440 Exhaust-to-head gasket...help!
#323320
05/20/09 01:12 AM
05/20/09 01:12 AM
Posts: 5,275 near Harrisburg, Pa
440trk
near Harrisburg, Pa
In the past 2 weeks, I've put 2 exhaust manifold-to-cyl. head gaskets on my 71 440 R/T. They ALL leak from the bottom of cyl. 3/5. After looking at the Fel-Pro gaskets, it looks like the bottom of the center exhaust ports just don't get drawn down tight enough. I've checked for any other causes, but ... ![](/ubbthreads/images/graemlins/shruggy.gif) I cleaned the ever lovin' crap outta both surfaces thinking there was gasket residue...but nope...still leaks. So...I once again need to fix the leak. ![](/ubbthreads/images/graemlins/rant.gif) Anyone have any tricks, or any suggestions on WHAT gaskets to use to fix this problem. I realize the maifolds may have a slight warp, which is causing the problem...but I REALLY don't care do deal with having the manifold planed down, unless I have NO other options. Thanks in advance...
Re: 440 Exhaust-to-head gasket...help!
[Re: mrmopardan]
#323328
05/20/09 04:34 PM
05/20/09 04:34 PM
69x
This will solve your problem http://www.remflex.com/
Thats it, Remflex, thats what you need
[Re: 69x]
#323329
05/20/09 07:26 PM
05/20/09 07:26 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
the rimflex and the NAPA Nitro Seals are the same...
I am truckless..
