440 Exhaust-to-head gasket...help!
#323320
05/20/09 01:12 AM
05/20/09 01:12 AM
Posts: 5,275 near Harrisburg, Pa
440trk
near Harrisburg, Pa
In the past 2 weeks, I've put 2 exhaust manifold-to-cyl. head gaskets on my 71 440 R/T. They ALL leak from the bottom of cyl. 3/5. After looking at the Fel-Pro gaskets, it looks like the bottom of the center exhaust ports just don't get drawn down tight enough. I've checked for any other causes, but ... I cleaned the ever lovin' crap outta both surfaces thinking there was gasket residue...but nope...still leaks. So...I once again need to fix the leak. Anyone have any tricks, or any suggestions on WHAT gaskets to use to fix this problem. I realize the maifolds may have a slight warp, which is causing the problem...but I REALLY don't care do deal with having the manifold planed down, unless I have NO other options. Thanks in advance...
Re: 440 Exhaust-to-head gasket...help!
[Re: mrmopardan]
#323328
05/20/09 04:34 PM
05/20/09 04:34 PM
69x
This will solve your problem http://www.remflex.com/
Thats it, Remflex, thats what you need
[Re: 69x]
#323329
05/20/09 07:26 PM
05/20/09 07:26 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
the rimflex and the NAPA Nitro Seals are the same...
I am truckless..
