1966 Carter AFB rebuild question? #3223543
03/29/24 01:36 PM
03/29/24 01:36 PM
North Dakota
Azzkikrcuda Offline OP
North Dakota
Guy brought me and Older AFB to rebuild and I know someones been thru it before. The Question is does anybody know which way the rear boosters are supposed to be installed? Air bleed hole to the front or the rear, It can be installed either way. I searched pics online and can find them installed both ways. Anyone know for sure, Thanks.
The only Carbs I care about are under the hood!
Re: 1966 Carter AFB rebuild question? [Re: Azzkikrcuda] #3223559
03/29/24 03:34 PM
03/29/24 03:34 PM
Indianapolis, In. area
BTBelvedere Offline
BTBelvedere  Offline
Try this. Or this link https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.corvetteforum.com%2Fforums%2Fattachments%2Fc1-and-c2-corvettes%2F48329620d1676143299-afb-avs-servicemanual-cartercarburetor-cm01610.pdf&psig=AOvVaw0SQDVX-ctZ4VuirshHcP1V&ust=1711826929969000&source=images&cd=vfe&opi=89978449&ved=0CBQQjhxqFwoTCPCy6rSamoUDFQAAAAAdAAAAABAE
Re: 1966 Carter AFB rebuild question? [Re: Azzkikrcuda] #3223598
03/29/24 09:57 PM
03/29/24 09:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Do you have a number on the carb? Everting I'm seeing shows the boosters rear mounted confused
Re: 1966 Carter AFB rebuild question? [Re: TJP] #3223626
03/30/24 12:42 AM
03/30/24 12:42 AM
North Dakota
North Dakota
It is a model 4131S off a 1966 Sport Fury. That is a Nice breakdown but no good pics or info about the secondary
Re: 1966 Carter AFB rebuild question? [Re: TJP] #3223655
03/30/24 09:24 AM
03/30/24 09:24 AM
Sour Lake, Texas
61-63 Offline
61-63  Offline
Sour Lake, Texas
Some Mopar AFBs mount the secondary boosters at the sides as his carb does. His primary boosters are mounted correctly but I would have to remove the secondary boosters and look at their mounting surfaces to determine if they are?
Re: 1966 Carter AFB rebuild question? [Re: 61-63] #3223676
03/30/24 10:41 AM
03/30/24 10:41 AM
North Dakota
North Dakota
Pic of it apart.
Re: 1966 Carter AFB rebuild question? [Re: Azzkikrcuda] #3223679
03/30/24 10:59 AM
03/30/24 10:59 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I have three different 66 FSM's. All of them show essentially the same picture of this part of the carb. None of them are really clear enough to see that bleed hole.
Maybe, if you squint really hard and had to pick a spot, towards the primaries.
However, the FSM is very specific about making sure the primary venturies are replaced in their original locations, but those are pretty obvious how they have to go. Not a peep about the secondaries, so I am thinking it does not matter.
Re: 1966 Carter AFB rebuild question? [Re: Azzkikrcuda] #3223697
03/30/24 12:19 PM
03/30/24 12:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
The front boosters will only go in one way correctly due to the vent tubes, the rears you should be able to look at the mating surfaces on the bottom of the boosters and make sure the fuel transfer slots align with the base scope wrench twocents
The later rear boosters have a small alignment notch cut in the booster bodies that will not allow you to swap them to the wrong sides in the rear scope up
Re: 1966 Carter AFB rebuild question? [Re: Cab_Burge] #3223721
03/30/24 02:19 PM
03/30/24 02:19 PM
AZ
Mike P Offline
Mike P  Offline
AZ
".............The later rear boosters have a small alignment notch cut in the booster bodies that will not allow you to swap them to the wrong sides in the rear........"
I believe this carb has them. I circled the area that has the cutout and there should be a corresponding raised area inside the carburetor.
[Linked Image]Carb-AFB by M Patterson, on Flickr
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 1966 Carter AFB rebuild question? [Re: Mike P] #3223774
03/30/24 06:52 PM
03/30/24 06:52 PM
North Dakota
North Dakota
Carb body does Not have any casting that prevents installing the boosters from being installed the other way.
Re: 1966 Carter AFB rebuild question? [Re: Azzkikrcuda] #3223898
03/31/24 08:34 AM
03/31/24 08:34 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
looking at the boster /casting the the air bleed looks to go to the main well and the two outer holes are blind in the main body. So it looks to me like it doesn't matter. Maybe that's why they aren't keyed in any way.
Re: 1966 Carter AFB rebuild question? [Re: B1MAXX] #3223923
03/31/24 11:10 AM
03/31/24 11:10 AM
All the AFB I've worked on a left and right side rear booster, same on the front boosters shruggy
Re: 1966 Carter AFB rebuild question? [Re: B1MAXX] #3223987
03/31/24 12:49 PM
03/31/24 12:49 PM
North Dakota
North Dakota
I just put it back together the same way it came apart. Will run it after the car is back together and see if there are any issues.
Re: 1966 Carter AFB rebuild question? [Re: Azzkikrcuda] #3224054
03/31/24 04:04 PM
03/31/24 04:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I just checked two and both had air holes toward front of carb not to back, need a pic?
Re: 1966 Carter AFB rebuild question? [Re: cudaman1969] #3224167
04/01/24 09:49 AM
04/01/24 09:49 AM
North Dakota
North Dakota
Thanks for the info.
Re: 1966 Carter AFB rebuild question? [Re: Azzkikrcuda] #3224467
04/02/24 11:15 AM
04/02/24 11:15 AM
VA
dragon slayer Offline
VA
If you can read the number the 828 goes on side opposite of accelerator pump. The 829 goes on the pump side.
