Re: line lock and proportioning valve location [Re: bigdad] #3226286
04/10/24 02:19 PM
04/10/24 02:19 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
My line lock is on lower frame rail , look right below the roll bar tube
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: line lock and proportioning valve location [Re: bigdad] #3226386
04/10/24 11:13 PM
04/10/24 11:13 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
My p valve is just right of the M/C
You’ve got your prop valve plumbed into your front brakes !!
The rear reservoir in the m/c is for the front brakes.
Re: line lock and proportioning valve location [Re: HardcoreB] #3226387
04/10/24 11:20 PM
04/10/24 11:20 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Rear port MC to prop valve IN. Prop OUT to line-loc IN. Line-loc OUTLETS to front brakes.
Prop valve should be on rear brakes. No ???
Re: line lock and proportioning valve location [Re: Stanton] #3226414
04/11/24 06:42 AM
04/11/24 06:42 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Plate pic. I made the spacing long enough that i could turn the front outlet line behind this plate.
Re: line lock and proportioning valve location [Re: HardcoreB] #3226416
04/11/24 06:59 AM
04/11/24 06:59 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Followed the line down to the caliper for ya.
Re: line lock and proportioning valve location [Re: HardcoreB] #3226418
04/11/24 07:11 AM
04/11/24 07:11 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The line to the pass side is 'anchored' at a point mid-engine and again along the pass frame rail. I put a piece of rubber hose on the line to bridge it off the firewall and bent the line so it wants to touch the firewall without the hose/insulator.
Re: line lock and proportioning valve location [Re: Stanton] #3226436
04/11/24 09:24 AM
04/11/24 09:24 AM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Originally Posted by Stanton
Quote
ok
Re: line lock and proportioning valve location [Re: bigdad] #3226472
04/11/24 12:15 PM
04/11/24 12:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
If it is a track specific only car with front runners and an aftermarket master, it should be in the front. Think about the braking ability of front runners versus slicks/radials. Just my .02
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: line lock and proportioning valve location [Re: BloFish] #3226481
04/11/24 12:55 PM
04/11/24 12:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I never use a prop valve just buy the correct master cylinder to begin with......
Re: line lock and proportioning valve location [Re: Al_Alguire] #3226482
04/11/24 01:02 PM
04/11/24 01:02 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I didn't feel like arguing about so I just agreed, and only reason I put one on is its a cool old ( nos) direct connection one .. driven the car, seems to work fine
Re: line lock and proportioning valve location [Re: bigdad] #3226527
04/11/24 05:27 PM
04/11/24 05:27 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I wasn’t looking for an argument, just an explanation. Everything you read says it should go in the rear brake line. If you’re only installing it “for looks” then I suppose it doesn’t matter. A few years ago a guy brought a nicely restored ‘69 GTX into my buddy’s shop to have him install a line lock - in a very specific place - solely because he thought it would give the car some credibility - he wasn’t shy about admitting he’d never use it !!
Re: line lock and proportioning valve location [Re: HardcoreB] #3226531
04/11/24 05:51 PM
04/11/24 05:51 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Hardcore , will /or did you add a heat shield under your M/C & brake lines- line loc ? May just be the pic but looks close . And a super way to mount as well !! Thanks Gary
Re: line lock and proportioning valve location [Re: BloFish] #3226641
04/12/24 06:23 AM
04/12/24 06:23 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
This was the theory that I built my system around.
Re: line lock and proportioning valve location [Re: Gabby63] #3226642
04/12/24 06:39 AM
04/12/24 06:39 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The routing is close enough that, if I had a daily driver, I MAY have rerouted the lines. My car has no inner fenders and underhood air is pretty free circulating. I know of a few cars that see street duty that have routing much closer but, use your own discretion. With all this said, the lines are not as close as the pics probably show. I appreciate the compliment and I'm racking my brain to remember if I stole the idea or created it. This is one reason I share with pics and details what I have done because I recognize that many others were before me. Another is to be open to alternative suggestions or ideas.
