Hydraulic lifter pre-load
#3229333
04/26/24 02:22 PM
04/26/24 02:22 PM
Posts: 1,449 Martinsville, IN
cdwmotorsports
Martinsville, IN
We swapped heads and to Isky iron rockers and I’m trying to measure for new pushrods. The engine has a hydraulic .509 in it and I can’t seem to find the pre-load number for the lifters anywhere. Can someone please tell me what it is supposed to be?
eBay-cdwmotorsports
Re: Hydraulic lifter pre-load
[Re: Diplomat360]
#3229434
04/27/24 08:50 AM
04/27/24 08:50 AM
Posts: 1,991 Apollo, PA.
B1MAXX
Apollo, PA.
What lifters are you using?
I ask b/c some of them (the anti pump-up ones) will allow you to run a much tighter setup.
My SB favourite are the SpeedPro HT2011R, which are supposed to be installed with 0 (zero) preload. As in: tighten things down until the pushord stops spining/turning between your fingers.
Prior to switching to my current hydraulic roller setup that's what I used, and loved them! I have seen people take that as tighten the adjuster until you collapse all the preload and make it so tight you CAN'T turn the pushrod. lol
[Re: B1MAXX]
#3229513
04/27/24 02:49 PM
04/27/24 02:49 PM
Posts: 8,274 fredericksburg,va
cudaman1969
fredericksburg,va
With my .509 (383) I did zero lash with Isky rockers, tighten till pushrod stops turning, 6800 easy all day You know ‘preload’ is a built in rev limiter to ‘save’ your engine
[Re: fast68plymouth]
#3229601
04/27/24 10:22 PM
04/27/24 10:22 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
Standard lifters should get .030-.040” preload. How about all iron motor compared too iron block with aluminum heads and then aluminum block and heads ?
[Re: B1MAXX]
#3229698
04/28/24 11:31 AM
04/28/24 11:31 AM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I have seen people take that as tighten the adjuster until you collapse all the preload and make it so tight you CAN'T turn the pushrod. lol I honestly can't understand why someone would conclude that is the right setup, given that they are working with adjustable rocker arms already so presumably they must know a little more about valvetrain than the proverbial uninitiated! lol Still...I have no doubt this does happen, and have in fact seen numerous such on-line posts as I investigated the whole topic during my move to the hydraulic roller setup. Even those (which are Comp Cam pieces) I ended up setting up with just 1/4 turn preload.
[Re: Diplomat360]
#3229817
04/28/24 07:54 PM
04/28/24 07:54 PM
cdwmotorsports
Martinsville, IN
Ok so am I under thinking this process? Can i just snug up the checking pushrod against the lifter and the adjustable rocker? and use that measurement -.030? This is all new territory for me, the BB has always just had iron heads, stock rockers and pushrods. I don't want to not complete Dragweek and don't have billions to continually throw at valvetrain parts. Also since the Stealth's only accept 5/16" pushrods without modifications should i do the .118 wall Manton's? The only other Series 3 option at Manton is a .083" wall pushrod
eBay-cdwmotorsports
[Re: cdwmotorsports]
#3230025
04/29/24 04:38 PM
04/29/24 04:38 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
Ok so am I under thinking this process? Can i just snug up the checking pushrod against the lifter and the adjustable rocker? and use that measurement -.030? This is all new territory for me, the BB has always just had iron heads, stock rockers and pushrods. I don't want to not complete Dragweek and don't have billions to continually throw at valvetrain parts. Also since the Stealth's only accept 5/16" pushrods without modifications should i do the .118 wall Manton's? The only other Series 3 option at Manton is a .083" wall pushrod If you are measuring for pushrods, snug the adjuster up with the pushrods until you can just barely feel the pushrod resist turning with your finger. Take that measurement, then ADD your preload to the length of the checking rod for your actual pushrod length. (basically, what you have above, but ADD the preload to your pushrod measurement)
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
