Re: $36k for a new 3.0 v6 diesel engine?
[Re: Pacnorthcuda]
#3233470
05/18/24 06:44 AM
05/18/24 06:44 AM
Posts: 6,335 nowhere
Sniper
nowhere
Well, I suppose 24k for a new crate means a dealer throwing out a $36k number for a new installed engine is believable, but likely on the high side. I had no idea a relatively common work truck motor could run that high. Seems insane to me. I would think a used engine installed by a private mechanic might be more like 12-15k, but no warrantee. A rock and a hard place. Guys pay a premium for the long term durability of diesels, when one craps out at 40,000 miles all that goes out the window. This jogged a memory cell or two for me, lol. Last oil change on the company truck the oil place wanted to replace the air filter, which I agreed with. 50k miles in the 12 months since I got it, new. A lot of it out in the oil patch on dirt. Lease company said "no, not due for replacement for 36 more MONTHS". At that rate I will have 200k miles on the truck before they will sign off on a new air filter. Really? As I told the shop, an air filter is cheaper than an engine.
[Re: FurryStump]
#3233598
05/18/24 08:08 PM
05/18/24 08:08 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Here’s a real question. What would it cost to just swap in a 5.7 or 6.4? Less than $36,000 probably. Junkyard fuel system and stand alone computer. Unless you have to pass a smog inspection. Kevin
[Re: Twostick]
#3233619
05/18/24 10:23 PM
05/18/24 10:23 PM
Posts: 10,654 Freeport IL USA
poorboy
Freeport IL USA
I have seen new OEM crate engines advertised privately here for around $11k. No idea if they were a scam or not but low mile used were that much too. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Kevin If the OEM motor puked at 40,000, what are the chances the next "low mileage" replacement is going to fair any better? It sounds like these motors are not surviving well in the real world. Imagine what its going to be like finding a good one of these motors in another 10 years.
[Re: poorboy]
#3233679
05/19/24 11:04 AM
05/19/24 11:04 AM
Posts: 1,863 Sault Ste. Marie, Ontario, Can...
moparmike1
I have seen new OEM crate engines advertised privately here for around $11k. No idea if they were a scam or not but low mile used were that much too. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Kevin If the OEM motor puked at 40,000, what are the chances the next "low mileage" replacement is going to fair any better? It sounds like these motors are not surviving well in the real world. Imagine what its going to be like finding a good one of these motors in another 10 years. 10??? I'm thinking in ten years, the eco-diesel will be a bad memory. Probably replaced by the next "brainiac" idea to save fuel.
[Re: Twostick]
#3233729
05/19/24 03:11 PM
05/19/24 03:11 PM
Posts: 4,761 Florida
BDW
I have seen new OEM crate engines advertised privately here for around $11k. No idea if they were a scam or not but low mile used were that much too. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Kevin Isn't it just a tail pipe check? How would they know what motor is in the truck, or care?
[Re: BDW]
#3233738
05/19/24 03:41 PM
05/19/24 03:41 PM
Posts: 5,960 ohio
ruderunner
ohio
Many states do an underhood inspection and an under vehicle inspection. Weather or not the inspections know anything is a grab bag.
I have a 1st gen Cummins. For 36 K, I could restore the truck AND build one heck of an engine.
Angry white pureblood male
[Re: BDW]
#3233741
05/19/24 03:48 PM
05/19/24 03:48 PM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
I have seen new OEM crate engines advertised privately here for around $11k. No idea if they were a scam or not but low mile used were that much too. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Kevin Isn't it just a tail pipe check? How would they know what motor is in the truck, or care? Here in Ohio E-Check plugs into the OBD and runs the diagnostic through it. VIN (and OBD) verifies the engine and the emission output and issues, can't fool it.
[Re: A12]
#3233776
05/19/24 05:23 PM
05/19/24 05:23 PM
Posts: 4,924 new berlin wisconsin
Mr T2U
I have seen new OEM crate engines advertised privately here for around $11k. No idea if they were a scam or not but low mile used were that much too. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Kevin Isn't it just a tail pipe check? How would they know what motor is in the truck, or care? Here in Ohio E-Check plugs into the OBD and runs the diagnostic through it. VIN (and OBD) verifies the engine and the emission output and issues, can't fool it. MOST STATES emission zone inspections do this. the test reads 10 test readiness monitors. you have to have 9 out of 10 in compliance. a LOT if not all test zones you can fail by having a NON 50 state approved tune in your car even if all 10 monitors transmit ok i know Wisconsin has this.
perception is 90% of reality
[Re: Mr T2U]
#3233798
05/19/24 06:30 PM
05/19/24 06:30 PM
Posts: 836 Missouri
galen
Missouri
I traded my 2014 ecodiesel off in November. 63,000 miles. It did me good but after the last high pressure fuel pump recall with no real fix and the crank sensor tone wheel failure. (bring it in and we will program it to run off the cam sensor). Only offered me 17k trade in. Figured I was living on borrowed time so I took it.
[Re: Mr T2U]
#3233824
05/19/24 09:03 PM
05/19/24 09:03 PM
Posts: 4,963 WI
Dcuda69
WI
I have seen new OEM crate engines advertised privately here for around $11k. No idea if they were a scam or not but low mile used were that much too. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Kevin Isn't it just a tail pipe check? How would they know what motor is in the truck, or care? Here in Ohio E-Check plugs into the OBD and runs the diagnostic through it. VIN (and OBD) verifies the engine and the emission output and issues, can't fool it. MOST STATES emission zone inspections do this. the test reads 10 test readiness monitors. you have to have 9 out of 10 in compliance. a LOT if not all test zones you can fail by having a NON 50 state approved tune in your car even if all 10 monitors transmit ok i know Wisconsin has this. Yep. I have a tune for my F150 5.0. It doesn't touch any emissions systems or monitors but I still put the stock tune back in at emissions test time
