Installing rear strut rod nuts #3226086
04/09/24 04:49 PM
04/09/24 04:49 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I just installed new hotchkis adjustable strut rods on my cuda, and unfortunately, even with the price they charge, they make you reuse the 50 year old hardware. I removed the original nuts from the strut rods and they came off fairly easily and the threads look good as well. However, when I go to install them onto the new strut rods, they feel like they are wanting to cross thread after a while. Is this normal due to them being ovaled from the factory to help keep them locked in place once tightened, or is there something that I'm missing?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Installing rear strut rod nuts [Re: 73cuda340] #3226130
04/09/24 07:58 PM
04/09/24 07:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Get new hardware. Use jam nuts.
Re: Installing rear strut rod nuts [Re: CMcAllister] #3226151
04/09/24 08:55 PM
04/09/24 08:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
For a non stock application, use nylocs
Re: Installing rear strut rod nuts [Re: Stanton] #3226175
04/09/24 11:01 PM
04/09/24 11:01 PM
clarks summit pa
clarks summit pa
Does anyone know what size they are? I believe 9/16-18 but I'm not positive.
