Trailer tires #3229564
04/27/24 07:03 PM
04/27/24 07:03 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Anyone one here change from load range "E" trailer tires (10 ply) to a LR "G" (14 ply) on a 16" wheel? I have a 48' LQ gooseneck trailer w/ 3 6K axles & LR E tires that are about 5 1/2 years old. I going to replace them. I'm looking at a LR "G", 14 ply all steel radial. They also run at a higher pressure than the old tires, 110psi compared to 80psi. Just curious if anyone has done this and what were the results? Less problems, longer wear, shake the race car and trailer apart? Worth it or not?
Thanks, Brian
Re: Trailer tires [Re: '72CudaRacer] #3229567
04/27/24 07:23 PM
04/27/24 07:23 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I did it on my 30ft trailer 15 inch wheels .
Haven't had tire issues since .
The 10 ply would start blowing out after 2 years haven't had one go bad in 3 now .
Re: Trailer tires [Re: a493demon] #3229614
04/27/24 11:00 PM
04/27/24 11:00 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
If you run the tires at their max pressure you may have rim cracking issues, Ive been down that road, rims have a max pressure rating just like the tires, this happened to me on a fifth wheel camper toyhauler.
Re: Trailer tires [Re: '72CudaRacer] #3229665
04/28/24 09:33 AM
04/28/24 09:33 AM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I switched to Hercules H901 tires on every trailer I own and have never had an issue regardless of how old the tires are. They are a commercial grade regroovable trailer tire. They do run at a higher pressure so check your wheels. Well worth the investment.
Re: Trailer tires [Re: '72CudaRacer] #3229709
04/28/24 12:07 PM
04/28/24 12:07 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Like Wyo mentioned….. rims are rated too. Pretty sure we’re dancing with the devil in that aspect as we have 6 lug rims. We switched to Greenball Towmaster ASC back in 2019 on our 28ft box (11k approx). Best move in tires ever for us ever. 78mph rating, haven’t lost one yet. Old “E” rated tires would usually give us issues after two years. We run them at 90psi cold as we often run in some extreme heat at times. One thing we did start doing with these tires was to remove them when it starts to get hot. Huge pita, but our boat being stored inside taught us a thing or two about tire life smile .
Re: Trailer tires [Re: J_BODY] #3229870
04/29/24 01:49 AM
04/29/24 01:49 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I replaced my old 10 plys with 14 plys on my 28' box trailer a couple years ago. So far, so good.
Just because they have a maximum inflation rating of 110, doesn't mean you have to fill them that high. The pressure should be commensurate with the load. I run mine at 80 when loaded, 55 empty. Watch the tread wear pattern as a guide. Wear in the center means you have too much pressure and edge wear means too little pressure.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Trailer tires [Re: Hemi_Joel] #3229875
04/29/24 02:23 AM
04/29/24 02:23 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
Tire load carrying capacity is based on the air pressure and volume.
Re: Trailer tires [Re: SNK-EYZ] #3229909
04/29/24 09:20 AM
04/29/24 09:20 AM
Mooresburg, Tn
Mooresburg, Tn
Trailer has steel wheels and I don't find any indication of load capacity on them. I also have good valve stems (not rubber). What brand of 14 ply tires do you run? It looks like a LOT of them are still made in China? The tires that are on there now are made in China (Trailer King RST 235/80r16, LR E speed rated M-81 mph)
Thanks, Brian
Re: Trailer tires [Re: '72CudaRacer] #3229997
04/29/24 03:10 PM
04/29/24 03:10 PM
Boise
Moparteacher Offline
Boise
FWIW, the only USA made trailer tire, that I can find, is the Goodyear Endurance tire. If it matters to ya'.
Re: Trailer tires [Re: Moparteacher] #3230010
04/29/24 03:32 PM
04/29/24 03:32 PM
Knock on wood luck My current Maxxis brand E rated 215x75x15 inch trailer tires are going on their fifth year, maybe their 6th year luck CRS on the exact ear whiney
I hope I'm not jinxing myself now luck
I used it this weekend to go to Madras Drags, around 45 to 50 miles north of me, used it last winter to go from Bend, OR to Glendale, AZ to buy a bracket car for my youngest granddaughter and her Husband to learn to drag race in with those tires on the 24 Ft. Pace shadow enclosed car trailer, it weighed 8650 Lbs. on the axles the last time I weighed it with my old pump gas Duster in it, I hope they like drag racing luck
Re: Trailer tires [Re: '72CudaRacer] #3230040
04/29/24 06:43 PM
04/29/24 06:43 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I run Light truck tires on all my trailers, got sick and tired of blow outs. the LT tires have run for years with no blow outs.
