Best K member for Hellcrate swap? #3212743
02/11/24 12:14 PM
02/11/24 12:14 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Trying to do a little research on a Hellcrate swap into a 70 Challenger. What K member would you suggest as being the best for a street swap. I really want to go with the rack and pinion steering also. Is Magnum Force the best bet? RMS? Thanks in advance
Re: Best K member for Hellcrate swap? [Re: 70VcodeCoronetRT] #3212882
02/11/24 09:14 PM
02/11/24 09:14 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
In my view, the Altercation is the best setup to run with a G3....I have two Magnuforce ones, and I think the Altercation is better due to it has its own upper coil over mounts vs using the OEM shock position...I think the geometry is better...Plus, they make tubular motor mounts for a G3 to their K-member.
Re: Best K member for Hellcrate swap? [Re: Dragula] #3213401
02/14/24 04:48 AM
02/14/24 04:48 AM
Netherlands
72Challenger Offline
Netherlands
With my build of a 70 Challenger with Hellcrate - 6sp manual etc. I used QA1 subframe with stock (reinforced) lower arms, adjustable SPC upper arms, adjustable strud rods, Borgeson steering box, Hotchkiss heim tie rods and sleeves, QA1 swaybar along with Ridetech air ride.
Perfect ride for the street.
Oh and uses Milodon oil pan.
Re: Best K member for Hellcrate swap? [Re: 72Challenger] #3225951
04/09/24 02:55 AM
04/09/24 02:55 AM
Which Milidon oil pan?
I'm wanting to put a Gen 3 in a 1967 Satellite so that oil pan should work in it also up luck work
Thanks in advance bow up: Cab
Re: Best K member for Hellcrate swap? [Re: Cab_Burge] #3228722
04/23/24 10:09 AM
04/23/24 10:09 AM
Netherlands
Netherlands
Hi Cab,
I believe I have used the Milodon 31030 pan with 18341 pickup.
Hope this helps.
Re: Best K member for Hellcrate swap? [Re: 72Challenger] #3230253
04/30/24 02:45 PM
04/30/24 02:45 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the AlterKation in my 70 Challenger but with a 2ND Gen Hemi. No complaints about any of it after 1000's of street miles and plenty of strip passes.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
