904 tailshaft removal in car #3223803
03/30/24 08:44 PM
03/30/24 08:44 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
I need to change the tailshaft bushing in my 904. Will the tailshaft come off in an a body without removing the trans? I can't think of any other way to get the bushing out in the car.
I put a fresh one in before drag week last year and it was smoked by the end of the week, has some play in it and leaking. What would cause that? Drivetrain runs nice and smooth. I do have a heavy 3.5" steel driveshaft. I did learn I can clock the bushing differently and get pressurized oil to it vs splash oiling so I will be doing that.
68 Barracuda Formula S 340
Re: 904 tailshaft removal in car [Re: Bad340fish] #3223838
03/30/24 09:49 PM
03/30/24 09:49 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
it will come off
pull drive saft
remove trans mount , speedo gear
remove housing
Re: 904 tailshaft removal in car [Re: calrobb2000] #3223846
03/30/24 10:04 PM
03/30/24 10:04 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Originally Posted by calrobb2000
it will come off
pull drive saft
remove housing
. You left out 2 steps, remove 2 screws that hide snap ring, use snap rings pliers to open snap ring, pull housing.
Without Data, you’re just another guy with an opinion.
Re: 904 tailshaft removal in car [Re: sr4440] #3223848
03/30/24 10:15 PM
03/30/24 10:15 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I got a bushing remover tool and an installer tool off of Amazon or E-Bay. You can do the bushing without removing the housing. It takes the same tools as a C-4 Ford. I don't remember the toold being very expensive.
Re: 904 tailshaft removal in car [Re: slantzilla] #3223910
03/31/24 09:51 AM
03/31/24 09:51 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Piston ring expender works well for the tail shaft bearing snap ring.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 904 tailshaft removal in car [Re: slantzilla] #3223919
03/31/24 10:44 AM
03/31/24 10:44 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
That's good to hear. (Takes same tool as a C4)
I just got a set of bushing drivers from eBay for the 727/518 tranny's, was pretty cheap. I think the front pump bushing is the same as a TH350 or 400 as well
Re: 904 tailshaft removal in car [Re: Bad340fish] #3223978
03/31/24 12:30 PM
03/31/24 12:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Before removing the housing, placed the shifter in Park and rotate the driveshaft until you hear the parking pawl engage. Makes the park rod (if equipped) slide out of the housing easier.
Re: 904 tailshaft removal in car [Re: John_Kunkel] #3224089
03/31/24 06:28 PM
03/31/24 06:28 PM
Tulsa OK
Tulsa OK
Great news, thanks for the replies. I will look for that bushing puller first, if I can't find one I will just pull the housing. Just working out of a two car garage I have to setup differently for a small job vs a transmission pull.
Re: 904 tailshaft removal in car [Re: John_Kunkel] #3224161
04/01/24 08:47 AM
04/01/24 08:47 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Honestly this is probably the most important part of the whole job. You'll thank yourself if you do this part!
If you don't, you'll likely end up needing to take the pan off and valve body out when you go to re-install everything if you forget this step.
Re: 904 tailshaft removal in car [Re: dizuster] #3224189
04/01/24 11:00 AM
04/01/24 11:00 AM
Central US
grancuda Offline
grancuda  Offline
Central US
I had to take my engine mounts loose, header collector bolts out & remove the trans mount crossmember in order to lower the back of transmission to allow the housing to clear the torsion crossmember above the housing so the engine/transmission as a whole had to tilt down at the back for it to slide off, in my ‘67 Barracuda.
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: 904 tailshaft removal in car [Re: grancuda] #3224247
04/01/24 12:55 PM
04/01/24 12:55 PM
Park Forest, IL
Park Forest, IL
Tool
$91 for the pair on the Bag.
Re: 904 tailshaft removal in car [Re: FurryStump] #3224301
04/01/24 03:11 PM
04/01/24 03:11 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Have you thought about switching to a 4 speed, and getting rid of that maintenance problem child? Probably make your life less stressful.
69 GTX 68 Road Runner
Re: 904 tailshaft removal in car [Re: JERICOGTX] #3224338
04/01/24 05:13 PM
04/01/24 05:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
laugh2 drive
Re: 904 tailshaft removal in car [Re: JERICOGTX] #3224344
04/01/24 05:27 PM
04/01/24 05:27 PM
Tulsa OK
Tulsa OK
Yeah this little trans is terrible. All stock internal parts and it has needed 2 extension housing bushings after 3 drag weeks. Total junk! argue grin
Re: 904 tailshaft removal in car [Re: Bad340fish] #3224353
04/01/24 06:23 PM
04/01/24 06:23 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
What about that time it leaked like the Exxon Valdez, backing into a car show? That’s double embarrassment.
Re: 904 tailshaft removal in car [Re: Bad340fish] #3224409
04/02/24 12:18 AM
04/02/24 12:18 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
HI
tell me how you are going to get pressurized oil to rear bushing by clocking it diff .
no pressure in the area of that bushing ! splash only !
Re: 904 tailshaft removal in car [Re: calrobb2000] #3224419
04/02/24 02:05 AM
04/02/24 02:05 AM
HI
Correct up scope
Re: 904 tailshaft removal in car [Re: Cab_Burge] #3224436
04/02/24 08:10 AM
04/02/24 08:10 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
There is a correct orientation though. You can't just throw them in there.
Re: 904 tailshaft removal in car [Re: calrobb2000] #3224452
04/02/24 10:08 AM
04/02/24 10:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
HI
Clark this ^^^ , there is no pressurized fluid circuit past the govenor, where did you find that info ?
If you are taking out the bushing check to make sure balance of the shaft is good , pinon angle is good and check the bearing in the tailhousing that the mainshft of the trans rides in is not loose
Re: 904 tailshaft removal in car [Re: JohnRR] #3224475
04/02/24 11:49 AM
04/02/24 11:49 AM
Tulsa OK
Tulsa OK
Ok I went back to my email about that. It was not pressurized oiling, but it was suggested I clock the bushing hole at 4 o'clock instead of 12 o'clock because there is another oil hole at that location that might deliver more splash oiling.
