1966 Carter AFB rebuild question?
#3223543
03/29/24 01:36 PM
03/29/24 01:36 PM
Posts: 1,814 North Dakota
Azzkikrcuda
North Dakota
Guy brought me and Older AFB to rebuild and I know someones been thru it before. The Question is does anybody know which way the rear boosters are supposed to be installed? Air bleed hole to the front or the rear, It can be installed either way. I searched pics online and can find them installed both ways. Anyone know for sure, Thanks.
The only Carbs I care about are under the hood!
Re: 1966 Carter AFB rebuild question?
[Re: Azzkikrcuda]
#3223559
03/29/24 03:34 PM
03/29/24 03:34 PM
Posts: 154 Indianapolis, In. area
BTBelvedere
Try this. Or this link https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.corvetteforum.com%2Fforums%2Fattachments%2Fc1-and-c2-corvettes%2F48329620d1676143299-afb-avs-servicemanual-cartercarburetor-cm01610.pdf&psig=AOvVaw0SQDVX-ctZ4VuirshHcP1V&ust=1711826929969000&source=images&cd=vfe&opi=89978449&ved=0CBQQjhxqFwoTCPCy6rSamoUDFQAAAAAdAAAAABAE
[Re: TJP]
#3223626
03/30/24 12:42 AM
03/30/24 12:42 AM
Azzkikrcuda
North Dakota
It is a model 4131S off a 1966 Sport Fury. That is a Nice breakdown but no good pics or info about the secondary
[Re: Cab_Burge]
#3223721
03/30/24 02:19 PM
03/30/24 02:19 PM
Posts: 1,531 AZ
Mike P
AZ
".............The later rear boosters have a small alignment notch cut in the booster bodies that will not allow you to swap them to the wrong sides in the rear........" I believe this carb has them. I circled the area that has the cutout and there should be a corresponding raised area inside the carburetor. Carb-AFB by M Patterson, on Flickr
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Mike P]
#3223774
03/30/24 06:52 PM
03/30/24 06:52 PM
Azzkikrcuda
North Dakota
Carb body does Not have any casting that prevents installing the boosters from being installed the other way.
[Re: B1MAXX]
#3223987
03/31/24 12:49 PM
03/31/24 12:49 PM
Azzkikrcuda
North Dakota
I just put it back together the same way it came apart. Will run it after the car is back together and see if there are any issues.
[Re: Azzkikrcuda]
#3224054
03/31/24 04:04 PM
03/31/24 04:04 PM
Posts: 8,639 fredericksburg,va
cudaman1969
fredericksburg,va
I just checked two and both had air holes toward front of carb not to back, need a pic?
