Source with girdle and light weight crank ARP2000 rod bolts 1050 Holley carb Indy big valve EZ1 heads fully ported Moral Lifters Comp/T&D 1.5 rockers Indy 4500/400 intake, ported by me 10.7:1 compression for pump gas Block bored with torque plate Block decked .005 Exhaust is 2" into 2-1/4 to 4" fender exit (Loud) Have all receipts for engine.
Trans: 727 with all A&A parts Trans brake FMRVB Competition Trans convertor, just freshened Steel outer drum Extra clutches modified for better oiling deep cast alum pan PPP Shifter
Car typically runs 6.0 at 115mph in the 1/8th and 9.4's in the 1/4...with this combo.
Still weight to be removed from the doors, and around the radiator.
Options: Could sell as a roller with good deposit Could sell just the engine with a good deposit
1968 Dodge Dart GT convertible shell
[Re: moparts]
#3253423
08/23/24 09:39 PM
08/23/24 09:39 PM
Posts: 43,891 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
1968 Dodge Dart GT convertible shell, was 318 automatic factory A/C now stripped to bare shell. Comes with doors one with glass one without, rear complete glass and mechanisms, dash frame with VIN, complete top mechanism and hydraulics, new front floor pans welded in, and nothing else. Needs bottom of rear quarters, trunk spare tire well, and various other rust repair in trunk and dutchman panel. No suspension, fenders, bumpers, hood, wiring, interior, or deck lid. Some of those parts are available.$2500.00, delivery available at $1.75 per mile. Bill of Sale from Kansas, no title. Call Jim at 224-688-4352 or PM me here...
JB Rhinehart, Realist
A-Body's RULE!
Re: A Body - Cars For Sale 3rd Quarter
[Re: moparts]
#3260087
09/25/24 08:37 PM
09/25/24 08:37 PM
Posts: 172 orange city,FL
Demon340GSS
orange city,FL
1971 Dodge Demon 340 4 speed originally with ,Rallye Dash n Gauges still present NOW 440 big block with 6-71 Supercharger. VIN tag has “ H” as 5 th character. 4 speed clutch pedal still there . Only metal that needs work is lower outer skins and bottom of quarters at wheel opening. ( not the inner Alston kit stuff) No rust basically totally rust free body everywhere. 12 point cage Parachute Comp Engineering Wheelie Bars 33x21.5 x15 rear Mickey Thompson ET drag slick NEW 5:13 rear Gear. Moser, Mark Williams, Richmond, Custom race driveshaft 16 gallon Fuel Cell Includes Mickey Thompson Sportsman tires for street driving Included 2 Holley Blue pumps and regulators , Billet Fuel Filters. 1/2” fuel and Nitrous Lines. Has fiberglass trunk lid installed Includes original 71 demon steel trunk lid ( has factory wing spoiler cutouts. Included is the original rust free 1971 Demon 340 dual scoops hood. Includes 2 new fiberglass hoods unused. ALL from US Fiberglass Tampa. Has steel doors on it now, But includes 2 sets of Fiberglass Doors too ( 4 doors un installed) Has factory glass windshield and side glass, but lexan back glass. Includes Lexan door glass’s too Window Net drivers side. Racing Seats with Harness’s ( need revert, but good for street / play) Complete set of Autometer gauges including nitrous pressure gauge, Boost Gauge, Water, Oil, Water Temp, Etc. Nitrous Bottle Heater and Discharge Solenoid to vent Moser Axles Long wheel studs rear Front grill in trailer Includes 33’ PACE American Race Car Hauler Enclosed Trailer. 2 5/16 Ball included for receiver hitch Included is a new electric Air Compressor for track/ ? Use.. Tires good- but includes a complete set of spare tires mounted on extra complete set of wheels for trailer.. ( load car and haul it all away) Includes Demon Stripe Kit. NEW Includes Rallye dash white gauge kit not installed Extra Spare Rallye Demon 340 gauge cluster included.
440 Big Block Engine. Standard Bore, Forged Steel Crank STD STD Milodon Gear Drive. Pistons have deep valve reliefs Milodon oil pan and pump Includes new NOS Milodon Oil Pan with Swinging pickup. Uninstalled .557 lift solid cam ( so valves don’t stick open under boost) Includes a brand new still in the box Comp Cams Roller 720 lift Cam. Ported and polished 906 heads using Direct Connection Templates with upgrade to Manley Severe Duty MAX Wedge Valves. Work done by Mopar Madness. Milodon Valve Covers. Moroso Pan Evac Supercharger safety Straps ( need recertification) but still good. Electric Water Pump. Griffin Radiator MSD 7 AL box with 3 step MSD retard. Raced it with 1050 Dominators included with all linkage and plate. Had a pair of Carter Comp Series Carbs now as a effort to de tune. ( for street) New 4200 Stall 727 transmission, Deep Pan B&M pro stick Full reverse manual valve body. Includes brand new still in box Transbrake. Go Baby Go Nitrous Knob Really Too Much to list is included. Mopar Performance M1 intake manifold included with 750 double pumper carb ( in case you don’t like Superchargers) NOS single 4 nitrous kit included if you want to take supercharger off car. Full Nitrous Bottle ( never used since first fill) Under chassis Headers Hooker 3” mufflers.
Best time 8.03 @ 174 mph full quarter on motor only, thru muffs and on street tires Orlando Speedworld fastest street car nationals 2008 Can go faster with gear change. Some 340 stuff included too. New Racing Helmet Included New Race Jacket Included. Car has mostly sat in trailer . Includes 5 gallons of 112 oct race fuel still in unopened can. ( Sunoco)
Contact Grant at 386-561-1181
Asking 30,000 for ALL Willing to talk .
Orange City, Florida. 32763 zip. ( between Daytona Beach and Orlando) just off of I-4. Can hold only a short time. Reason for selling? I am disabled and cannot enjoy ( leg amputation) Car has sat unused for years Still starts and drives Have Questions please call Need to move before I lose my home. Plan was to strip and paint and reassemble. Enjoy 386-561-1181. No trades
Owner of Original collector and restored original mopars from Mr Norms Grand Spaulding Dodge.
