Need to change drivers side remote mirror #3230019
04/29/24 04:17 PM
04/29/24 04:17 PM
South San Francisco, Ca
70sixpkrt Offline OP
I need to change my drivers side remote mirror on a 70 Charger. What does it consist of? Taking the upper pad off? And then what? Thanks
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Need to change drivers side remote mirror [Re: 70sixpkrt] #3230071
04/29/24 09:34 PM
04/29/24 09:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
screw on the outside , nut on the underside then the remote joy stick , make sure the window is rolled up.
Someone makes/made a special tool to unscrew the nut on the joystick so you don't damage it.
Re: Need to change drivers side remote mirror [Re: JohnRR] #3230157
04/30/24 09:56 AM
04/30/24 09:56 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Gonna need to remove the door panel in order to access the mirror - if I recall correctly, there is a stud with a nut you need to remove, also for being able to put the cable/joystick into the hole and getting the nut on - don't think you need to remove the upper pad. . . .
Re: Need to change drivers side remote mirror [Re: a12rag] #3230271
04/30/24 04:09 PM
04/30/24 04:09 PM
Thanks. I had a feeling I would have to remove the door panel.
4-speed
3:54 Dana
