904 tailshaft removal in car
#3223803
03/30/24 08:44 PM
03/30/24 08:44 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I need to change the tailshaft bushing in my 904. Will the tailshaft come off in an a body without removing the trans? I can't think of any other way to get the bushing out in the car.
I put a fresh one in before drag week last year and it was smoked by the end of the week, has some play in it and leaking. What would cause that? Drivetrain runs nice and smooth. I do have a heavy 3.5" steel driveshaft. I did learn I can clock the bushing differently and get pressurized oil to it vs splash oiling so I will be doing that.
68 Barracuda Formula S 340
Re: 904 tailshaft removal in car
[Re: calrobb2000]
#3223846
03/30/24 10:04 PM
03/30/24 10:04 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
it will come off
pull drive saft
remove trans mount , speedo gear
remove housing
. You left out 2 steps, remove 2 screws that hide snap ring, use snap rings pliers to open snap ring, pull housing.
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3223848
03/30/24 10:15 PM
03/30/24 10:15 PM
Posts: 20,176 Park Forest, IL
slantzilla
Park Forest, IL
I got a bushing remover tool and an installer tool off of Amazon or E-Bay. You can do the bushing without removing the housing. It takes the same tools as a C-4 Ford. I don't remember the toold being very expensive.
[Re: Bad340fish]
#3223978
03/31/24 12:30 PM
03/31/24 12:30 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Before removing the housing, placed the shifter in Park and rotate the driveshaft until you hear the parking pawl engage. Makes the park rod (if equipped) slide out of the housing easier.
[Re: John_Kunkel]
#3224089
03/31/24 06:28 PM
03/31/24 06:28 PM
Bad340fish
Tulsa OK
Great news, thanks for the replies. I will look for that bushing puller first, if I can't find one I will just pull the housing. Just working out of a two car garage I have to setup differently for a small job vs a transmission pull.
[Re: John_Kunkel]
#3224161
04/01/24 08:47 AM
04/01/24 08:47 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Honestly this is probably the most important part of the whole job. You'll thank yourself if you do this part! If you don't, you'll likely end up needing to take the pan off and valve body out when you go to re-install everything if you forget this step.
[Re: dizuster]
#3224189
04/01/24 11:00 AM
04/01/24 11:00 AM
Posts: 1,005 Central US
grancuda
Central US
I had to take my engine mounts loose, header collector bolts out & remove the trans mount crossmember in order to lower the back of transmission to allow the housing to clear the torsion crossmember above the housing so the engine/transmission as a whole had to tilt down at the back for it to slide off, in my ‘67 Barracuda.
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
[Re: grancuda]
#3224247
04/01/24 12:55 PM
04/01/24 12:55 PM
slantzilla
Park Forest, IL
Tool$91 for the pair on the Bag.
[Re: FurryStump]
#3224301
04/01/24 03:11 PM
04/01/24 03:11 PM
Posts: 10,022 MN
JERICOGTX
MN
Have you thought about switching to a 4 speed, and getting rid of that maintenance problem child? Probably make your life less stressful.
69 GTX
68 Road Runner
[Re: Bad340fish]
#3224353
04/01/24 06:23 PM
04/01/24 06:23 PM
Posts: 10,022 MN
JERICOGTX
MN
Have you thought about switching to a 4 speed, and getting rid of that maintenance problem child? Probably make your life less stressful. Yeah this little trans is terrible. All stock internal parts and it has needed 2 extension housing bushings after 3 drag weeks. Total junk! What about that time it leaked like the Exxon Valdez, backing into a car show? That’s double embarrassment.
69 GTX
68 Road Runner
[Re: calrobb2000]
#3224452
04/02/24 10:08 AM
04/02/24 10:08 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
HI
tell me how you are going to get pressurized oil to rear bushing by clocking it diff .
no pressure in the area of that bushing ! splash only !
Clark this ^^^ , there is no pressurized fluid circuit past the govenor, where did you find that info ? If you are taking out the bushing check to make sure balance of the shaft is good , pinon angle is good and check the bearing in the tailhousing that the mainshft of the trans rides in is not loose
[Re: JohnRR]
#3224475
04/02/24 11:49 AM
04/02/24 11:49 AM
Bad340fish
Tulsa OK
Ok I went back to my email about that. It was not pressurized oiling, but it was suggested I clock the bushing hole at 4 o'clock instead of 12 o'clock because there is another oil hole at that location that might deliver more splash oiling.
