Re: line lock and proportioning valve location
[Re: bigdad]
#3226286
04/10/24 02:19 PM
04/10/24 02:19 PM
Posts: 34,974 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
My line lock is on lower frame rail , look right below the roll bar tube
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#3226386
04/10/24 11:13 PM
04/10/24 11:13 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
My p valve is just right of the M/C You’ve got your prop valve plumbed into your front brakes !! The rear reservoir in the m/c is for the front brakes.
[Re: HardcoreB]
#3226387
04/10/24 11:20 PM
04/10/24 11:20 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Rear port MC to prop valve IN. Prop OUT to line-loc IN. Line-loc OUTLETS to front brakes. Prop valve should be on rear brakes. No ???
[Re: Stanton]
#3226436
04/11/24 09:24 AM
04/11/24 09:24 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
My p valve is just right of the M/C You’ve got your prop valve plumbed into your front brakes !! The rear reservoir in the m/c is for the front brakes. ok
[Re: bigdad]
#3226472
04/11/24 12:15 PM
04/11/24 12:15 PM
Posts: 16,554 On the run…
BloFish
On the run…
If it is a track specific only car with front runners and an aftermarket master, it should be in the front. Think about the braking ability of front runners versus slicks/radials. Just my .02
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3226481
04/11/24 12:55 PM
04/11/24 12:55 PM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
FWIW I never use a prop valve just buy the correct master cylinder to begin with......
[Re: Al_Alguire]
#3226482
04/11/24 01:02 PM
04/11/24 01:02 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I didn't feel like arguing about so I just agreed, and only reason I put one on is its a cool old ( nos) direct connection one .. driven the car, seems to work fine
[Re: bigdad]
#3226527
04/11/24 05:27 PM
04/11/24 05:27 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I didn't feel like arguing about so I just agreed, and only reason I put one on is its a cool old ( nos) direct connection one .. driven the car, seems to work fine I wasn’t looking for an argument, just an explanation. Everything you read says it should go in the rear brake line. If you’re only installing it “for looks” then I suppose it doesn’t matter. A few years ago a guy brought a nicely restored ‘69 GTX into my buddy’s shop to have him install a line lock - in a very specific place - solely because he thought it would give the car some credibility - he wasn’t shy about admitting he’d never use it !!
[Re: BloFish]
#3226641
04/12/24 06:23 AM
04/12/24 06:23 AM
Posts: 4,105 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
If it is a track specific only car with front runners and an aftermarket master, it should be in the front. Think about the braking ability of front runners versus slicks/radials. Just my .02 This was the theory that I built my system around.
[Re: Gabby63]
#3226642
04/12/24 06:39 AM
04/12/24 06:39 AM
HardcoreB
Shelby Twp. Mi
Hardcore , will /or did you add a heat shield under your M/C & brake lines- line loc ? May just be the pic but looks close . And a super way to mount as well !! Thanks Gary The routing is close enough that, if I had a daily driver, I MAY have rerouted the lines. My car has no inner fenders and underhood air is pretty free circulating. I know of a few cars that see street duty that have routing much closer but, use your own discretion. With all this said, the lines are not as close as the pics probably show. I appreciate the compliment and I'm racking my brain to remember if I stole the idea or created it. This is one reason I share with pics and details what I have done because I recognize that many others were before me. Another is to be open to alternative suggestions or ideas.
