Repop T Handle Issues #3223476
03/29/24 01:40 AM
03/29/24 01:40 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi
My slap stik won't rachet with the repop T Handle I have.
It doesn't let the mechanism return up to the notches.
The shifter works fine without the handle installed.
Has anyone else had this issue?
Any solution would be greatly appreciated.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Repop T Handle Issues [Re: Hrtbkr] #3223486
03/29/24 08:01 AM
03/29/24 08:01 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
It's where the set screw pulls the T to shifter handle to. As I recall it pulls it down to far on the handle Put the tee on but leave it up a little bit and I bet It works. Then devise the best way to re pin, I want to say I cheated the set screw position up by retapping to #10 and got a new set screw. Been a while, but know exactly what you mean.
Re: Repop T Handle Issues [Re: B1MAXX] #3223490
03/29/24 08:30 AM
03/29/24 08:30 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi
I tried raising the handle on the mount a bit (as much as an entire screw hole diameter).
Still not releasing
Thanks anyway
Re: Repop T Handle Issues [Re: Hrtbkr] #3223491
03/29/24 08:35 AM
03/29/24 08:35 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Sorry worked for me, maybe the little rod sticking up needs tweaked
Re: Repop T Handle Issues [Re: Hrtbkr] #3223492
03/29/24 08:37 AM
03/29/24 08:37 AM
IMGTX Online content
IMGTX  Online Content
On my original one the screw was just slightly too long and would drag on the shaft inside.
Does it work if you loosen the screw?
If it works either grind down the screw tip or glue a small spacer inside the shifter under the screw hole.
Hope it helps.
Re: Repop T Handle Issues [Re: IMGTX] #3224195
04/01/24 11:08 AM
04/01/24 11:08 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
I haven't installed the screw yet.
The shifter actuates fine without the handle, everything goes bad after the handle gets installed.
It seems like the T handle button is dragging sightly the housing.
Being a cheap b*stard, I don't want to risk $50 on another repop.
Re: Repop T Handle Issues [Re: Hrtbkr] #3227241
04/15/24 04:50 PM
04/15/24 04:50 PM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Update!
I installed a friends borrowed T handle and now the shifter rachets properly.
If you hold his handle and shake it, the chrome button moves in and out pretty freely. boogie
Mine stays retracted no matter how hard you shake. It looks like that's what causing the failure. mad
'Nother part to find at the swaps...
Re: Repop T Handle Issues [Re: Hrtbkr] #3227242
04/15/24 04:53 PM
04/15/24 04:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried freeing up the button? Some times a little work can make things work.
Re: Repop T Handle Issues [Re: stumpy] #3227444
04/16/24 12:48 PM
04/16/24 12:48 PM
moparx Offline
moparx  Offline
like the saying goes : "there is no such thing as a "bolt on and go" part"...............
beer
Re: Repop T Handle Issues [Re: moparx] #3228536
04/22/24 01:58 AM
04/22/24 01:58 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
You can pry the chrome bezel off the handle using a putty knife.
I ended up sanding/filing the plug, the cavity in the handle, and the bezel.
Everything almost had enough clearance
It works like a charm now.
All it took was a couple of hours of work...
Re: Repop T Handle Issues [Re: Hrtbkr] #3228746
04/23/24 11:48 AM
04/23/24 11:48 AM
moparx Offline
moparx  Offline
"All it took was a couple of hours of work..."
another saying is : "there is no such thing as a 5 [or 10, 15, 30, 45, etc.] minute [you can also insert hour[s] for minute] job.......... biggrin
as an old "guy" [or insert the description of your choice here] i have discovered this is way more common than one would think.
beer
