1985 Dodge dually 2wd 360 #3226675
04/12/24 09:11 AM
04/12/24 09:11 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1985 Dodge dually 2wd 360 [Re: bigdad] #3226698
04/12/24 10:58 AM
04/12/24 10:58 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Ashtray shot is a huge selling point.
Earning every penny of that moderator paycheck.
DBAP
Re: 1985 Dodge dually 2wd 360 [Re: not_a_charger] #3226716
04/12/24 12:10 PM
04/12/24 12:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ laugh2 Yeah, bet it smells wonderful in there...
Nevertheless, seems like a decent enough price, depending on the problems alluded to.
Seems to me a 360 "ain't enough motor", though I know of a medium-duty car hauler (D600 ?) that ran one well into the 1990s.
Re: 1985 Dodge dually 2wd 360 [Re: topside] #3226757
04/12/24 05:22 PM
04/12/24 05:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If it's truly rust free it's not priced hateful.
Color combo isnt the best. but not hateful either. I could live with it
Perfect candidate for a cummins swap.
Put a bicycle in the back of that and its gonna be underpowered.
Regular cabs trucks are a tough sell though
Re: 1985 Dodge dually 2wd 360 [Re: gtx6970] #3226809
04/12/24 11:58 PM
04/12/24 11:58 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I had a 79 d300 w/ 360 that I put headers and an intake on. Added a hot ignition box too. Ended up at one point pulling the pan and installing a windage tray. It surprised the hell out of people. Made enough more power that I had to go to a centerforce clutch to hold it. I know this one is an auto, but you could wake it up for not much money. I don’t know about a price.
I want my fair share
Re: 1985 Dodge dually 2wd 360 [Re: SomeCarGuy] #3226823
04/13/24 05:46 AM
04/13/24 05:46 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
No mention of overdrive, did they come with it in 85? With no overdrive that 4:10 gear is going to be a beating.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: 1985 Dodge dually 2wd 360 [Re: RapidusMaximus] #3226862
04/13/24 12:08 PM
04/13/24 12:08 PM
A727Tflite Offline
A727Tflite  Offline
No O/D in 85.
Re: 1985 Dodge dually 2wd 360 [Re: RapidusMaximus] #3226869
04/13/24 12:45 PM
04/13/24 12:45 PM
Indianapolis, In. area
BTBelvedere Offline
BTBelvedere  Offline
.[quote=RapidusMaximus]No mention of overdrive, did they come with it in 85? With no overdrive that 4:10 gear is going to be a beating. [/quote
I bought a 1980 D200 in 1982. It was a heavy 3/4 ton (9900 gvw). It had the 360 with a thermoquad, automatic, and 4.10 gears. The speed limit was 55mph then. If I kept it right on 55, I got 10 mpg with the Belvedere on an open trailer. It only had an 18 gallon tank. I could make a round trip to Muncie on a Saturday night and have just enough gas to get to the gas station the next morning.
Re: 1985 Dodge dually 2wd 360 [Re: RapidusMaximus] #3226874
04/13/24 01:17 PM
04/13/24 01:17 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Need to ditch the 4:10s. twocents
Re: 1985 Dodge dually 2wd 360 [Re: bigdad] #3226972
04/14/24 06:55 AM
04/14/24 06:55 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Friend of mine bought that identical truck new, Used it to put a huge boat in and out of nearby lake. And occasionally haul gravel for his driveway. Think it had a Q-jet carb.
Re: 1985 Dodge dually 2wd 360 [Re: redraptor] #3226977
04/14/24 09:03 AM
04/14/24 09:03 AM
BTBelvedere Offline
BTBelvedere  Offline
I had an 88 and it, too, had the Q-jet.
Re: 1985 Dodge dually 2wd 360 [Re: BTBelvedere] #3226987
04/14/24 10:50 AM
04/14/24 10:50 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
My '85 motorhome 360 is a Quadrajet as well,TQs were gone at that point.
Re: 1985 Dodge dually 2wd 360 [Re: BTBelvedere] #3228525
04/21/24 11:35 PM
04/21/24 11:35 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Our first race car tow rig was an '81 with a 360/TQ, 4 SPD with 4.10's. Very solid puller, even with 120,000 miles on it. We even hauled a 9 1/2 ft camper and pulled the car. When I bought that truck I put new plug wires on it, tweaked the TQ and the timing, and ran a single 3" exhaust outlet with no muffler. Exiting at the side, it was only loud at WOT, thanks to the stock manifolds. Before we got the camper, we were heading home from the track, with a friend pulling his Firebird behind a 78 GMC with a 454 right behind us. We hit the bottom of a long grade, and my buddy figured he'd show me how a 454 pulls. I let him get abreast of my car, then I let the ol' Thermo-Bog eat. He never did get better than right alongside me. Then I actually pulled away. I know. I know. 454's were generally better pullers than 360's. But, a 360 with 4.10's, pulling 4500 lbs, could easily run with a 454 pulling similar, using 3.42's. Double those trailer weights, and that 360's out of its depth.
