Re: Bogus Valve Adjuster - WTH ?
[Re: 572B1]
#3225714
04/08/24 05:22 AM
04/08/24 05:22 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I believe the adjuster WITHOUT the locking nut is the OEM adjuster. They are an interference fit designed to not use a locking nut. The others are an aftermarket replacement with the familiar adjusting screw with locking/lockdown nut. As mentioned, replace them all with Smith Bros components. Maybe ensure the surface the locking nut will seat down onto is filed down flat so the nut is not forced to seat against an irregular surface.
Keep old mopars alive.
[Re: 572B1]
#3225749
04/08/24 10:15 AM
04/08/24 10:15 AM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Smith bros or manton and replace all of them in the correct length. That's what I think. Those look like 1-1/2" and that's too long. Get a set of 1-1/4". And these new ones will have a larger hex in the end. Mo better.
2011 Drag Pak Challenger
[Re: rickseeman]
#3225754
04/08/24 10:44 AM
04/08/24 10:44 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Smith bros or manton and replace all of them in the correct length. That's what I think. Those look like 1-1/2" and that's too long. Get a set of 1-1/4". And these new ones will have a larger hex in the end. Mo better. The one oddball adjuster there is the factory original adjuster for those rockers.
[Re: 2boltmain]
#3225778
04/08/24 12:25 PM
04/08/24 12:25 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I believe the adjuster WITHOUT the locking nut is the OEM adjuster. They are an interference fit designed to not use a locking nut. And when the interference fit becomes loose, only way to save the rocker is to run a tap through the threads and use an adjuster that needs a locknut.
[Re: John_Kunkel]
#3225817
04/08/24 02:01 PM
04/08/24 02:01 PM
Posts: 20,774 A collage of whims
topside
A collage of whims
Thankfully, the mini-me screw came out smoothly. No other sign of buggery, hope they didn't drop the proper hardware into the machinery I'll make that adjuster available as a genuine original MoPar part for that last correct-numbers-and-codes detail Smith Bros to the rescue...
[Re: topside]
#3225906
04/08/24 08:44 PM
04/08/24 08:44 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
It's the amount of adjuster sticking out the bottom that really matters.
