Holley running EXTREMELY rich
#3221362
03/19/24 08:54 AM
03/19/24 08:54 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang...
Car: 71 440 six pack Challenger RT Situation: The motor is idling EXTREMELY rich, black smoke out the exhaust and running really rough at idle. The outboard carbs have been disconnected to eliminate them. None of the 3 carbs has fuel flowing out the booster ventures at idle which typically means high float level. Metering block fuel/air mixture screws only about 1 turn out. My gut says the new power valve from a basic rebuild kit is bad. The car was running fine earlier, so the ignition and timing haven't changed.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Holley running EXTREMELY rich
[Re: hemi68charger]
#3221370
03/19/24 09:15 AM
03/19/24 09:15 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I agree w/ the power valve being bad.
[Re: Cab_Burge]
#3221544
03/19/24 09:37 PM
03/19/24 09:37 PM
Posts: 3,243 Md.
carnut68
Md.
I agree w/ the power valve being bad. Maybe I've seen the power valve gaskets kink and cause the same thing Yep, been there done that. Check that gasket.
America First!
[Re: rickraw]
#3221596
03/20/24 06:47 AM
03/20/24 06:47 AM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
Pull a vacuum test to see if if it holds. . Have you checked vacuum at idle? What rating power valve is in there? Maybe there's not enough vacuum at idle to hold it closed.
