'68 A-body dash pads #3223534
03/29/24 12:29 PM
03/29/24 12:29 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Are they one-year-only because of the lower pads ?
My A-bodies so far have been '70-up, except for a '68 Barracuda (with the lower pads).
I seem to recall that the '68 upper pad extended further down than my '70-up Dusters.
Wondering if a '67 upper pad interchanges with a '68.
Re: '68 A-body dash pads [Re: topside] #3223569
03/29/24 05:53 PM
03/29/24 05:53 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
68 is unique. There is a portion at end that sort off interlocks/fit in the lower section. When you put a 69-76 you will see pinching.
67 profile is unique, but it will physically interchange with 69-76.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: '68 A-body dash pads [Re: autoxcuda] #3223572
03/29/24 06:27 PM
03/29/24 06:27 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks - figured either you and/or Rhino would be The Word on that !
Re: '68 A-body dash pads [Re: topside] #3223587
03/29/24 09:15 PM
03/29/24 09:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No problem.
Here is a picture showing the difference. Dark red is 69-up. Green is '68 only
Thread with more pictures: https://board.moparts.org/ubbthread...08/1968-dodge-dart-dash-replacement.html
Re: '68 A-body dash pads [Re: autoxcuda] #3223605
03/29/24 10:08 PM
03/29/24 10:08 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
If the length was the same, looks like the later pad could be modified to work.
But my memory is that the length of the later sides is shorter.
I have a line on a '67 pad, but that's another different style, IIRC.
Re: '68 A-body dash pads [Re: topside] #3223606
03/29/24 10:10 PM
03/29/24 10:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
People have tried to cut the ends and make the 69-76 work, but it always looks like crap. ABC Moparts is making the 68 pads now...
JB Rhinehart, Realist
A-Body's RULE!
Re: '68 A-body dash pads [Re: Rhinodart] #3223609
03/29/24 10:17 PM
03/29/24 10:17 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks - At $499 & the wait, I think I might try a repair first.
I'll know more about my predicament when the car shows up tomorrow...
Re: '68 A-body dash pads [Re: topside] #3223672
03/30/24 10:32 AM
03/30/24 10:32 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a couple 68 pads that each have one small crack in them, can't easily tell on the one. I would let either one go for $250...
A-Body's RULE!
Re: '68 A-body dash pads [Re: Rhinodart] #3223680
03/30/24 11:10 AM
03/30/24 11:10 AM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
I'll PM you.
Re: '68 A-body dash pads [Re: topside] #3223783
03/30/24 07:47 PM
03/30/24 07:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
PG classics made pads at one point. Used to be under $500.
Still make them?
