Hemi Torque sequence #3228333
04/20/24 08:27 PM
04/20/24 08:27 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
I’m putting together a 518 ci Hemi
This is a mega block and Indy 426-1 aluminum heads
What is the Torque sequence on a Hemi
I’m using head studs
What should they be torque down to
Top row the same specs
How can you torque the top row from under the valley
My first Hemi motor so I’m new to this
Any tips please
Thank you Ari
1.39 9.85 - 137 mph
Re: Hemi Torque sequence [Re: Ari440] #3228356
04/20/24 11:28 PM
04/20/24 11:28 PM
If your running aluminum heads call the manufactures tech dept and ask them what torque sequence and Ft. lbs. on all the fasteners on your motor.
I seem to remember them being different from stock iron heads to Mopars aluminum heads, maybe different on some of the other brands also. I think the inner studs into the lifter valley use less torque also scope twocents
Way better to get it right to start with, another one of the reasons I call them 426 Hemiroids motors rant shruggy work
Re: Hemi Torque sequence [Re: Ari440] #3228373
04/21/24 08:21 AM
04/21/24 08:21 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
If they are ARP studs they go to 80 ft lbs. with ARP lube. The book calls for 5 lbs less with aluminum heads. Some people go less on the inner studs of some aluminum heads (say 45 lbs on Edelbrock heads) because it can distort the intake valve seat. What size inner nuts do you have? You will need the appropriate torque wrench adapter as pictured below.
2011 Drag Pak Challenger
