2nd gen hemi valve guide / seal question UPDATE adjustments
#3220457
03/14/24 06:52 PM
03/14/24 06:52 PM
Posts: 21,499 It's a dry heat
gtx6970
It's a dry heat
I have mine opened up for some Maintenace Clean and paint touchups, Intake reseal and valve adjustments And want to replace the seals while I have it open.
I have a feeling these are not OEM style The boss where the seal is . measures .528- .530 OD Valves are 5/16ths OD
SO, Im looking for a quality seal
Re: 2nd gen hemi valve guide / seal question
[Re: gtx6970]
#3220461
03/14/24 06:59 PM
03/14/24 06:59 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I run US Seal viton valve seals on my Hemi and all my engines for that matter. Never any issues. My Sixpack 440 has over 65,000 miles on it so far.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: topside]
#3220491
03/14/24 09:18 PM
03/14/24 09:18 PM
gtx6970
It's a dry heat
Anyone have sources. I cant find anything where they shows specs / dimensions of the seal. Part of me thinks the guides on mine have been milled to accept the seals that are on it EDIT, these look like they might work https://www.jegs.com/i/COMP-Cams/249/500-12/10002/-1
[Re: gtx6970]
#3220501
03/14/24 10:12 PM
03/14/24 10:12 PM
Posts: 20,200 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If I can recommend something stay away from Teflon seals. Get a good set of Viton seals
[Re: gtx6970]
#3220556
03/15/24 09:41 AM
03/15/24 09:41 AM
gtx6970
It's a dry heat
Seals ordered And am going to put a set of the milodon tube seals in it while I'm here
EDIT ;
Well chit.
The Milodon tube seals are out of stock everywhere until May.
So, I'll just put valve seals in it, adjust valves and deal with oil in the spark plug tubes as I see fit. / another time
[Re: gtx6970]
#3220561
03/15/24 10:01 AM
03/15/24 10:01 AM
fast68plymouth
So. Burlington, Vt.
It looks like there was an inner spring riding on the locating step?
That’s often not a desirable situation.
[Re: gtx6970]
#3220564
03/15/24 10:13 AM
03/15/24 10:13 AM
Posts: 13,390 Marion, South Carolina [><]
an8sec70cuda
I wouldn't bother w/ valve seals on the exhaust side.
[Re: an8sec70cuda]
#3220566
03/15/24 10:22 AM
03/15/24 10:22 AM
gtx6970
It's a dry heat
I wouldn't bother w/ valve seals on the exhaust side. Im not. I know guys in the past who dont even put seals on the exhaust guide
[Re: fast68plymouth]
#3220567
03/15/24 10:23 AM
03/15/24 10:23 AM
gtx6970
It's a dry heat
That’s often not a desirable situation. It has inner springs. I will take a closer look at that once parts get here House projects today
[Re: JohnRR]
#3220570
03/15/24 10:36 AM
03/15/24 10:36 AM
gtx6970
It's a dry heat
I wouldn't bother w/ valve seals on the exhaust side. Can I ask why ? the way it was told to me is the exhaust is a push side . aka no vacuum to pull oil into the port like the intake side does Being brutally honest with myself. Deep down there is a part of me that thinks new seals will do nothing for my oil consumption issues. But , Its cheap and I have it down far enough I have to give it a try.
#3220588
03/15/24 11:38 AM
03/15/24 11:38 AM
gtx6970
It's a dry heat
That’s often not a desirable situation. Had me concerned. So took the inner springe and ckd. its good. Outer spring is well outside the inner step. Looks like the damper might be rubbing the stepped edge. And I think thats ok
[Re: B1MAXX]
#3220616
03/15/24 12:49 PM
03/15/24 12:49 PM
gtx6970
It's a dry heat
The inner "should" be at the same installed height. Not up on that step.That should get machined away , but If it ain't broke...I would be curios how close to coil bind it is though.
As for the damper the only thing I don't like there is the cast iron going through the engine as it machines itself, but again if it ain't broke....
That head isn't really set for those springs. Thanks, When it comes apart at a later date to freshen it up. I'll have them taken care of , or maybe new heads ???? I'll take a look / ck for coil bind before I put it back together next week. But the engine runs good and has been together for over 20 years with no issues ,,,so far (knocks on wood )
[Re: JohnRR]
#3220624
03/15/24 01:27 PM
03/15/24 01:27 PM
an8sec70cuda
I wouldn't bother w/ valve seals on the exhaust side. Can I ask why ? No vacuum pulling oil in. The exhaust valve is laid over so far on a hemi, the oil doesn't pool up around the guide. Even if it did pull a little oil in, the guides on a hemi could probably use all the lube they can get, lol. I've seen so many hi-perf engines over the years that didn't have seals on the exhaust side and had no issues w/ oil getting past them. I decided to try it myself and have seen no problems.
[Re: an8sec70cuda]
#3220665
03/15/24 04:57 PM
03/15/24 04:57 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I wouldn't bother w/ valve seals on the exhaust side. Can I ask why ? No vacuum pulling oil in. The exhaust valve is laid over so far on a hemi, the oil doesn't pool up around the guide. Even if it did pull a little oil in, the guides on a hemi could probably use all the lube they can get, lol. I've seen so many hi-perf engines over the years that didn't have seals on the exhaust side and had no issues w/ oil getting past them. I decided to try it myself and have seen no problems. thanks Chip ... and Bill ... makes sense .
