Re: Cal Trac springs
[Re: cudaman1969]
#3231202
05/05/24 06:15 PM
05/05/24 06:15 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I set mine at 3 degrees down when I ran CalTracs. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#3231217
05/05/24 07:26 PM
05/05/24 07:26 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I run mine 1 deg down from parallel to the trans, work great
[Re: CSK]
#3231220
05/05/24 07:33 PM
05/05/24 07:33 PM
Posts: 4,701 Wichita
GY3
Wichita
I'm at 4° down. Nickel width air gap at rest. Bars in bottom hole. Upper shock mount moved to framerail to get them as vertical as possible.
Has been 1.36 60 ft. on a 275 drag radial.
[Re: GY3]
#3231237
05/05/24 08:54 PM
05/05/24 08:54 PM
Posts: 8,344 fredericksburg,va
cudaman1969
fredericksburg,va
Has been 1.36 60 ft. on a 275 drag radial. Nice
[Re: AndyF]
#3231240
05/05/24 09:01 PM
05/05/24 09:01 PM
cudaman1969
fredericksburg,va
Are you just using the CalTrac springs, or do you have the full CalTrac suspension? When you use the Calvert suspension setup with the lower bars you don't need much pinion angle since the rear end doesn't rotate much. If you use their springs without the bars then you would nee a bunch more pinion angle. Whole setup, “doesn't rotate much” what I wanted to hear. Amazing how ‘off’ the suspension is, to get rear square to car I had to move axel spring perch back on pin 1/8” (right side was more forward)
[Re: cudaman1969]
#3231283
05/06/24 05:41 AM
05/06/24 05:41 AM
Posts: 2,934 A shed in England
Tig
A shed in England
5 degrees down, car gets a LOT of axle rotation, it's why we have the wheelie bars set so high (the bars are for safety not tuning). This is something I have seen on many mopars using that type of wheelie bar, the big mistake is they are set too low and it unloads the tyre at the hit. The car has been 1.29, (1.34 on the back wheels) 60ft @ 4000lb + with a 29.5 x 10.5 radial slick. Watch the vid below 1/4 time and you will see what a typical launch is like and how the rear reacts. (F/F to 40 sec in to miss the staging stuff ) https://www.youtube.com/watch?v=8iUhVr2rxm0
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3231307
05/06/24 09:14 AM
05/06/24 09:14 AM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
Mine is 3° down relative to the trans. Calvert recommends 2-3° if I'm not mistaken.
[Re: cudaman1969]
#3231338
05/06/24 11:07 AM
05/06/24 11:07 AM
Posts: 31,074 Oregon
AndyF
Are you just using the CalTrac springs, or do you have the full CalTrac suspension? When you use the Calvert suspension setup with the lower bars you don't need much pinion angle since the rear end doesn't rotate much. If you use their springs without the bars then you would nee a bunch more pinion angle. Whole setup, “doesn't rotate much” what I wanted to hear. Amazing how ‘off’ the suspension is, to get rear square to car I had to move axel spring perch back on pin 1/8” (right side was more forward) Calvert recommends 2 to 3 degrees of pinion angle with the bars parallel to the ground and a small gap. Need to put weight in the driver seat when making your adjustments.
[Re: CSK]
#3231421
05/06/24 03:17 PM
05/06/24 03:17 PM
CSK
Pattison Texas
I run mine 1 deg down from parallel to the trans, work great The reason I run mine only 1deg down from trans is it works great SO FAR at launch, BUT if I go down more on the pinion I get a driveline vibration at a light cruise 70mph & up,, Street car problems LOL , I have OD trans & a 4.10 gear with a short driveshaft its very sensitive to the angles, smooth as glass the way I have it now that I have a Mark Williams driveshaft
[Re: cudaman1969]
#3231426
05/06/24 03:36 PM
05/06/24 03:36 PM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
From Calvert's faq
What pinion angle works best? We suggest a pinion angle to be between 2-4 degrees negative, measuring off the transmission yoke and pinion yoke.
[Re: AndyF]
#3231433
05/06/24 05:29 PM
05/06/24 05:29 PM
cudaman1969
fredericksburg,va
Are you just using the CalTrac springs, or do you have the full CalTrac suspension? When you use the Calvert suspension setup with the lower bars you don't need much pinion angle since the rear end doesn't rotate much. If you use their springs without the bars then you would nee a bunch more pinion angle. Whole setup, “doesn't rotate much” what I wanted to hear. Amazing how ‘off’ the suspension is, to get rear square to car I had to move axel spring perch back on pin 1/8” (right side was more forward) Calvert recommends 2 to 3 degrees of pinion angle with the bars parallel to the ground and a small gap. Need to put weight in the driver seat when making your adjustments. What I always did. We had horses back in the day and wife bought 50 pound bags of feed, I put 5 bags in the driver seat then adjust the weight and 4 link bars. I did a lot of freebies back then all the buddies cars, rears, suspensions, motors and trans, but just a hobby
[Re: 340Cuda]
#3231434
05/06/24 05:31 PM
05/06/24 05:31 PM
cudaman1969
fredericksburg,va
As you can tell from the responses there seems to be a pretty wide range of what will work. Mine have been on so long I don't remember what the pinion angle was set at.
If you want to know for sure what might be best for your car give Calvert a call, their customer service is top notch.
Cool to see you are building a F/SA car! Keep us posted on your progress and let us know when you get it on the track. Thanks, if I don’t get it done soon time will pass me by, old folks home calling me every month. lol Bad part I’m getting rotator surgery next week then 4 months later the other shoulder, to much lifting and falling!
