Low deck Indy 540 on the dyno
#3222925
03/26/24 03:42 PM
03/26/24 03:42 PM
Posts: 31,036 Oregon
AndyF
Low deck 540, Indy aluminum block, Indy 440-1 heads, Indy 400-2 intake. Roller cam but owner didn't have cam card, thinks it is an Indy cam. 1050 carb. Drag race engine. Owner was told it makes 900 hp but we'll see. We're getting it ready to run now, should have numbers later in the week. Engine has some good parts in it, Jesel belt drive, T&D rockers, etc.
Re: Low deck Indy 540 on the dyno
[Re: AndyF]
#3222958
03/26/24 06:24 PM
03/26/24 06:24 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
900 hp with 440-1 is doable, but a high water mark. This will be interesting, especially all the parts that went into it. If i remember correctly your 514 build left few stones unturned in the quest for NA power at that level .
[Re: 6PKRTSE]
#3223031
03/27/24 07:13 AM
03/27/24 07:13 AM
Posts: 4,049 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Assuming it's one I saw listed not long ago with car and performance numbers... I'd guess 800. Like has been said it has some pretty nice pieces and still not a bad motor performance-wise!
[Re: HardcoreB]
#3223045
03/27/24 09:50 AM
03/27/24 09:50 AM
Posts: 2,505 PA
moparacer
PA
That is pretty much exactly what I want to build for my car.
Any idea on compression? Will have to be pretty high to get 900.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: AndyF]
#3223056
03/27/24 10:35 AM
03/27/24 10:35 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Awesome.
Agree with previous post, I'd expect a 13:1 compression ratio and up.
Rich H.
Esse Quam Videri
[Re: AndyF]
#3223066
03/27/24 10:53 AM
03/27/24 10:53 AM
Posts: 403 Laredo, Texas USA
hugo
Laredo, Texas USA
Very similar to mine. My heads were old version of indy 440-1 ported by Larry Smith. Same intake with adapter to dominator also ported by Larry. mine made 890 hp at 7200rpm and 755tq at 5900rpm. This one should be around the same. My compression was 13.9.
[Re: cl440]
#3223153
03/27/24 02:43 PM
03/27/24 02:43 PM
AndyF
Only way it gets close is if the heads are fully ported equal to the 345CC versions and the cam is large enough to support the airflow needed to make 900hp. I think its gonna be good but fall somewhere in the 850 range give or take 20. It does have the CNC 345 heads on it and the cam specs on the old build sheet are 282/290 R113. I'm not sure if that is an old Indy cam or not. Customer's carb is a Holley 80672 1050 three circuit. It was way too rich so we swapped on the dyno room 1050.
[Re: AndyF]
#3223361
03/28/24 01:56 PM
03/28/24 01:56 PM
Posts: 16,925 NC
440Jim
NC
It does have the CNC 345 heads on it and the cam specs on the old build sheet are 282/290 R113. I'm not sure if that is an old Indy cam or not. Customer's carb is a Holley 80672 1050 three circuit. It was way too rich so we swapped on the dyno room 1050. 282/290 on 113 LSA sounds good to me. With at least 13.0 CR, it should make good power 840-875 Close to Indy cam specs, but not a match. What size dia & length are the dyno headers. That will affect things too.
[Re: gregsdart]
#3225248
04/05/24 03:10 PM
04/05/24 03:10 PM
AndyF
That engine didn't do as well as expected. It made 815 hp at 6900 RPM. The vacuum pump that the customer brought was wore out so it didn't pull much vacuum. Once he gets his pump rebuilt the engine will probably make around 825. Not sure why the power was down. The parts he had seemed capable of more. I'm not a fan of using a 4500 to 4150 adapter on a 400-2 intake but the customer was told that the necked down intake made more power. I would've liked to see what a ported 400-3 intake would do on the engine but we didn't have one to try.
One interesting footnote is that we're currently running a 428 inch SBC on the dyno that is making 795 hp. Cam specs are almost identical between the two engines, and we're using the same 1050 Dominator dyno carb. The 540 Mopar had less rocker arm ratio than the 428 SB so that could've been part of the issue.
Next motor on the dyno is a 540 inch BBC with very similar specs. Same compression, cam specs, carb, etc. It will be interesting to see how it does. I think the heads on the BBC are bigger so that might work in its favor.
[Re: AndyF]
#3225255
04/05/24 03:36 PM
04/05/24 03:36 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Always going to make more power with a dedicated 4500 intake. Seen it a number of times for sure.
[Re: AndyF]
#3225256
04/05/24 03:39 PM
04/05/24 03:39 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Frankly, the 815 seems about right to me for that combo. On the dyno here, a similarly built 572 with 14:1 made 878……. So at the same hp/ci a 540 would be 829.
A 14:1 542 with 572-13’s and the 440-3x made 860.
-1/345’s flow about 380 on my bench.
In the BBC world, those would be pretty mediocre flow numbers for heads getting used on a 540” build.
What was the peak TQ, and at what rpm?
[Re: AndyF]
#3225281
04/05/24 06:49 PM
04/05/24 06:49 PM
fast68plymouth
So. Burlington, Vt.
Sounds like he should look into getting his carb reworked.
