Removing tape stripes #3219302
03/09/24 02:18 PM
03/09/24 02:18 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
I've removed lots of vinyl speed-equipment decals using a heat gun, but I'm wondering about the '73 Duster 340 side stripes...
Car was painted & re-striped about 10 years ago, and been a garage queen since.
So, I'm thinking the stripes should be removable without damaging the paint, using that process.
And that there should be no fading/witness afterwards.
The reasons I'm debating it:
1. Had a '72 Gold Duster a couple years ago whose original side molding was baked on, and NOTHING would remove the adhesive, except sanding.
2. I don't want to bet the cost of a re-paint.
I'm probably worrying in vain, but I really don't like that stripe design.
Re: Removing tape stripes [Re: topside] #3219303
03/09/24 02:32 PM
03/09/24 02:32 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Should come off with a hair dryer and by rolling the vinyl back over top of itself very slowly. Warm up a foot or so at a time and work your way down the car. Don't pull on it upward, or do it in a hurry. Even if the rest of the paint is not faded the paint under the decals is likely to look different from the surrounding paint due it not being washed and rubbed on by waxing etc. so a light polish job may be required.
Re: Removing tape stripes [Re: Neil] #3219306
03/09/24 02:41 PM
03/09/24 02:41 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Yup, Neil, that's what I'm thinking - I'm probably just being an old lady about it laugh2
Re: Removing tape stripes [Re: topside] #3219311
03/09/24 02:59 PM
03/09/24 02:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
They do make those 3M vinyl stripe wheels too, but I have never tried one.
Re: Removing tape stripes [Re: Neil] #3219327
03/09/24 04:10 PM
03/09/24 04:10 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Be VERY careful with the vinyl remover wheels. They can and will damage the paint. I only use them when I am planing on repaint the car or area. They sale hard plastic razor blades that I have used with good success on stripes on a 1998 Durango that where their from the factory, when using the heat gun.
My Monster are real!
Living within your means makes life pretty easy.
Re: Removing tape stripes [Re: 67vertman] #3219463
03/10/24 08:52 AM
03/10/24 08:52 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i am a pro bodyman / painter. i use them at least 1 time a week..
if used properly they won't damage paint. the key is going SLOW with the wheel. this keeps the heat build up down.
the best suggestion is use a battery powered hand drill and keep the rpm below 500rpm, preferably about 300rpm..
if you used lacquer anything in the paint job. don't even think about using a stripe eraser wheel on it.
if you used modern 2K products on the METAL from start to finish you won't have any problems. if plastic anything you will probably need to repaint if using a wheel.
perception is 90% of reality
Re: Removing tape stripes [Re: 67vertman] #3219474
03/10/24 10:22 AM
03/10/24 10:22 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I tried the wheel and it will damage the paint pretty easy but I `m no pro by any stretch. The plastic razors do work well though.
Re: Removing tape stripes [Re: mopars4ever] #3219488
03/10/24 11:47 AM
03/10/24 11:47 AM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
I'm sure it's BC/CC paint, and I've used & have the stripe-remover wheels - I think the stripes are wide enough that heat is best removal method.
Re: Removing tape stripes [Re: Mr T2U] #3219495
03/10/24 12:06 PM
03/10/24 12:06 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree We frequently use the wheels. When used properly, they work very well with no damage to modern paint. IF there is paint damage, the issue is NOT the wheel.
www.youtube.com/watch?v=7Y_2DYBwoTU&t=61s
Master, again and still
