Holley running EXTREMELY rich #3221362
03/19/24 08:54 AM
03/19/24 08:54 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang...
Car: 71 440 six pack Challenger RT
Situation: The motor is idling EXTREMELY rich, black smoke out the exhaust and running really rough at idle. The outboard carbs have been disconnected to eliminate them. None of the 3 carbs has fuel flowing out the booster ventures at idle which typically means high float level. Metering block fuel/air mixture screws only about 1 turn out. My gut says the new power valve from a basic rebuild kit is bad. The car was running fine earlier, so the ignition and timing haven't changed.
Troy
Houston Mopar Connection Club
Re: Holley running EXTREMELY rich [Re: hemi68charger] #3221370
03/19/24 09:15 AM
03/19/24 09:15 AM
an8sec70cuda Offline
I agree w/ the power valve being bad.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Holley running EXTREMELY rich [Re: hemi68charger] #3221381
03/19/24 10:13 AM
03/19/24 10:13 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Pull a vacuum test to see if if it holds.
Re: Holley running EXTREMELY rich [Re: an8sec70cuda] #3221450
03/19/24 02:37 PM
03/19/24 02:37 PM
Maybe scope up
I've seen the power valve gaskets kink and cause the same thing rant scope
Re: Holley running EXTREMELY rich [Re: Cab_Burge] #3221544
03/19/24 09:37 PM
03/19/24 09:37 PM
Md.
carnut68 Online content
carnut68  Online Content
Md.
Maybe scope up
Yep, been there done that. Check that gasket.
America First!
Re: Holley running EXTREMELY rich [Re: rickraw] #3221596
03/20/24 06:47 AM
03/20/24 06:47 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Have you checked vacuum at idle? What rating power valve is in there? Maybe there's not enough vacuum at idle to hold it closed.
Re: Holley running EXTREMELY rich [Re: fbs63] #3221599
03/20/24 07:59 AM
03/20/24 07:59 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
If the valve is open because of too little vacuum it won't put anymore fuel in to the engine. That just allows more fuel for the main circuit (through the booster) A ruptured power valve diaphragm, or bad gasket will pull fuel directly into the intake from the bowl.
