Anyone know? #3220903
03/16/24 08:52 PM
03/16/24 08:52 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
Does anyone know the backspacing on this wheel? 15x7 if I recall correctly.
https://www.dropbox.com/scl/fi/sdeh...rlkey=h64trcilrjelmx0yr3j422btn&dl=0
eBay-cdwmotorsports
Re: Anyone know? [Re: cdwmotorsports] #3220911
03/16/24 09:24 PM
03/16/24 09:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I want to say Chrysler steel wheels that are 15x7 all have 4-1/4" backspacing.
Re: Anyone know? [Re: cdwmotorsports] #3220926
03/16/24 10:38 PM
03/16/24 10:38 PM
That is not a Mopar passenger car wheel I have ever seen tsk
Maybe it is one made and used after 1990 confused
Re: Anyone know? [Re: Cab_Burge] #3220939
03/17/24 12:18 AM
03/17/24 12:18 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks like the 15 x 6 .5 mid 80s 5th Ave wheels for the wire wheel hub caps. Three of the 5 holes between the lug nuts were used to hold the hub cap lock bracket onto the wheel. Mopar also made a 15 x 7" wide version of the same wheel. They also offered both widths without the small holes between the lug nuts (I looked a long time to find those). I thought the 7" wide had the wheel centers welded to the rims with them
centered on the rim. I believe the 6 1/2 had the same backspacing the 7" wide had. The wheel pictured looks more like a 6 1/2" wide version. I don't have one with the extra holes here to measure anymore. but I believe the rear wheels on my coupe are the 7" wide without the extra holes (which were used on cars without the wire wheel hub caps). When the wire wheel hub caps first came out, many were stolen, so Mopar had to all a hub cap lock, which is what required the extra holes.
Added a pic. Notice how the wheel appears to have a deeper offset the the one the OP posted? That difference is because the back spacing between the 6 1/2" wide wheel and the 7" wheel are both the same.
Re: Anyone know? [Re: poorboy] #3221087
03/17/24 04:31 PM
03/17/24 04:31 PM
5thAve Offline
5thAve  Offline
Looks like the typical later RWD rim. Most I have are 7" and they usually all have the holes.
Re: Anyone know? [Re: 5thAve] #3221098
03/17/24 05:09 PM
03/17/24 05:09 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I agree.
Do you know, or can you measure the back spacing on one of those wheels?
That was what he wants to know.
Re: Anyone know? [Re: poorboy] #3221199
03/18/24 10:54 AM
03/18/24 10:54 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
M body
Re: Anyone know? [Re: twodoorpost] #3221215
03/18/24 12:26 PM
03/18/24 12:26 PM
Martinsville, IN
Martinsville, IN
Thanks to all of you for your help
eBay-cdwmotorsports
Re: Anyone know? [Re: cdwmotorsports] #3221227
03/18/24 01:34 PM
03/18/24 01:34 PM
moparx Offline
moparx  Offline
any 7" factory wheel i have measured had a 4 1/4" back space.
beer
