Something you dont see everyday #3230832
05/03/24 03:59 PM
05/03/24 03:59 PM
Nor here, Nor there
Dart 500 Offline OP
Dart 500  Offline OP
Nor here, Nor there
Cameron Fine had his NASCAR Xfinity Series Dodge out making the first passes since he got it, still running its NASCAR engine with some gearing and suspension changes, running in the 10s and lifting the wheels a little in the process!! How many times have you seen a stock car that raced on Talladega doing a wheelie???
Re: Something you dont see everyday [Re: Dart 500] #3230849
05/03/24 05:38 PM
05/03/24 05:38 PM
Any idea of its weight and H.P.?
Re: Something you dont see everyday [Re: Dart 500] #3230881
05/03/24 08:20 PM
05/03/24 08:20 PM
AndyF Offline
AndyF  Offline
Be interesting to see what the NHRA tech guys think about NASCAR stuff. I know that NASCAR used to put the oil tank behind the driver's seat. They were big tanks back in the day, maybe 3 to 5 gallons. NHRA doesn't allow any engine fluid in the driver's compartment. There might be other stuff like that.
Re: Something you dont see everyday [Re: AndyF] #3230887
05/03/24 09:08 PM
05/03/24 09:08 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Power for those can be about 700 HP, except restrictor-plate tracks @ about 450.
IIRC, they're 3400 lbs w/driver, minimum.
The car in the OP could certainly vary, as it's an old car, and not at an Xfinity race. Their tech guys are murderous compared to NHRA, but obviously they're 2 different worlds.
For ovals, maximizing left side weight is limited by regulations. Hence stuff like oil tanks & batteries have been traditionally left side, and located with regard to polar moment of inertia.
I would think a road course configuration would be inherently better at drag racing than an oval car configuration.
FWIW, An obsolete dirt Sprint Car from 40-50 years ago should easily run 8s.
Re: Something you dont see everyday [Re: topside] #3230919
05/04/24 12:54 AM
05/04/24 12:54 AM
Nor here, Nor there
Dart 500 Offline OP
Dart 500  Offline OP
Nor here, Nor there
It didn't look Xfiniti to me either, looks like a CASCAR which I think used the gen3 hemi
Edit, it aint no CASCAR, pics for difference
Re: Something you dont see everyday [Re: Dart 500] #3230930
05/04/24 04:47 AM
05/04/24 04:47 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Something you dont see everyday [Re: topside] #3231077
05/04/24 10:09 PM
05/04/24 10:09 PM
gregsdart Offline
gregsdart  Offline
And later ones, much quicker! 900 hp at what, 1400 lbs with driver? With traction, 7s?
Re: Something you dont see everyday [Re: gregsdart] #3231102
05/05/24 09:43 AM
05/05/24 09:43 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
They used to race sprints against pro stocks, the sprints would come down the return road and u turn at the starting line/burnout box. Then get a running start at the tree, the pro stocker would get a little earlier three than the sprint. This was when the pro stockers were running low 7's The sprint's won most of them as I recall.
Re: Something you dont see everyday [Re: gregsdart] #3231104
05/05/24 09:57 AM
05/05/24 09:57 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Is anyone running Mopar's in any sprints these days? My son and I went and watched the High Limit series 410 sprints a few weeks ago. Mostly chevies, one ford, one or two Toyota engines was all I found. No matter the powerplant it was a good show.
68 Barracuda Formula S 340
Re: Something you dont see everyday [Re: Bad340fish] #3231128
05/05/24 11:36 AM
05/05/24 11:36 AM
my own world
theraif Offline
theraif  Offline
my own world
i have seen a old WoO spint car run and have seen photos of a old dirt late model
Re: Something you dont see everyday [Re: theraif] #3231133
05/05/24 12:03 PM
05/05/24 12:03 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
If they ran those in Nascar I might actually watch it again !
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
