Repop T Handle Issues
#3223476
03/29/24 01:40 AM
03/29/24 01:40 AM
Posts: 821 On the open road
Hrtbkr
On the open road
Hi
My slap stik won't rachet with the repop T Handle I have.
It doesn't let the mechanism return up to the notches.
The shifter works fine without the handle installed.
Has anyone else had this issue?
Any solution would be greatly appreciated.
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
Re: Repop T Handle Issues
[Re: B1MAXX]
#3223490
03/29/24 08:30 AM
03/29/24 08:30 AM
Hrtbkr
On the open road
Hi
I tried raising the handle on the mount a bit (as much as an entire screw hole diameter).
Still not releasing
Thanks anyway
[Re: IMGTX]
#3224195
04/01/24 11:08 AM
04/01/24 11:08 AM
Hrtbkr
On the open road
I haven't installed the screw yet. The shifter actuates fine without the handle, everything goes bad after the handle gets installed. It seems like the T handle button is dragging sightly the housing. Being a cheap b*stard, I don't want to risk $50 on another repop.
[Re: Hrtbkr]
#3227241
04/15/24 04:50 PM
04/15/24 04:50 PM
Hrtbkr
On the open road
Update! I installed a friends borrowed T handle and now the shifter rachets properly. If you hold his handle and shake it, the chrome button moves in and out pretty freely. Mine stays retracted no matter how hard you shake. It looks like that's what causing the failure. 'Nother part to find at the swaps...
[Re: moparx]
#3228536
04/22/24 01:58 AM
04/22/24 01:58 AM
Hrtbkr
On the open road
You can pry the chrome bezel off the handle using a putty knife. I ended up sanding/filing the plug, the cavity in the handle, and the bezel. Everything almost had enough clearance It works like a charm now. All it took was a couple of hours of work...
