2nd gen hemi valve guide / seal question UPDATE adjustments #3220457
03/14/24 06:52 PM
03/14/24 06:52 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I have mine opened up for some Maintenace
Clean and paint touchups, Intake reseal and valve adjustments
And want to replace the seals while I have it open.
I have a feeling these are not OEM style
The boss where the seal is . measures .528- .530 OD
Valves are 5/16ths OD
SO, Im looking for a quality seal
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220459
03/14/24 06:55 PM
03/14/24 06:55 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
A project that snowballed pretty quick
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220461
03/14/24 06:59 PM
03/14/24 06:59 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run US Seal viton valve seals on my Hemi and all my engines for that matter. Never any issues. My Sixpack 440 has over 65,000 miles on it so far.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 2nd gen hemi valve guide / seal question [Re: 6PKRTSE] #3220482
03/14/24 08:30 PM
03/14/24 08:30 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I used SilverSeal's blue silicone seals on my Hemi, which until then had a bit of an appetite even after a complete rebuild.
Worked a charm, still in there.
Never had an intake leak.
FWIW, it had headers - being a "Day 2 car" before I got it; literally, according to 1st owner's logbook - and no heat tubes to the intake.
Re: 2nd gen hemi valve guide / seal question [Re: topside] #3220491
03/14/24 09:18 PM
03/14/24 09:18 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Anyone have sources.
I cant find anything where they shows specs / dimensions of the seal.
Part of me thinks the guides on mine have been milled to accept the seals that are on it
EDIT, these look like they might work
https://www.jegs.com/i/COMP-Cams/249/500-12/10002/-1
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220501
03/14/24 10:12 PM
03/14/24 10:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If I can recommend something stay away from Teflon seals. Get a good set of Viton seals
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220553
03/15/24 09:21 AM
03/15/24 09:21 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I use this style a lot https://www.ebay.com/itm/123106703236 they will expand enough to fit your slightly oversize .500 guide.
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220555
03/15/24 09:41 AM
03/15/24 09:41 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Comp Cams 516-16
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220556
03/15/24 09:41 AM
03/15/24 09:41 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Seals ordered
And am going to put a set of the milodon tube seals in it while I'm here
EDIT ;
Well chit.
The Milodon tube seals are out of stock everywhere until May.
So, I'll just put valve seals in it, adjust valves and deal with oil in the spark plug tubes as I see fit. / another time
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220561
03/15/24 10:01 AM
03/15/24 10:01 AM
So. Burlington, Vt.
So. Burlington, Vt.
It looks like there was an inner spring riding on the locating step?
That’s often not a desirable situation.
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220564
03/15/24 10:13 AM
03/15/24 10:13 AM
an8sec70cuda Offline
I wouldn't bother w/ valve seals on the exhaust side. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 2nd gen hemi valve guide / seal question [Re: an8sec70cuda] #3220566
03/15/24 10:22 AM
03/15/24 10:22 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Im not.
I know guys in the past who dont even put seals on the exhaust guide
Re: 2nd gen hemi valve guide / seal question [Re: fast68plymouth] #3220567
03/15/24 10:23 AM
03/15/24 10:23 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
It has inner springs. I will take a closer look at that once parts get here
House projects today
Re: 2nd gen hemi valve guide / seal question [Re: an8sec70cuda] #3220568
03/15/24 10:24 AM
03/15/24 10:24 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Can I ask why ?
Re: 2nd gen hemi valve guide / seal question [Re: JohnRR] #3220570
03/15/24 10:36 AM
03/15/24 10:36 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Can I ask why ?
the way it was told to me is the exhaust is a push side . aka no vacuum to pull oil into the port like the intake side does
Being brutally honest with myself.
Deep down there is a part of me that thinks new seals will do nothing for my oil consumption issues.
But , Its cheap and I have it down far enough I have to give it a try.
Re: 2nd gen hemi valve guide / seal question [Re: fast68plymouth] #3220588
03/15/24 11:38 AM
03/15/24 11:38 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Had me concerned.
So took the inner springe and ckd. its good. Outer spring is well outside the inner step. Looks like the damper might be rubbing the stepped edge. And I think thats ok
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3220602
03/15/24 12:31 PM
03/15/24 12:31 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The inner "should" be at the same installed height. Not up on that step.That should get machined away , but If it ain't broke...I would be curios how close to coil bind it is though.
As for the damper the only thing I don't like there is the cast iron going through the engine as it machines itself, but again if it ain't broke....
That head isn't really set for those springs.
Re: 2nd gen hemi valve guide / seal question [Re: B1MAXX] #3220616
03/15/24 12:49 PM
03/15/24 12:49 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks, When it comes apart at a later date to freshen it up.
I'll have them taken care of , or maybe new heads ????
I'll take a look / ck for coil bind before I put it back together next week.
But the engine runs good and has been together for over 20 years with no issues ,,,so far (knocks on wood )
Re: 2nd gen hemi valve guide / seal question [Re: JohnRR] #3220624
03/15/24 01:27 PM
03/15/24 01:27 PM
Can I ask why ?
No vacuum pulling oil in.
The exhaust valve is laid over so far on a hemi, the oil doesn't pool up around the guide.
Even if it did pull a little oil in, the guides on a hemi could probably use all the lube they can get, lol.
I've seen so many hi-perf engines over the years that didn't have seals on the exhaust side and had no issues w/ oil getting past them. I decided to try it myself and have seen no problems.
CHIP
Re: 2nd gen hemi valve guide / seal question [Re: an8sec70cuda] #3220665
03/15/24 04:57 PM
03/15/24 04:57 PM
U.S.S.A.
U.S.S.A.
Can I ask why ?
thanks Chip ... and Bill ... makes sense .
