Cal Trac springs #3231193
05/05/24 05:32 PM
05/05/24 05:32 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Looking to see if anyone has a vidio from under car launching on these springs? Basically where to set pinion angle (Duster Dana 4.88 gear and 9x30 Hosier radials auto)
Re: Cal Trac springs [Re: cudaman1969] #3231202
05/05/24 06:15 PM
05/05/24 06:15 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I set mine at 3 degrees down when I ran CalTracs.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Cal Trac springs [Re: cudaman1969] #3231211
05/05/24 07:01 PM
05/05/24 07:01 PM
AndyF Offline
AndyF  Offline
Are you just using the CalTrac springs, or do you have the full CalTrac suspension? When you use the Calvert suspension setup with the lower bars you don't need much pinion angle since the rear end doesn't rotate much. If you use their springs without the bars then you would nee a bunch more pinion angle.
Re: Cal Trac springs [Re: AndyF] #3231217
05/05/24 07:26 PM
05/05/24 07:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I run mine 1 deg down from parallel to the trans, work great
Re: Cal Trac springs [Re: CSK] #3231220
05/05/24 07:33 PM
05/05/24 07:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'm at 4° down. Nickel width air gap at rest. Bars in bottom hole. Upper shock mount moved to framerail to get them as vertical as possible.
Has been 1.36 60 ft. on a 275 drag radial.
'63 Dodge 330
11.19 @ 121 mph
Re: Cal Trac springs [Re: GY3] #3231228
05/05/24 08:04 PM
05/05/24 08:04 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Re: Cal Trac springs [Re: nss guy] #3231235
05/05/24 08:53 PM
05/05/24 08:53 PM
fredericksburg,va
fredericksburg,va
Yes whole Cal setup, been thinking of moving top of shocks over close to frame to get more vertical. Car will be 340 F/Stock auto, moly cage 3115 pounds
Re: Cal Trac springs [Re: GY3] #3231237
05/05/24 08:54 PM
05/05/24 08:54 PM
fredericksburg,va
fredericksburg,va
Nice
Re: Cal Trac springs [Re: AndyF] #3231240
05/05/24 09:01 PM
05/05/24 09:01 PM
fredericksburg,va
fredericksburg,va
Whole setup, “doesn't rotate much” what I wanted to hear.
Amazing how ‘off’ the suspension is, to get rear square to car I had to move axel spring perch back on pin 1/8” (right side was more forward)
Re: Cal Trac springs [Re: cudaman1969] #3231244
05/05/24 09:18 PM
05/05/24 09:18 PM
fredericksburg,va
fredericksburg,va
Pics
Re: Cal Trac springs [Re: cudaman1969] #3231283
05/06/24 05:41 AM
05/06/24 05:41 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
5 degrees down, car gets a LOT of axle rotation, it's why we have the wheelie bars set so high (the bars are for safety not tuning). This is something I have seen on many mopars using that type of wheelie bar, the big mistake is they are set too low and it unloads the tyre at the hit.
The car has been 1.29, (1.34 on the back wheels) 60ft @ 4000lb + with a 29.5 x 10.5 radial slick. Watch the vid below 1/4 time and you will see what a typical launch is like and how the rear reacts. (F/F to 40 sec in to miss the staging stuff up)
https://www.youtube.com/watch?v=8iUhVr2rxm0
Re: Cal Trac springs [Re: Tig] #3231307
05/06/24 09:14 AM
05/06/24 09:14 AM
an8sec70cuda Offline
Mine is 3° down relative to the trans. Calvert recommends 2-3° if I'm not mistaken.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cal Trac springs [Re: cudaman1969] #3231338
05/06/24 11:07 AM
05/06/24 11:07 AM
AndyF Offline
AndyF  Offline
Calvert recommends 2 to 3 degrees of pinion angle with the bars parallel to the ground and a small gap. Need to put weight in the driver seat when making your adjustments.
Re: Cal Trac springs [Re: AndyF] #3231412
05/06/24 02:54 PM
05/06/24 02:54 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
As you can tell from the responses there seems to be a pretty wide range of what will work. Mine have been on so long I don't remember what the pinion angle was set at.
If you want to know for sure what might be best for your car give Calvert a call, their customer service is top notch.
Cool to see you are building a F/SA car! Keep us posted on your progress and let us know when you get it on the track.
Re: Cal Trac springs [Re: CSK] #3231421
05/06/24 03:17 PM
05/06/24 03:17 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The reason I run mine only 1deg down from trans is it works great SO FAR at launch, BUT if I go down more on the pinion I get a driveline vibration at a light cruise 70mph & up,, Street car problems LOL , I have OD trans & a 4.10 gear with a short driveshaft its very sensitive to the angles, smooth as glass the way I have it now that I have a Mark Williams driveshaft
Re: Cal Trac springs [Re: cudaman1969] #3231426
05/06/24 03:36 PM
05/06/24 03:36 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
From Calvert's faq
What pinion angle works best?
We suggest a pinion angle to be between 2-4 degrees negative, measuring off the transmission yoke and pinion yoke.
Re: Cal Trac springs [Re: AndyF] #3231433
05/06/24 05:29 PM
05/06/24 05:29 PM
fredericksburg,va
fredericksburg,va
What I always did. We had horses back in the day and wife bought 50 pound bags of feed, I put 5 bags in the driver seat then adjust the weight and 4 link bars. I did a lot of freebies back then all the buddies cars, rears, suspensions, motors and trans, but just a hobby
Re: Cal Trac springs [Re: 340Cuda] #3231434
05/06/24 05:31 PM
05/06/24 05:31 PM
fredericksburg,va
fredericksburg,va
Thanks, if I don’t get it done soon time will pass me by, old folks home calling me every month. lol
Bad part I’m getting rotator surgery next week then 4 months later the other shoulder, to much lifting and falling!
