EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke #3220530
03/15/24 01:08 AM
03/15/24 01:08 AM
Buenos Aires, ARGENTINA
madmax2 Offline OP
madmax2  Offline OP
I currently have an SBM 418 stroker running with Holley HP EFI with 4-barrel TBI over weiand single plane intake (x-celerator).
Looking ahead to future improvements and since the Holley HP ECU can handle 8 injectors, I thought about making it MPFI using a Super Victor EFI intake or getting another 4-barrel TBI and using a tunnel-ram.
not for running, just for personal taste.
what do you think?
pd: If I go for a 2x4 configuration that intake recommends
'70 Dodge GTX sb 418ci (Early A-body),
Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator,
Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: madmax2] #3220534
03/15/24 02:26 AM
03/15/24 02:26 AM
I think a system that can and does controls eight direct port injectors would be more efficient and make more power than dual wet EFI throttle bodies work scope twocents up
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: madmax2] #3220583
03/15/24 11:18 AM
03/15/24 11:18 AM
AndyF Offline
AndyF  Offline
Which Holley ECU are you using? If you have a Terminator, HP or Dominator ECU then you have the ability to do all sorts of things. The older Holley systems are a little more limited in what they can do.
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: AndyF] #3220584
03/15/24 11:22 AM
03/15/24 11:22 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
He is running Holley HP ecu.
I think it's worth going multi port injection. Whatever intake you decide to use I would run multi port. So, convert a single 4bbl or tunnel ram intake to multi port.
(I wouldn't get another TBI unit for the 2x4 setup)
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: INTMD8] #3220681
03/15/24 06:50 PM
03/15/24 06:50 PM
AndyF Offline
AndyF  Offline
I use a good single plane intake with a Holley throttle body. Edelbrock makes the Super Victor EFI for SB Mopar engines so that is what I'd use. I'm assuming that since it is a 418 it has good heads and the Super Victor intake will fit and work on there.
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: Cab_Burge] #3220709
03/15/24 09:09 PM
03/15/24 09:09 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: Dragula] #3220718
03/15/24 09:46 PM
03/15/24 09:46 PM
AndyF Offline
AndyF  Offline
Kinsler stacks would be the last thing I'd recommend for a street engine!
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: AndyF] #3220727
03/15/24 10:22 PM
03/15/24 10:22 PM
iagree down shruggy
Talk about a touchy throttle pedal shock tsk
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: madmax2] #3221168
03/18/24 03:53 AM
03/18/24 03:53 AM
madmax2 Offline OP
madmax2  Offline OP
thanks you, go to MPFI single plane and reuse the TBI body only.
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: madmax2] #3221211
03/18/24 12:03 PM
03/18/24 12:03 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
My son has an engine not too dissimilar to yours.
He could see that even with the Holley 4150 style 1,000 CFM throttle body with port injection he was still pulling some vacuum.
He went to a tunnel ram and another throttle body and picked up a tenth if I remember correctly.
It it has been on Drag Week many times so it is a true street strip car.
Currently configuring a Kinsler stack injection (converting to EFI) for it but that will be a while before it sees the track.
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: madmax2] #3221238
03/18/24 02:30 PM
03/18/24 02:30 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
what do you think?
Can you please give us some details on your engine
What is the compression ratio, what heads are you using, camshaft, etc... thanks..
Plymouth Makes It!
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: RoadRunnerLuva] #3221346
03/19/24 03:47 AM
03/19/24 03:47 AM
madmax2 Offline OP
madmax2  Offline OP
Quote
10:1 CR, Lunati solid flat 404A1LUN (270ºadv, 243º@050, .548", 104º/110º), hand ported edelbrock head 280cfm@550", ported single plane XCELerator 300cfm.
I have a street car
Re: EFI: One 4-barrel o Dual-Quad TBI in a SBB 418 stroke [Re: madmax2] #3221443
03/19/24 01:58 PM
03/19/24 01:58 PM
Land 'O Lakes
Land 'O Lakes
Quote
10:1 CR, Lunati solid flat 404A1LUN (270ºadv, 241º@050, .548", 104º/110º), hand ported edelbrock head 280cfm@550", ported single plane XCELerator 300cfm.
I have a street car
Nice! It's very similar to the engine (418") in my street Duster. I have heavily ported J heads..
and a Bullet Racing solid cam #30400, using a ported/gasket matched Edelbrock single plane Victor intake.
Fuel delivery is a Race Demon 850 cfm.
Plymouth Makes It!
