Re: Removing tape stripes
[Re: Neil]
#3219327
03/09/24 04:10 PM
03/09/24 04:10 PM
Posts: 4,754 Star Idaho
67vertman
Star Idaho
They do make those 3M vinyl stripe wheels too, but I have never tried one. Be VERY careful with the vinyl remover wheels. They can and will damage the paint. I only use them when I am planing on repaint the car or area. They sale hard plastic razor blades that I have used with good success on stripes on a 1998 Durango that where their from the factory, when using the heat gun.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3219463
03/10/24 08:52 AM
03/10/24 08:52 AM
Posts: 4,921 new berlin wisconsin
Mr T2U
They do make those 3M vinyl stripe wheels too, but I have never tried one. Be VERY careful with the vinyl remover wheels. They can and will damage the paint. I only use them when I am planing on repaint the car or area. They sale hard plastic razor blades that I have used with good success on stripes on a 1998 Durango that where their from the factory, when using the heat gun. i am a pro bodyman / painter. i use them at least 1 time a week.. if used properly they won't damage paint. the key is going SLOW with the wheel. this keeps the heat build up down. the best suggestion is use a battery powered hand drill and keep the rpm below 500rpm, preferably about 300rpm.. if you used lacquer anything in the paint job. don't even think about using a stripe eraser wheel on it. if you used modern 2K products on the METAL from start to finish you won't have any problems. if plastic anything you will probably need to repaint if using a wheel.
perception is 90% of reality
[Re: 67vertman]
#3219474
03/10/24 10:22 AM
03/10/24 10:22 AM
Posts: 13,589 md
mopars4ever
md
They do make those 3M vinyl stripe wheels too, but I have never tried one. Be VERY careful with the vinyl remover wheels. They can and will damage the paint. I only use them when I am planing on repaint the car or area. They sale hard plastic razor blades that I have used with good success on stripes on a 1998 Durango that where their from the factory, when using the heat gun. I tried the wheel and it will damage the paint pretty easy but I `m no pro by any stretch. The plastic razors do work well though.
[Re: Mr T2U]
#3219495
03/10/24 12:06 PM
03/10/24 12:06 PM
Posts: 12,082 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
They do make those 3M vinyl stripe wheels too, but I have never tried one. Be VERY careful with the vinyl remover wheels. They can and will damage the paint. I only use them when I am planing on repaint the car or area. They sale hard plastic razor blades that I have used with good success on stripes on a 1998 Durango that where their from the factory, when using the heat gun. i am a pro bodyman / painter. i use them at least 1 time a week.. if used properly they won't damage paint. the key is going SLOW with the wheel. this keeps the heat build up down. the best suggestion is use a battery powered hand drill and keep the rpm below 500rpm, preferably about 300rpm.. if you used lacquer anything in the paint job. don't even think about using a stripe eraser wheel on it. if you used modern 2K products on the METAL from start to finish you won't have any problems. if plastic anything you will probably need to repaint if using a wheel. We frequently use the wheels. When used properly, they work very well with no damage to modern paint. IF there is paint damage, the issue is NOT the wheel. www.youtube.com/watch?v=7Y_2DYBwoTU&t=61s
Master, again and still
