$36k for a new 3.0 v6 diesel engine? #3233372
05/17/24 03:57 PM
05/17/24 03:57 PM
Kirkland, Washington
Pacnorthcuda Offline OP
Got a friend who’s 2018 RAM 1500 Ecodiesel died..presumably a spun bearing or rod problem. Dodge dealer says $36,000 for new engine. Is that even remotely close to reality???? I would have quessed $10k. No way……
Re: $36k for a new 3.0 v6 diesel engine? [Re: Pacnorthcuda] #3233450
05/17/24 11:12 PM
05/17/24 11:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
We have two laying out back with people looking down the barrel of iirc 26k + repair for engines. That would be #20 and #21 at the small dealer I work at. Also have two waiting for fuel systems for the exploded high psi pump and one we’ve been waiting for months on a melted intake. People that buy these get what’s coming to them sooner or later.
Re: $36k for a new 3.0 v6 diesel engine? [Re: Pacnorthcuda] #3233457
05/18/24 01:17 AM
05/18/24 01:17 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: $36k for a new 3.0 v6 diesel engine? [Re: A12] #3233462
05/18/24 03:49 AM
05/18/24 03:49 AM
Well, I suppose 24k for a new crate means a dealer throwing out a $36k number for a new installed engine is believable, but likely on the high side. I had no idea a relatively common work truck motor could run that high. Seems insane to me. I would think a used engine installed by a private mechanic might be more like 12-15k, but no warrantee. A rock and a hard place.
Guys pay a premium for the long term durability of diesels, when one craps out at 40,000 miles all that goes out the window.
Re: $36k for a new 3.0 v6 diesel engine? [Re: Pacnorthcuda] #3233470
05/18/24 06:44 AM
05/18/24 06:44 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
This jogged a memory cell or two for me, lol.
Last oil change on the company truck the oil place wanted to replace the air filter, which I agreed with. 50k miles in the 12 months since I got it, new. A lot of it out in the oil patch on dirt. Lease company said "no, not due for replacement for 36 more MONTHS". At that rate I will have 200k miles on the truck before they will sign off on a new air filter.
Really?
As I told the shop, an air filter is cheaper than an engine.
Re: $36k for a new 3.0 v6 diesel engine? [Re: Sniper] #3233488
05/18/24 09:51 AM
05/18/24 09:51 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Here’s a real question. What would it cost to just swap in a 5.7 or 6.4? Less than $36,000 probably. Junkyard fuel system and stand alone computer.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: $36k for a new 3.0 v6 diesel engine? [Re: FurryStump] #3233598
05/18/24 08:08 PM
05/18/24 08:08 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Unless you have to pass a smog inspection.
Kevin
Re: $36k for a new 3.0 v6 diesel engine? [Re: Twostick] #3233601
05/18/24 08:11 PM
05/18/24 08:11 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I have seen new OEM crate engines advertised privately here for around $11k. No idea if they were a scam or not but low mile used were that much too. shruggy
Kevin
Re: $36k for a new 3.0 v6 diesel engine? [Re: Twostick] #3233619
05/18/24 10:23 PM
05/18/24 10:23 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Kevin
If the OEM motor puked at 40,000, what are the chances the next "low mileage" replacement is going to fair any better? It sounds like these motors are not surviving well in the real world. Imagine what its going to be like finding a good one of these motors in another 10 years.
Re: $36k for a new 3.0 v6 diesel engine? [Re: Pacnorthcuda] #3233628
05/18/24 11:19 PM
05/18/24 11:19 PM
AndyF Offline
AndyF  Offline
Wow, so no warranty left even at 40K miles? Guess a person needs to buy an extended warranty with these trucks. I've owned my 2004 Dodge Ram for 20 years no with mostly just routine maintenance costs. I did recently have to replace the fan on the AC system and that was $1000 for a little electric fan, but not too bad in the big picture. Had I known exactly what the problem was I most likely could've found one in a wrecking yard.
Re: $36k for a new 3.0 v6 diesel engine? [Re: AndyF] #3233674
05/19/24 10:51 AM
05/19/24 10:51 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I was thinking of a new truck soon(current truck is 11 yrs old) but none of the new stuff floats my boat and most of them seem problematic and spendy to fix(not just Ram...all of them) I certainly won't be looking at anything with these small diesels.....GM has had their share of issues also. I will likely keep my current truck....I like it and it has been trouble free since new.
Re: $36k for a new 3.0 v6 diesel engine? [Re: poorboy] #3233679
05/19/24 11:04 AM
05/19/24 11:04 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Kevin
10??? I'm thinking in ten years, the eco-diesel will be a bad memory. Probably replaced by the next "brainiac" idea to save fuel.
Re: $36k for a new 3.0 v6 diesel engine? [Re: moparmike1] #3233689
05/19/24 11:49 AM
05/19/24 11:49 AM
moparx Offline
moparx  Offline
"I'm thinking in ten years, the eco-diesel will be a bad memory. Probably replaced by the next "brainiac" idea to save fuel."
wooden cloths pins on the fuel line works, as well as that propeller thing that spins inside your air intake. whistling biggrin
beer
Re: $36k for a new 3.0 v6 diesel engine? [Re: Twostick] #3233729
05/19/24 03:11 PM
05/19/24 03:11 PM
BDW Offline
BDW  Offline
Kevin
Isn't it just a tail pipe check?
How would they know what motor is in the truck, or care?
Re: $36k for a new 3.0 v6 diesel engine? [Re: BDW] #3233738
05/19/24 03:41 PM
05/19/24 03:41 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Many states do an underhood inspection and an under vehicle inspection. Weather or not the inspections know anything is a grab bag.
I have a 1st gen Cummins. For 36 K, I could restore the truck AND build one heck of an engine.
Angry white pureblood male
Re: $36k for a new 3.0 v6 diesel engine? [Re: BDW] #3233741
05/19/24 03:48 PM
05/19/24 03:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Kevin
Here in Ohio E-Check plugs into the OBD and runs the diagnostic through it. VIN (and OBD) verifies the engine and the emission output and issues, can't fool it.
Re: $36k for a new 3.0 v6 diesel engine? [Re: A12] #3233776
05/19/24 05:23 PM
05/19/24 05:23 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
Kevin
MOST STATES emission zone inspections do this.
the test reads 10 test readiness monitors. you have to have 9 out of 10 in compliance.
a LOT if not all test zones you can fail by having a NON 50 state approved tune in your car even if all 10 monitors transmit ok
i know Wisconsin has this.
perception is 90% of reality
Re: $36k for a new 3.0 v6 diesel engine? [Re: Mr T2U] #3233798
05/19/24 06:30 PM
05/19/24 06:30 PM
Missouri
galen Offline
galen  Offline
Missouri
I traded my 2014 ecodiesel off in November. 63,000 miles. It did me good but after the last high pressure fuel pump recall with no real fix and the crank sensor tone wheel failure. (bring it in and we will program it to run off the cam sensor). Only offered me 17k trade in. Figured I was living on borrowed time so I took it.
Re: $36k for a new 3.0 v6 diesel engine? [Re: galen] #3233802
05/19/24 06:49 PM
05/19/24 06:49 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
watched a vid recently. 5.0 cummins in nissan spun a few bearings ...quote for long block from nissan $23k..not sure if price is long block only or motor + install.
Re: $36k for a new 3.0 v6 diesel engine? [Re: Mr T2U] #3233824
05/19/24 09:03 PM
05/19/24 09:03 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Kevin
Yep. I have a tune for my F150 5.0. It doesn't touch any emissions systems or monitors but I still put the stock tune back in at emissions test time
